1990 toyota corona gl starts dies after 1 minute - Toyota Nation Forum : Toyota Car and Truck Forums
Corona Forum Specific discussion of the Toyota Corona
post #1 of 4 Old 06-08-2016, 10:03 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Unhappy 1990 toyota corona gl starts dies after 1 minute
so ive brought a 1990 corona gl 2.0 liter it starts fine idles perfectly for no longer than 1 minute then it sounds like it runs out of fuel can keep it running for a little longer spraying fuel down the carburetor. fuel pump seems fine. new distributor. any ideas?
annoyingcorona is offline
post #2 of 4 Old 06-09-2016, 12:09 PM
Toyota Collector
71Corolla's Avatar
Quoted: 2428 Post(s)
If you really don't have a fuel problem then when the engine dies check for spark. I had a 1979 Corolla that would run for 5 minutes then die, let it sit for an hour it would run again then die. The igniter circuit was defective.
2000 Lexus ES300 Millenium Edition
1990 Camry LE V6 Anniversary Edition 5-Speed
1990 Camry LE V6 WAGON
1987 Camry LE I4 5-Speed
71Corolla is online now
post #3 of 4 Old 06-10-2016, 11:11 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
yeah it has good spark. its quite wierd because when it dies it can take awhile to fire up again the other day i started it 5 times it ran for 1.24 every time im stumped stripped carby down cleaned it out must be an electrical fault. also battery light stays on all the time has a new alternator fitted.
post #4 of 4 Old 06-13-2016, 02:08 PM
Soylent Green sales
fourwd1's Avatar
Quoted: 560 Post(s)
Does the carb have a sight glass you can watch to see if maybe the fuel bowl isn't going empty maybe?
_No THANKs necessary !
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corona Forum
Tags
1990 corona dies
User Tag List
Linear Mode Linear Mode
