2019 SE Rear View Mirror with Homelink Mod - Toyota Nation Forum : Toyota Car and Truck Forums
post #1 of 7 Old 04-03-2019, 09:59 AM Thread Starter
Quoted: 2 Post(s)
(Thread Starter)
Hello,
I just purchased a 2019 Camry SE, it does not have the Auto Dimming Rear View Mirror with Homelink so i need to add it. The original mirror is not auto dimming so there is no wiring running to the original mirror.
At this time i have not tried taking anything apart, There could be a connection behind the bulky cover for the front camera?
I wanted to get feedback from anyone that may have experienced a need for this modification and anyone that has completed it.
I need to purchase the mirror, i believe Gentex is the correct company?
Thanks,
Mark
markasparks is offline
post #2 of 7 Old 04-03-2019, 10:02 AM
Senior TN Member
Vangm25's Avatar
Quoted: 743 Post(s)
Check a wiring diagram or you can pry off some plastic trim and hope there it is pre-wired.
Vangm25 is online now
post #3 of 7 Old 04-04-2019, 06:28 AM Thread Starter
Quoted: 2 Post(s)
(Thread Starter)
i will take the trim off today and see if it is wired for the mirror.
Thank You,
Mark
post #4 of 7 Old 04-04-2019, 10:36 AM Thread Starter
Quoted: 2 Post(s)
(Thread Starter)
I took the enclosure apart and found a 12 pin plug, i think its being used by Lane Departure Alert with Steering Assist.
One more plug runs along the top of Steering Assist Module.
How can i use this with the 10 pin that goes in back of mirror?
File Type: jpeg 63BBA60E-C690-416E-9538-75BFDA9E18E0.jpeg (591.5 KB, 10 views)
File Type: jpeg C44D91E1-1E2E-43BF-9D5F-EFD88611D3B4.jpeg (731.0 KB, 7 views)
File Type: jpeg 8AE89AFF-9D1C-41CF-917C-342CED43082B.jpeg (364.3 KB, 7 views)
File Type: jpeg A96E5CEE-D806-4337-9204-B14465560714.jpeg (560.6 KB, 8 views)
post #5 of 7 Old 04-04-2019, 10:43 AM
Senior TN Member
Vangm25's Avatar
Quoted: 743 Post(s)
You would have to look at a wiring diagram to determine a lot of that.
The Following User Says Thank You to Vangm25 For This Useful Post:
markasparks (04-05-2019)
post #6 of 7 Old 04-05-2019, 09:41 AM Thread Starter
Quoted: 2 Post(s)
(Thread Starter)
Thanks, iím looking for the diagram
post #7 of 7 Old 04-05-2019, 10:03 AM
Senior TN Member
Vangm25's Avatar
Quoted: 743 Post(s)
Toyota TIS, get your 2-days.
Tags
homelink
User Tag List
Linear Mode Linear Mode
