Wet carpets, again. But not what you might think - Toyota Nation Forum : Toyota Car and Truck Forums
Highlander 2nd Generation (2008-2013) Forum dedicated to the discussion of 2nd generation Toyota Highlanders.
post #1 of 3 Old 04-20-2019, 05:06 PM Thread Starter
Quoted: 25 Post(s)
(Thread Starter)
Angry Wet carpets, again. But not what you might think
To my surprise and high frustration, I discovered the passenger side carpet was thoroughly soaked. Further, I found damp carpet in the second row. Back in the winter water froze in the sunroof drain passenger side blocking it and spilling into the interior. Luckily I quickly became aware of the water then. No problem since until today.
After removing all the Weathertech rubber carpet covers and checking all carpets I learned that the underside of all the Weathertech pieces were heavily coated with "dew". The sunroof drains are clear, so is the A/C drain. This part of the South has had a good amount of rain and off and on cool nights. As best I can tell condensation has been the culprit.
There has been no need for A/C or heat in the car so no drying by those mechanisms. Now I'll have to keep an eye on the carpets until it turns much warmer and the solar gain or A/C can keep the interior dry.
Have any other Weathertech users experienced anything like this?
Will
2013 Silver Limited AWD, OEM Hitch, BSM, running boards, mudguards, crossbars
TN SkyPilot is offline
post #2 of 3 Old 04-20-2019, 06:25 PM
Senior TN Member
Quoted: 619 Post(s)
Toyota had an issue with the A/C drains. It attracted bugs and was the perfect home for these critters. They can out with a hose with built-in bug repellant/killer to prevent the drains from clogging.
Yes, I've dealt with sunroof and HVAC clogging drains, along with other rainwater drains a little too much. Damn insects are the worst. But leaves/seeds/pineneedles decomposing are major culprits.
Do you park your car on a level surface? or is your driveway a hill? Rain days on hilly steep driveway caused some problems too,
https://attachments.priuschat.com/at...SB-0033-14.pdf
So many trolls so little time
Greasymechtech is online now
The Following User Says Thank You to Greasymechtech For This Useful Post:
TN SkyPilot (04-21-2019)
post #3 of 3 Old 04-21-2019, 05:26 AM Thread Starter
Quoted: 25 Post(s)
(Thread Starter)
Thanks for the TSB, GMT! I'll check it out, too.
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Highlander Forum > Highlander 2nd Generation (2008-2013)
User Tag List
Linear Mode Linear Mode
