83 corona stalling at idle problem Help! - Toyota Nation Forum : Toyota Car and Truck Forums
Corona Forum Specific discussion of the Toyota Corona
 1Likes
  • 1 Post By fourwd1
post #1 of 3 Old 02-17-2018, 06:08 AM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
Unhappy 83 corona stalling at idle problem Help!
Hi everyone!
First time posting, not sure if you guys can help but I am out of options!
I own a 1983 Toyota Corona CS with the Starfire 1X engine. Ever since I bought it I've had problems with what I am assuming is the carburettor. It fires up fine and idles fine (when it's cold) and even drives fine but as soon as its warmed up and I come up to an intersection or stop sign the rpm drops and will run very rough until it stalls once I've come to a stop. It was sitting for about 1.5-2 years and not started so I have cleared the fuel lines, replaced the fuel filter and checked the spark plugs. It does seem to backfire a lot once you let off the accelerator as well. I am assuming it's something to do with the carburettor but I am not sure it could be something else entirely. Any insight would be much appreciated! Thankyou!
I will attach a photo of the car for reference.
DavisT is offline
post #2 of 3 Old 02-17-2018, 01:56 PM
Brit, in Bitz!
tooSavvy's Avatar
Quoted: 28 Post(s)
UK
Hi m8
My 1.6 '91 4A-F does pretty much the same*... (But not all that often = live with it)
... Agreed likely carb
*no back pops
Back pops might indicate timing ..?
2sav
TOO MUCH POWER is not quite Enough!
tooSavvy is offline
post #3 of 3 Old 02-18-2018, 09:45 PM
Soylent Green sales
fourwd1's Avatar
Quoted: 560 Post(s)
If its carbed it would have a choke, so maybe the choke is not shutting off once it gets warm.
The timing would be the other thing to look at.
tooSavvy likes this.
_No THANKs necessary !
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline
The Following User Says Thank You to fourwd1 For This Useful Post:
tooSavvy (02-21-2018)
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corona Forum
Tags
1983 corona , help me , stalling when idling
User Tag List
Linear Mode Linear Mode
