Please help me with my door - Toyota Nation Forum : Toyota Car and Truck Forums
Corolla 7th Generation (1993-1997) Specific discussion of the 7th generation
 13Likes
post #1 of 71 Old 06-18-2019, 07:28 PM Thread Starter
GHT
Quoted: 52 Post(s)
(Thread Starter)
Back in Chicago, some kid snapped my door handle or something. Not sure how it happened but a kid did it. Now the door won't open.. please help me get it open, and replace the handle ! Then I dont have to think about it anymore.
When I first got the car, the passenger side front one got replaced too.
I was going to put this in "General Chat" but thought it could be an issue, hopefully this does not happen to someone else, with the door handles.
https://youtu.be/kSrhUBOyrNs
GHT is offline
post #2 of 71 Old 06-18-2019, 07:52 PM
Senior TN Member
Quoted: 894 Post(s)
Check out the DIY section for some good info (although some of the threads no longer have pictures). Here's how to remove the inside and outside handles. This is for the front, but the rear is very close to the same. Use a small flat head screwdriver to undo the clips holding the rod to the inside door handle. The window crank has a c-clip securing it. Push the door card towards the door frame and you can get it either with a hooked tool or a screw driver.
https://www.toyotanation.com/forum/1...a-93-97-a.html
Chris94 is online now
post #3 of 71 Old 06-18-2019, 08:03 PM Thread Starter
GHT
Quoted: 52 Post(s)
(Thread Starter)
There is a particular "trick" to get the inside handle off without snapping/breaking it further? I think this is the original one.
When it is off, I can try pulling really really hard on the rod to get it to open like this guy with his Acura did...
GHT is offline
post #4 of 71 Old 06-18-2019, 08:09 PM
Senior TN Member
Quoted: 894 Post(s)
Not that I am aware of. You've already removed the screw, slid the handle slightly forward and now it's only help by the rod and clip. Don't attempt to yank the rod or you risk damaging it, or breaking more clips that hold it. Look carefully at the clip and how it's secured to the rod and you will see it's a U shaped plastic clip, but the U is turned on it's side. The end of the rod is also bent and goes down into that clip. You want to use a small flat head to press against the "top" of the U to get it to pop off the rod, then it will rotate out of the way and the rod can be pulled out of the clip.
Apples555 and Pete Suhman like this.
post #5 of 71 Old 06-19-2019, 08:00 AM Thread Starter
GHT
Quoted: 52 Post(s)
(Thread Starter)
I am not sure how I did it, but I can look into the part of the door between the door and the frame. By looking at the other door, it looks like the child safety lock is indeed on on the side that will not open.
I am trying to move it with a long screwdriver.. should I pick up a Slim Jim too, or continue trying to get the child safety lock off with a long screwdriver? It seems to almost want to come off, then pop back.
GHT is offline
post #6 of 71 Old 06-19-2019, 02:23 PM
DrZ
Senior TN Member
Quoted: 690 Post(s)
With the child safety lock on you should still be able to open it with the outside handle, but that is broken, but if you could pull the rod that is attached (or should be attached) to the outer door handle then maybe it will open. Maybe you could reach something down there past the window trim.
stvotw and Pete Suhman like this.
1990 Corolla DX sedan, 4A-FE, 3-speed auto A131L
233,000 miles and counting...
1997 Corolla DX sedan, 7A-FE, 4-speed auto A245E
214,000+ miles
DrZ is offline
post #7 of 71 Old 06-19-2019, 04:35 PM
Senior TN Member
Quoted: 894 Post(s)
I missed the part about the door being stuck shut. I tried searching threads for a solution but came up empty.
post #8 of 71 Old 06-19-2019, 10:47 PM
Senior TN Member
Pete Suhman's Avatar
Quoted: 1486 Post(s)
Do rear latches F up the way the front ones do, with the spring breaking and making it impossible to unlock and hence open the door?
2000 Corolla CE Automatic
2005 Mustang GT Premium coupe, 5 speed
1988 Mustang GT 5.0. 5 speed, lots of mods
1977 F150 Straight 6, 3 on the tree
Pete Suhman is offline
post #9 of 71 Old 06-22-2019, 10:07 AM Thread Starter
GHT
Quoted: 52 Post(s)
(Thread Starter)
This is where I am presently at. This shows the length of my tool etc.
Where am I aiming, what am I looking for, please be literal, been years since I used one?
GHT is offline
post #10 of 71 Old 06-22-2019, 11:05 AM Thread Starter
GHT
Quoted: 52 Post(s)
(Thread Starter)
Image re-try
GHT is offline
post #11 of 71 Old 06-22-2019, 01:47 PM
Senior TN Member
Quoted: 1866 Post(s)
Do you know where to pull?
Take apart other door panel and look at how mechanism works when you pull on door handle. You'll find that slim-jims won't fit in latch mechanism where it's needed. You might just be able to unlock door.. Better to make custom puller with coat hanger as you'll need slight C shape to it. Also need a 1/2" 90-degree "finger" bent at end. Mark on coat-hanger depth needed. Practice unlatching the working side so you can do it in 5-seconds without breaking anything. Then go to blind side.
Yeah, I used to go to school with kids that broke into cars to steal alarm system.
Chris94 likes this.
DannoXYZ is offline
post #12 of 71 Old 06-22-2019, 04:04 PM Thread Starter
GHT
Quoted: 52 Post(s)
(Thread Starter)
Ahhhhhh. So.. my Slim Jim wont work?
If not, let me look to see if I have any wire hangers... this is very helpful. If i can pop the door... I'll take pics when I get home from work. I also ordered the outside door handle.
GHT is offline
post #13 of 71 Old 06-22-2019, 06:02 PM Thread Starter
GHT
Quoted: 52 Post(s)
(Thread Starter)
I totally do not know where to put the slim Jim down. Also, previous post makes it seem like that may not help.
Is my door coming apart no matter what on the inside to get the outside handle off?
GHT is offline
post #14 of 71 Old 06-22-2019, 09:01 PM
Senior TN Member
Yes. To get to the exterior handle, you need to remove the door card/interior panel. Maybe you can get the one off of the stuck door, intact, if you remove the back seat?
post #15 of 71 Old 06-22-2019, 09:07 PM Thread Starter
GHT
Quoted: 52 Post(s)
(Thread Starter)
I actually recently watched a video where a Youtuber with an almost exact issue did all that work (on a different car, an Acura TL, but exact same issue) and was not able to get any more access to the door and did so all for naught...
He says he finally got it open by pulling so hard on the rod he thought he was going to break it.
I dont know.
I can get some shots on how the door looks at the latch.. but, if it is all coming off anyways.. alright then. I just dont want to break anything not broken. That inside handle is ON THERE! I see where it would break.. Maybe some penetrating lube?
GHT is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > Corolla 7th Generation (1993-1997)
User Tag List
Linear Mode Linear Mode
