Erease code over and over again - Toyota Nation Forum : Toyota Car and Truck Forums
Corolla 8th Generation (1998-2002) Specific discussion of the 8th generation
 1Likes
  • 1 Post By topguncam3888
post #1 of 10 Old 05-22-2019, 12:07 PM Thread Starter
Quoted: 4 Post(s)
(Thread Starter)
Hello All,
I just want to ask if any of you have one of this "check engine" codes and in order to "turn off" the light have you use a scan tool and erase it every time comes on?
That's my story: 2001 Corolla, love it but like a year ago came with the well known P0420 DTC, so I changed the catalytic converter BUT I made the mistake to put an aftermarket one. It works fine for like 6 months , but then eventually light came back. At first, after continue driving the car and change to a next Gasoline level (mechanic recommend that) incredibly the light went off, but again, after a month or so, light back, so I bought a scan and since then, every time light comes on I erase the code with the scan . As a note always the same code comes on, but my question (maybe a silly one) is if this frequent "erasing" of this same code can create any problem on my car? I personally don't think so, but like to ask people with more experience. Thank you in advance for your feedback!
Pedro13 is offline
post #2 of 10 Old 05-22-2019, 12:15 PM
TN user
G_gazoo's Avatar
Quoted: 369 Post(s)
Short awnser no. Things to consider check the condition of your pipes. Look for holes or noise these can cause that code. Aftermarket o2 sensors will cause loads of issues so ensure they are denso (ngk). A good scan tool can check the status of your o2 sensor it's the rear post cat that trips p0420 so ensure it's working. If everything checks out then Google non fouler and do it.
If any part of this was useful please click the thanks button to let me know it worked
G_gazoo is offline
The Following User Says Thank You to G_gazoo For This Useful Post:
Pedro13 (05-22-2019)
post #3 of 10 Old 05-22-2019, 12:28 PM
Quoted: 179 Post(s)
Yup, faulty O2 sensors can trigger p0420. Make sure it's not the cat:
doctorbee is offline
The Following User Says Thank You to doctorbee For This Useful Post:
post #4 of 10 Old 05-22-2019, 01:16 PM
Quoted: 0 Post(s)
I donít have a cat on my 1998 Corolla and every time my check engine light comes on I just erase it. It only every throws code P0420. I havenít had any issue and Iíve been doing this since I got it straight piped in December.
LukeGirard is online now
post #5 of 10 Old 05-22-2019, 01:23 PM
Quoted: 179 Post(s)
Well being catless will definitely cause p0420.
You may have just had a faulty upstream o2 sensor and killed two cats with it. You need to ensure proper operation of the upstream o2 sensor.
post #6 of 10 Old 05-22-2019, 01:45 PM
topguncam3888's Avatar
Quoted: 29 Post(s)
For the cost ($5), I'd throw a spark plug nonfouler on the post-cat O2 sensor, unless you live in Cali or some other commie region. Doing this eliminated my recurring P0420. The action of clearing the code constantly in itself won't harm anything.
topguncam3888 is online now
post #7 of 10 Old 05-22-2019, 04:32 PM
Quoted: 179 Post(s)
You should always make sure your upstream o2 sensor is okay before doing the defouler mod. Otherwise you'll run rich all the time, have low MPG, and can kill the cat.
post #8 of 10 Old 05-22-2019, 05:55 PM
Quoted: 29 Post(s)
If the upstream was bad wouldn't you be doing that anyways?
funman1 likes this.
post #9 of 10 Old 05-23-2019, 12:12 PM Thread Starter
Quoted: 4 Post(s)
(Thread Starter)
Thank you all for your good comments and suggestions. I forgot on my original mail mention that I changed the O2 sensor too!, but again, using an aftermarket one... My MPG is very good, in fact is one of the reasons I love this car!. I personally don't think car is running rich.
Based in all this facts, I will go to install the non-fouler and put this issue on bed... Thank you all again for your help!
Pedro13 is offline
post #10 of 10 Old 05-24-2019, 09:27 PM
TN user
G_gazoo's Avatar
Quoted: 369 Post(s)
Look up what you installed. If it is not a denso or ngk o2 sensor it WILL cause further issues. Just search Bosch on this forum and read countless posts about it from dozens of different owners.
G_gazoo is offline
Pedro13 (05-25-2019)
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > Corolla 8th Generation (1998-2002)
User Tag List
Linear Mode Linear Mode
