DIY - Vacuum Leak Detection - Toyota Nation Forum : Toyota Car and Truck Forums
Corolla 7th Generation (1993-1997) Specific discussion of the 7th generation
 7Likes
  • 3 Post By DannoXYZ
  • 1 Post By Hiro Protagonist
  • 2 Post By 94RollaDad
  • 1 Post By Haloruler64
post #1 of 8 Old 05-14-2019, 10:57 PM Thread Starter
Senior TN Member
Quoted: 1792 Post(s)
(Thread Starter)
Vacuum leaks are primary cause of lean-condition error codes. On MAP cars, vacuum leaks don't cause as much driveability issues as with MAF-sensing. However, it still results in stumbling, roller-coaster idle, poor throttle-response and loss of power. Many people suggest propane, carb-cleaner, water or smoke squirting to find leaks. But this is iffy method requiring lots of previous experience and skill in listening to idle tone. Also not as helpful when you've got multiple leaks.
I prefer pressure-test with soapy water as bubbles will appear on outside of engine instead of inside like other methods. I wrote up procedure with photos here: Dreaded P0171 Lean Condition. This vacuum-leak test works on any car, regardless of MAP or MAF sensing and gives 100% confirmation and location of leaks regardless of the user's skill and experience level. This test has found multiple leaks numerous times where other methods have failed.
DannoXYZ is offline
post #2 of 8 Old 05-14-2019, 10:59 PM Thread Starter
Senior TN Member
(Thread Starter)
heck, I'll just repost it here.
Originally Posted by DannoXYZ View Post
All this reliance on electronics makes people soft and not capable of critcal thinking and logic. They just want answers and be told what to do. When apocalypse comes, those who can't set traps for rabbit or kill with your bare hands are gonna starve to death! Zombies are gonna getcha even though they're slower than molasses! Come see our newest game in Orlando: http://nomadicvr.com
Now, i'm going to show you some survival skillz. Put down the xbox, or tablet or whatever gizmo is your temple of Truth and get hands-on dirty and touch your car physically and mechanically. Touch it, feel it vibrate, learn how it sounds when it's healthy and when it's sick. Pull and yank on hoses to see if idle note changes. Squirting with propane, carb-cleaner, water or even strategic aiming of pee can help, but you need to have some prior experience to recognize the subtle change in idle tone. And you need to know where to squirt.
Here's a sure-fire 100% way to find vacuum leaks with positive visual confirmation.
1. Plug your exhaust with banana, potatoe, cork, wet-rag or whatever gives 100% blockage
2. Make a plug fitting that replaces MAF on intake hose with compressor quick-fitting
3. Install your plug into intake hose which normally connects to outlet of MAF
4. Then set compressor to 3-5psi and connect to fitting
5. Squirt soapy water at every connection point from intake hose all the way to intake valves. Every seam, every joint, every clamp, etc. Pay particular attention to intake-manifold to head mating surface. Also injector tips.
In this case ironically, I had leak at external idle-valve. There's O-rings and seal inside case of idle-valve that needs replacing.
And another leak at throttle-body/TPS. There's O-rings on both sides of butterfly shaft that needs refreshing.
Also leak by dipstick tube. Looks like someone previously replaced O-ring with one that's too big. New correct O-ring with some sealant takes care of that!
Bubbles stay around leaks and gives you time to find them. Squirting propane isn't nearly as effective because you need to squirt at ALL leaks simultaneously for enough to get into engine to affect idle note. And you can't see propane and see exactly where it was sucked in. Bubbles are easier!!!
DannoXYZ is offline
The Following 2 Users Say Thank You to DannoXYZ For This Useful Post:
94RollaDad (05-16-2019), Pete Suhman (05-14-2019)
post #3 of 8 Old 05-15-2019, 12:20 AM
Token Aussie
Hiro Protagonist's Avatar
Quoted: 555 Post(s)
Where do you recommend aiming the pee-stream?
Pete Suhman likes this.
Charlene - 1998 AE102 Conquest: Reborn
Billie KE55, Rosie AE82, Charlie ST162, Lexi JZZ30, Kevin SXV20: GONE
Daphne - 2018 ZRE182 Sport: First new car EVAR!
Hiro Protagonist is offline
post #4 of 8 Old 05-15-2019, 05:38 PM Thread Starter
Senior TN Member
(Thread Starter)
DannoXYZ is offline
post #5 of 8 Old 05-16-2019, 08:45 AM
Senior TN Member
94RollaDad's Avatar
Quoted: 806 Post(s)
@Haloruler64 - add to DIY thread?
Chris94 and Haloruler64 like this.
94RollaDad is offline
post #6 of 8 Old 05-17-2019, 11:38 AM
Senior TN Member
Pete Suhman's Avatar
Quoted: 1301 Post(s)
Ask a newer diesel!
2000 Corolla CE. 1ZZ-FE, 4 speed automatic
1988 Mustang GT 5.0. 5 speed, lots of mods
1977 F150. Big straight 6, 3 speed manual on column
Pete Suhman is online now
post #7 of 8 Old 05-17-2019, 09:16 PM
Token Aussie
Quoted: 555 Post(s)
Originally Posted by Pete Suhman View Post
Ask a newer diesel!
Funny how you never see blue on those urine colour/dehydration charts...
Sent from my SM-G970F using Tapatalk
post #8 of 8 Old 05-18-2019, 04:18 AM
Russian Bear
Haloruler64's Avatar
Quoted: 2073 Post(s)
Good call!
Chris94 likes this.
Haloruler64 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > Corolla 7th Generation (1993-1997)
User Tag List
Linear Mode Linear Mode
