UK Carina2 (gen2 1991) sal. - Page 10 - Toyota Nation Forum : Toyota Car and Truck Forums
Corona Forum Specific discussion of the Toyota Corona
 44Likes
post #136 of 150 Old 02-17-2019, 10:27 AM Thread Starter
Brit, in Bitz!
tooSavvy's Avatar
Quoted: 28 Post(s)
(Thread Starter)
UK
My 'right turn' stalk is getting a nuisance with Bzzz Bzzz Bzzz and NOT flashing the turn lamps....
I have read a detailed stripdown/fix [on Ih8mud forum] and have lots of pictures of the basic construction.
Later Toyotas have the stalk as a 'plug in' unit.... Mine (and MR2) is a complete alloy do-nut around the column.
Wheel off, cowlings removed and then unplug/test/strip as required.
The part I picked up off eBay [V Cheeep!] is a Mk2 MR2 assembly.... But I only want to rob bits so it wont matter. They seem all very basically similar tbh
It can't be too bad because when I push forward [full beam position] the turn switch performs perfectly....
Looking forward to the job - I love taking stuff to bits!
Need a deep 19MM socket, retighten 25 ft/lb.
2sav
TOO MUCH POWER is not quite Enough!
tooSavvy is offline
post #137 of 150 Old 02-18-2019, 04:18 AM Thread Starter
Brit, in Bitz!
tooSavvy's Avatar
Quoted: 28 Post(s)
(Thread Starter)
UK
Well Well Well....
Thanks, m8
...... we now have 'a plan!'
2sav
tooSavvy is offline
post #138 of 150 Old 02-22-2019, 10:19 AM Thread Starter
Brit, in Bitz!
tooSavvy's Avatar
Quoted: 28 Post(s)
(Thread Starter)
UK
My MR2 stalks arrived today, along with my 19MM socket & M6 stainless wingnuts (for locating the cambox cover).
Just clearing a spot for taking a peek at the actual 'winker' contacts.... For some insight into their condition (here, s/hand) and how I might fix 'in situ', perhaps, mine on the car.
Interesting.....
2sav
tooSavvy is offline
post #139 of 150 Old 02-23-2019, 09:18 AM Thread Starter
Brit, in Bitz!
tooSavvy's Avatar
Quoted: 28 Post(s)
(Thread Starter)
UK
Winkers Sorted **Winnah**
..... the bit of tinplated brass that slides across the pips was 'worn bright' = should have a matte tinning finish
The piece from eBay, my MR2 switch is mint... So just swapped over and I 'lightly scuffed' the surface of the pips with the edge of my jewellers screwdriver. Re-smeared everything with the excess/clean grease from under the cover and clipped everything back in place.
.... sharpie pen mark to keep wheel back in correct spot!
The nut was finger tight - likely years of folks heaving out.. Fitters arm crank retighten! NaaPraablem
2sav
tooSavvy is offline
post #140 of 150 Old 02-27-2019, 10:16 AM Thread Starter
Brit, in Bitz!
tooSavvy's Avatar
Quoted: 28 Post(s)
(Thread Starter)
UK
Replaced cap, leads & rotor arm.
The red vac hose goes for ever... and I haven't done the 'nest' under the carb!
Still need to check timing and clean the outside of the carb (coated in crusty dust and grease) and tune up
Mojo up for all this
2sav
tooSavvy is offline
post #141 of 150 Old 03-07-2019, 11:33 AM Thread Starter
Brit, in Bitz!
tooSavvy's Avatar
Quoted: 28 Post(s)
(Thread Starter)
UK
THIS is just on order:-
https://fuze-products.co.uk/shop/rus...ferprime-black
9.95UKpound + post @amazon
I have inner void wax treatment (several spraycans) and have done the inner/rear sill + lower arch "achilles heel" but want to do the floor/sill edges and all the pipes/fuel filler and suspension ironmongery
2sav
tooSavvy is offline
post #142 of 150 Old 03-26-2019, 09:28 AM Thread Starter
Brit, in Bitz!
tooSavvy's Avatar
Quoted: 28 Post(s)
(Thread Starter)
UK
Yesterday I found the car to have a fuel leak.
It is the small bore tank return, from the mech pump.
Thismorning, I dropped in to A V Taylor, parts guys, 9AM...
3ft 3/16" flexi fuel pipe £uk3.50
2x 12MM screw clamps £uk1.50
...my MOT garage @9:15 >> 20min wait *+£uk10 contribution to the staff 'Xmas fund'!
£uk15 and home
Opinions were the old rubber hose was goosed.
