1993 Corolla Speedometer doesn't work - Toyota Nation Forum : Toyota Car and Truck Forums
Corolla 7th Generation (1993-1997) Specific discussion of the 7th generation
 34Likes
post #1 of 56 Old 10-21-2018, 10:41 PM Thread Starter
Quoted: 35 Post(s)
(Thread Starter)
Hey guys just want to know what could be the possible reasons why my speedometer on my 93 Corolla 1.8L 5speed manual isint working.
The rpms work, the odometer for miles works and everything works but the speedometer.
I checked fuses and they are all good. The only thing now that o think it could be is the speed sensor. Is that more likely what it is.
Also where is the speed sensor located and how hard would it be for me to change it myself.
Thank you
DM209 is offline
post #2 of 56 Old 10-21-2018, 11:12 PM
Quoted: 49 Post(s)
If the odometer is working but the speedometer is not, the speed sensor is working, the issue there would be the stepper motor that is connected to the speedo needle or the motor controller that controls the motor.
I found at least one video by Pine Hollow auto diagnostics detailing how to repair this on a 7th gen prism (or a corolla, its the same car just rebadged).. although the symptoms there and yours are vastly different.
You can also try using a speedometer cluster from same gen corollas from the junkyard. Find ones that have close to the same mileage as yours and test it and see if it works there.
redwing0001 is online now
post #3 of 56 Old 10-21-2018, 11:17 PM
Senior TN Member
Pete Suhman's Avatar
Quoted: 1387 Post(s)
These speedos are known to suffer from expired capacitors as well from what I've read here. Could that be the cause here? People have repaired them and posted about it here. Be glad you have the 5 speed, because speedo problems are known to cause havoc with the 4 speed OD automatic, which is computer-controlled. In some cases the speedo appears to work normally, but it fails to process, or send the signal from the Vehicle Speed Sensor, to the ECU or transmission controls.
2000 Corolla CE. 1ZZ-FE, 4 speed automatic
1988 Mustang GT 5.0. 5 speed, lots of mods
1977 F150. Big straight 6, 3 speed manual on column
Pete Suhman is offline
post #4 of 56 Old 10-23-2018, 03:10 PM
Senior TN Member
Quoted: 1833 Post(s)
Replace 2x $0.05 capacitors in speedometer, most likely 80% chance that'll fix it.
If doesn't fix, get new speedo from junkyard car.
Pete Suhman likes this.
DannoXYZ is offline
post #5 of 56 Old 10-24-2018, 10:08 AM
tajohns34's Avatar
Quoted: 27 Post(s)
Here is the thread I had for my tachometer. It is a very similar repair process on the capacitors.
https://www.toyotanation.com/forum/1...ch-93-a-2.html
tajohns34 is offline
post #6 of 56 Old 10-27-2018, 05:54 PM
Quoted: 0 Post(s)
I just bought a 94 dx with 4spd auto tranny yesterday. My dad took me to get it and folloowed me on our 95mile drive home, the engine ran perfect and tranny shifted correctly and smooth but, the speedo is way off(odo and trip odo are fine and matching mile markers). When my speedo said 20, he said we were doing 50, when it said 25-27, he said we were doing 60-65. Is this a VSS or speedo problem? I have another cluster in my wrecked 97 rolla. Thanks for any input.
Brian Furches is offline
post #7 of 56 Old 10-27-2018, 06:09 PM
Moderator
75aces's Avatar
Quoted: 987 Post(s)
If the other cluster does the same thing, then it's a speed sensor or speedo cable.
Brian Furches likes this.
In the garage,
9th Gen Corolla XRS
2012 Mazda 5
"If it ain't broke yet, it's probably still working like a Swiss time piece; until you open it up and all hell breaks loose"
75aces is online now
post #8 of 56 Old 10-27-2018, 07:20 PM Thread Starter
Quoted: 35 Post(s)
(Thread Starter)
I looked into it and it's not the speed sensor. I put another cluster from my other Corolla and it worked. I use both Corollas so I still need the other cluster.
Where can I take the cluster to get repaired. I disassembled it and have the gauge that marks the speed. Is it just a matter of replacing the capacitors on there??
Would and auto electric shop be able to replace the capacitors?
DM209 is offline
post #9 of 56 Old 10-27-2018, 11:19 PM
Senior TN Member
You could also go to the junkyard and grab another speedometer.
Capacitors look like little cylinders. They usually have plastic shrink-wrapped over them, but the top will be partially uncovered, and be a silver metal surface. A capacitor which is fried, or on its way there, will be bulging, usually at the top. If you look closely, you'll see an "X" scribed into the metal top. The X gives the top a place to tear open when/if the insides of the capacitor swell enough.
Chris94 and Apples555 like this.
post #10 of 56 Old 10-28-2018, 05:12 AM
Russian Bear
Haloruler64's Avatar
Quoted: 2097 Post(s)
If it's showing the wrong speed, you might be able to remove the needle and push it on when going the correct speed. So go 50 MPH, use your phone to verify this with any GPS speed app, then stick the needle on 50. Or 55, so you have that factory cushion.
DrZ likes this.
Haloruler64 is offline
post #11 of 56 Old 10-28-2018, 07:53 AM
Senior TN Member
Quoted: 869 Post(s)
To help illustrate Pete's comment, here are some pictures. These are from a tach, but I believe it's close enough. If you have a soldering iron, you can replace them yourself. make sure you buy the correct size, and they are installed the same way.
Chris94 is online now
The Following User Says Thank You to Chris94 For This Useful Post:
Pete Suhman (10-30-2018)
post #12 of 56 Old 10-30-2018, 12:16 AM Thread Starter
Quoted: 35 Post(s)
(Thread Starter)
Do you guys happen to what capacitors I need to change them myself??
DM209 is offline
post #13 of 56 Old 10-30-2018, 02:16 AM
Senior TN Member
I think tajohns34 might have a couple hundred extras...
DannoXYZ is offline
post #14 of 56 Old 10-30-2018, 11:36 AM
tajohns34's Avatar
Quoted: 27 Post(s)
I am not sure if they speedometer and the tachometer use the same capacitors or not. I did order 100 of them because it was cheaper than buying 2. I still have a ton of them but I would have to go digging since it has been over 3 years (July 26th 2015) since I ordered them. The ones I ordered aren't on amazon anymore but they are 10uf 25v for the tachometer.
These These
capacitors are about the same price,
The Following User Says Thank You to tajohns34 For This Useful Post:
post #15 of 56 Old 11-04-2018, 02:26 PM Thread Starter
Quoted: 35 Post(s)
(Thread Starter)
Hey guys so I changed out one of the capacitors that looked burnt out and it works now!
Thanks guys
I'm.not sure if there's a right way or wring way to put it but I ended up putting it backwards facing the other direction from the other ones and it still works good and marks the speed.
But what I did notice is that my airbag light is now always on and won't go off. Is it possible that putting the capacitor on the other side of circuit board could cause this or is it something else?
I don't think my airbag light was on before changing capacitor.
What would cause it to go.on
DM209 is offline
The Following User Says Thank You to DM209 For This Useful Post:
Pete Suhman (11-04-2018)
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > Corolla 7th Generation (1993-1997)
User Tag List
Linear Mode Linear Mode
