Led flasher hunt - Toyota Nation Forum : Toyota Car and Truck Forums
Tundra 2nd Generation (2007-2013) Discussion of the 2nd generation of the Toyota Tundra
 1Likes
  • 1 Post By SnyperOne
post #1 of 5 Old 03-14-2019, 10:54 PM Thread Starter
SnyperOne's Avatar
Quoted: 33 Post(s)
(Thread Starter)
Led flasher hunt
I can't seem to pinpoint a vehicle specific LED flasher unit for my 2011 Tundra. The OEM flasher part # is 81980-0C020. Most units don't have the letter "C" in the part number, but I see no replacement number.
Thanks in advance
SnyperOne is offline
post #2 of 5 Old 03-15-2019, 05:16 PM
T100 Road Warrior...
BamZipPow's Avatar
Quoted: 902 Post(s)
Wink
If yer up fer some simple modding, give this a read.
https://v-ledsblog.com/2010/12/02/ho...k-with-v-leds/
...or this one.
https://www.tundratalk.net/forums/tu...n-signals.html
1998 T-100 SR5 2WD auto, Roadmaster Active suspension, dual oil catch jars, AC mod, aero cap, lower aero package, 67% grill block, aero single wheel trailer
BamZipPow is offline
post #3 of 5 Old 03-17-2019, 08:49 AM Thread Starter
SnyperOne's Avatar
Quoted: 33 Post(s)
(Thread Starter)
Thanks for the wonderful info !! I was moving along nicely with the Dremel, taking my time, but I was only looking at the dash when testing the unit. When the flash returned to a normal pace, I went to the front of the truck and noticed that the ding dang "RED" LED bulbs (Sylvania 3157R) were not blinking. The rear bulbs were doing fine. I switched out the front with white LED bulbs (Sylvania 3157) and they work perfectly. Only in my world...
I'm tempted to keep the reds in anyway cuz they look absolutely fantastic on a red Tundra..
Click image for larger version
ID:	235962   Click image for larger version
ID:	235964   Click image for larger version
post #4 of 5 Old 03-17-2019, 10:40 PM
BamZipPow's Avatar
Quoted: 902 Post(s)
Wink
Not to spoil yer fun but...
https://law.justia.com/codes/arkansa...r-2/27-36-216/
(2) The lamps showing to the front shall be located on the same level and as widely spaced laterally as practicable and when in use shall display a white or amber light, or any shade of color between white and amber, visible from a distance of not less one hundred feet (100') to the front in normal sunlight.
post #5 of 5 Old 03-17-2019, 11:25 PM Thread Starter
SnyperOne's Avatar
Quoted: 33 Post(s)
(Thread Starter)
Ha Ha ! That is awesome how we are on the same page. I have already prepped for a roadside meeting with law enforcement by having the white LED's and the OEM amber bulbs in a zip bag within reach to switch them back, if necessary. I will demand that the officer admits to how badass they look. I might even ask if hand signals will suffice, but I will immediately and graciously comply. They will also want to see my Smith and Wesson M&P 9mm when I present my Concealed Permit with my DL.
The blinking problem was due to being sold the wrong bulb. The Sylvania Zevo remedied the issue.
When I created the thread, I thought about just contacting you because I knew you'd have the answer. You're awesome, my man.
Thanks !!
Name:	BULB PACK 01.jpg
ID:	236034   Click image for larger version
Name:	FLASHER MOD 01.jpg
BamZipPow likes this.
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tundra Forum > Tundra 2nd Generation (2007-2013)
User Tag List
Linear Mode Linear Mode