*and no, not DIY job as I hate fuel up my armpit!!
2sav
tooSavvy is offline
post #143 of 150 Old 03-31-2019, 10:28 AM Thread Starter
Brit, in Bitz!
tooSavvy's Avatar
Quoted: 28 Post(s)
(Thread Starter)
UK
I have had a good think about my 'auto choke' and the rats nest of vac tubing that goes with it....
I have had years of manual choke type cars and I'm suspicious of the Auto mech - is it completely opening everytime? The car sometimes runs like a total pig - fluffing, stuttering and stalls at junctions... Quick restart and runs great = Suspicious!
I'm replacing the T-handle pull with a button type knob.
I will slice the threaded foot off and araldite 30mm Button onto T stub end
Plenty of pictures when I do the install. I have ordered 10x 3mm rubber caps, to blank off any vac ports.
2sav
tooSavvy is offline
post #144 of 150 Old 04-05-2019, 08:11 AM Thread Starter
Brit, in Bitz!
tooSavvy's Avatar
Quoted: 28 Post(s)
(Thread Starter)
UK
My pack of rubber caps has just turned up.
.... another item on my 'to do list' ticked off
2sav
tooSavvy is offline
post #145 of 150 Old 04-09-2019, 06:01 AM Thread Starter
Brit, in Bitz!
tooSavvy's Avatar
Quoted: 28 Post(s)
(Thread Starter)
UK
Yesterday I popped the trim off above the pedals, looking to pick up on the wiring to install my 'plip locking' kit. The loom is very densly wrapped as it exits the door boot, into footwell.... I couldn't see any way of picking out the 'locking wiring' easily.
Plan B :
I think I'm going to run 2 wires up into the actual rocker switch base >> these will take the signals down, through the door jamb boot, and then into the control box.
Bit of a faff BUT no loom chopping!
Do it all another day.... Bloominn freezing here, this time of year!
One of my sidelights went off - 5W T10 - luckily I found one in an old Ring bulb kit, from the bottom of my spares box. I had to twist the holder with an OE spanner, inserted behind the headlight void.. Horizontally.. as the space is bare big enough for a childs hand.
All sorted now
Anyone had long test of LED T10 type bulbs (NO..not jazzy BLUE ones)?
2sav
tooSavvy is offline
post #146 of 150 Old 04-09-2019, 01:20 PM
Toyota Collector
71Corolla's Avatar
Quoted: 2406 Post(s)
You mean long term test?
tooSavvy likes this.
2000 Lexus ES300 Millenium Edition
1990 Camry LE V6 Anniversary Edition 5-Speed
1990 Camry LE V6 WAGON
1987 Camry LE I4 5-Speed
71Corolla is online now
post #147 of 150 Old 04-09-2019, 02:40 PM Thread Starter
Brit, in Bitz!
tooSavvy's Avatar
Quoted: 28 Post(s)
(Thread Starter)
UK
Long term, yes.
I have seen LEDs on here, and a chassis set listed by code number.
Its more about sourcing... Quality vs Cheappo?
To be honest I'm quite taken by the use in the roof light.... Seems properly bright
2sav
tooSavvy is offline
post #148 of 150 Old 04-09-2019, 06:23 PM
Toyota Collector
71Corolla's Avatar
Long term, yes.
I've used these for about 6 months still going
https://www.ebay.com/itm/254006003011
This style T10 I use for the cluster and several other locations have not had one die yet. They come is most colours.
https://www.ebay.com/itm/392026178373
post #149 of 150 Old 05-14-2019, 02:00 AM Thread Starter
Brit, in Bitz!
tooSavvy's Avatar
Quoted: 28 Post(s)
(Thread Starter)
UK
My rear speakers have the 'clip retainer' for the trim cover as part of the cone chassis - like in vid above.
I'm looking to replace the speakers and will be cutting the cone part off, enabling me to retain the 'stock' speaker fabric cover.
RearSpeaker_below
RearSpeaker_above
Nothing ever straightforward with old skool Toyyos
Ahhhh..
Cone_chopped
2sav
tooSavvy is offline
post #150 of 150 Old 05-16-2019, 12:00 PM Thread Starter
Brit, in Bitz!
tooSavvy's Avatar
Quoted: 28 Post(s)
(Thread Starter)
UK
TS1672 6.5" 45W [inc Tweeter] 2x boxed, just arrived off Amazon locker....
https://images.app.goo.gl/NhvMr31GcZq1t21D6
Screwdriver out again....
2sav
tooSavvy is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corona Forum
User Tag List
Linear Mode Linear Mode
