Hybrid 12v battery jumping - Page 7 - Toyota Nation Forum : Toyota Car and Truck Forums
post #91 of 240 Old 01-27-2013, 08:00 PM
Senior TN Member
Ron AKA's Avatar
Quoted: 32 Post(s)
Originally Posted by restamp View Post
Perhaps the most demanding thing on startup is the accumulator pump -- does anyone know if it is driven off the 12V battery or the traction battery?)
I think the only accessory motor that runs off the HV battery is the A/C drive motor. The brake hydraulic fluid pump starts when you open the door and I believe at that point the 245 volt battery is not connected, so it must be 12 volt.
2012 Camry XLE Hybrid
Ron AKA is offline
post #92 of 240 Old 07-18-2013, 12:37 PM
Quoted: 0 Post(s)
Not Driving TCH Every Third Week
Starting in the fall, my travel will increase dramatically, with my TCH (2012 XLE) going up to 8 days without being driven, and spending one week out of every three idle in my garage.
How will this impact starting/battery when I return?
Also, does it matter how high the traction battery is charged when I leave the car for a week?
Sent from AutoGuide.com Free App
Mater99 is offline
post #93 of 240 Old 07-18-2013, 03:27 PM
Quoted: 0 Post(s)
It shouldn't be a problem. Just make sure the interior and exterior lights are off, and don't leave a fob in or near the car.
firepa63 is offline
post #94 of 240 Old 07-18-2013, 03:41 PM
Senior TN Member
Quoted: 22 Post(s)
I would drive it enough to see the traction battery is at least charge to 50% or higher before parking it for the 8 days. I would also make sure the clock is dark, or no digits to insure it's powered off.
WhiteSands is offline
post #95 of 240 Old 07-18-2013, 04:28 PM
Quoted: 9 Post(s)
That's what I was planning to do next month when my TCH will be parked for 8 days while I'm out of town. Figured better safe than sorry.
nutzo is offline
post #96 of 240 Old 07-18-2013, 05:04 PM
Quoted: 1 Post(s)
Sometimes I am in Florida for 2-3 months while my Camry will back home in the garage.........am I going to have problems?
randyf is offline
post #97 of 240 Old 07-18-2013, 07:21 PM
Quoted: 20 Post(s)
Two data points:
1. I left my 2012 TCH parked 8 days last month while I was out of town on vacation. When I returned, the 12V battery voltage was 12.53V and the car started without incident.
2. A friend left her 2007 Prius parked 4 months. When she returned, the 12V battery was too dead to start the car, but after a recharge it started fine. No problem with the traction battery. (Prior to this, the 12V battery had started the car after 3 months of non-use.)
YMMV
Rob - 2012 Camry Hybrid XLE
restamp is offline
post #98 of 240 Old 07-18-2013, 07:34 PM
Senior TN Member
Ron AKA's Avatar
Quoted: 32 Post(s)
Just make sure it is turned off. No need to do any more. There is a little power consumption on the 12 volt circuit, but I believe you are good for at least 3 weeks and probably more. No consumption on the high voltage side. No need to waste gas driving around trying to get it charged to a high level.
Ron AKA is offline
post #99 of 240 Old 07-18-2013, 08:16 PM
Quoted: 9 Post(s)
Our Camry is about to spend the next 2 1/2 months sitting in our garage while we're away. I always leave whichever car is in the garage for this amount of time connected to a battery tender and have never had a problem when we return.
2012 TCH XLE-77,000 miles
2015 Volvo V60
2005 Odyssey
1970 Camaro-original owner
gin man is offline
post #100 of 240 Old 07-18-2013, 08:20 PM
SDRider's Avatar
Quoted: 6 Post(s)
I wouldn't worry about it. 8 days is nothing.
2012 Toyota Camry Hybrid XLE
2014 Lexus ES350
SDRider is offline
post #101 of 240 Old 07-18-2013, 08:23 PM
Moderator
ukrkoz's Avatar
Quoted: 800 Post(s)
Just to sleep better, put Battery Tender on 12V battery. I'd still not leave traction battery with two or so bars.
ukrkoz is offline
post #102 of 240 Old 07-18-2013, 09:10 PM
Quoted: 0 Post(s)
For the time my car is less than 2 years old, would Toyota Roadside Assistance jump it for me if it did fail to start?
Mater99 is offline
post #103 of 240 Old 07-18-2013, 09:48 PM
Quoted: 20 Post(s)
I would certainly hope so. I would call them first if my car wouldn't start. (That said, I'm not sure if this program encompasses problems that occur at home and not on the road. Anyone know?)
restamp is offline
post #104 of 240 Old 07-18-2013, 11:57 PM
Quoted: 9 Post(s)
That would only work if it was the 12 volt battery. The TCH uses the traction battery to start the car, and if it's drained, they will NOT be able to jump start the car. Only way to charge the traction battery would be to have the car towed to the dealer.
Maybe Toyota should turn all their Hybrids into plug-in Hybrids.
Wouldn't cost that much for a simple charging circuit that would top off the small Hybrid battery over night using a standard outlet.
nutzo is offline
post #105 of 240 Old 07-19-2013, 11:37 AM
Senior TN Member
Ron AKA's Avatar
Quoted: 32 Post(s)
I would expect roadside assistance to do the towing if that becomes necessary. Except in cases of a failed HV battery I've never heard of anyone reporting a discharged HV battery. 12V yes if left for a long time, but HV no.
Ron AKA is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Hybrid Forum > Camry Hybrid
User Tag List
Linear Mode Linear Mode
