Celica GEN IV missing AC fuses - Toyota Nation Forum : Toyota Car and Truck Forums
Corolla Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
post #1 of 6 Old 04-20-2019, 04:57 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
4th Generation Celica GEN IV missing AC fuses
Hello Everyone, i would like to know what i am missing here, this is my AC Box in my 88' Celica GEN IV, if possible send me pics, here's the example!!
(PS: The car's a 1.6 gti)
Any help would be appreciated, there's nothing in the manuals that i know of, at least!
Thank you
tieigo is offline
post #2 of 6 Old 04-20-2019, 05:46 PM
Toyota Collector
71Corolla's Avatar
Quoted: 2406 Post(s)
Without your VIN or chassis code I can only guess the exact model.
http://www.japan-parts.eu/toyota/eu/...relay-computer
2000 Lexus ES300 Millenium Edition
1990 Camry LE V6 Anniversary Edition 5-Speed
1990 Camry LE V6 WAGON
1987 Camry LE I4 5-Speed
71Corolla is offline
post #3 of 6 Old 04-20-2019, 06:45 PM
Senior TN Member
Quoted: 1808 Post(s)
Looks like your fuses are OK (except for missing spares).
Missing some relays.
AC-related components such as fuse, AC relay, AC amplifier, etc. are typically located on interior fusebox and under centre console.
DannoXYZ is offline
post #4 of 6 Old 04-20-2019, 07:21 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
what kind of relays am i missing? my ac is not working ..i will get the chassis number asap
tieigo is offline
post #5 of 6 Old 04-20-2019, 07:34 PM
Senior TN Member
AC not working can be any number of things:
- under/overfilled Freon
- leaking AC lines
- clogged evaporator or condenser
- bad pressure-switch
- bad AC clutch
- bad fan circuits
- broken wiring or connectors somewhere in AC circuits
- AC fuses
- AC relay
- AC amplifier
- AC dash switch
- etc.
Follow AC-troubleshooting procedure in FSM. Will be fastest and cheapest path as you measure each component (voltages, resistances, pressures, etc.) to quickly identify problem area and only replace specific parts that are out of spec. Rather than replacing entire AC system randomly until it finally works.
DannoXYZ is offline
post #6 of 6 Old 04-21-2019, 04:24 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Thank you mate...but i just want to know which relays am i missing.. which is the AC FAN 2, AC FAN 3, AC RELAY...and i cannot find a pic online, nor can i find them on ebay...
tieigo is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > Corolla Older Generations (1969-1987)
User Tag List
Linear Mode Linear Mode
