1mzfe vs. 3mzfe, which one is a better swap? - Page 2 - Toyota Nation Forum : Toyota Car and Truck Forums
post #16 of 19 Old 05-30-2017, 08:14 AM
Quoted: 3 Post(s)
Did you complete the swap of a V6 into into your 1988 Corolla GTS?
I know it's been a while ago but I am wondering if it worked.
Originally Posted by Prof ozone View Post
I'm planning to drop a V6 into my 1988 Corolla GTS and I'm doing research into which one would be the best candidate.
I've eliminated the 3vzfe because of weight and age.
The 1mzfe would be a great choice for many reasons:
1. I have one in the garage, in my wife's car.
2. Older technology is less expensive.
3. It was available from the factory mated to a 5 speed.
4. Good power and economy.
5. Should fit under the hood (I still have to verify this).
6. I have all of the technical manuals for it already.
7. Standard throttle cable.
8. Can be supercharged (I even have the supercharger).
Some potential problems with it are:
1. They are getting old now and I would be swapping one old motor for another.
2. Possible sludge issues (do the new ones have this too?)
3. Power, while good, could be better.
The 3mzfe has one huge advantage in my opinion.
1. I could get one in a wrecked car that has less than say 50K miles on the odometer.
2. Also, more displacement means more horsepower and torque.
The disadvantage is:
1. I don't really know this engine. Is it basically the same size as the 1mzfe? I think the two are very similar, aren't they? I would need to verify that it would fit under my hood.
2. I've heard that the throttle-by-wire is calibrated for economy and not performance. I don't think I would care as long as it was still fast enough. I would need to know to what degree, this thing is scaled back.
3. Also, I would need to know if there were other things about the engine that I would need. For instance, to use the stock ECU on the 1mzfe (and the OBDII setup), I would need the charcoal canister. Does the 3mzfe have more extra components like that?
So that's a lot to digest, but it really comes down to the basic question of which engine is the right choice. I have a higher level of confidence swapping a 1mzfe from a Solara for instance, but it's hard to resist the calling of a newer engine. If I can't find a 1mzfe with a 5 speed, I would have figure out how mate one up anyway, so what's the difference in doing that with a 3.0 liter or a 3.3 liter (I already know that the E153 transmission will bolt up to both engines).
Let's hear your opinion on this.
Thanks for hanging in there on such a long winded question.
James Callaway is offline
post #17 of 19 Old 05-30-2017, 09:54 PM
BMR
Sheriff of Mayberry
BMR's Avatar
Quoted: 1882 Post(s)
See link in his post #10: https://www.toyotanation.com/forum/10...ml#post3619317
2015 RAV4 Limited, AWD, tech pkg, Barcelona red metallic, 66k miles
1996 Avalon XLS, ABS brakes, super white II, acquired w/ 139k, now at 400k
1992 Camry LE, V6 (3VZ-FE), ABS brakes, dark emerald pearl, owned since new. Replaced HGs @332k, totaled at 384k miles
BMR is online now
post #18 of 19 Old 06-18-2017, 10:59 AM
Senior TN Member
Quoted: 301 Post(s)
Originally Posted by BMR View Post
from Ozone's WEB site (6/18/17)
Number of times I have installed the engine and removed it: 18
Number of times I have installed the gas tank and removed it: 10
yikes its a 1MZ3MZOCD hybrid!
tedmich is offline
post #19 of 19 Old 10-10-2018, 01:49 PM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
It's been a while since I was on this forum, but I saw that about a year ago I was asked if the swap was successful. The answer is yes and no. My website, although not updated recently is still accurate. The engine is in, but I am still working on the project, even after all of these years. The Corolla is my forever car and I will not stop. That said a lot happened in my life in the last couple of years that kept me from working on it. However, I recently retired early and now it will be moved back to the front burner, so there will be a lot of updates coming soon, but really ramping up in January.
Thank you for your interest.
ozone
World's first V6 powered AE92 Corolla . . . in progress.
www.ozone2000.com
Prof ozone is offline
User Tag List
Linear Mode Linear Mode
