2006 Matrix code P0420 - Toyota Nation Forum : Toyota Car and Truck Forums
Corolla 9th Gen/1st Gen Matrix (2003-2008) 9th generation Corolla and 1st generation Matrix discussion.
 1Likes
  • 1 Post By core2kid
post #1 of 6 Old 10-19-2016, 12:52 PM Thread Starter
Quoted: 191 Post(s)
(Thread Starter)
Originally Posted by Warped View Post
I scanned my Matrix a few days ago and got code P0420. It said that the forward catalytic converter is bad. I priced one at Advance, Autozone and O'Reilly's and they are in the neighborhood of $375 for a direct fit replacement. I looked on eBay and they are somewhat cheaper and supposedly also direct fit. The car runs fine as it is with 205k on it. I reset the code, changed the plugs out for Bosch Iridiums because it had Denso platinums in it and the code hasn't come back, yet. Any suggestions would be greatly appreciated!
The 1ZZ on the Matrix likes Denso Iridium plugs, not platinum. If you have the 2ZZ, you definitely don't want to use platinum.
Every P0420 I've seen is from a bad downstream oxygen sensor, not a catalytic converter. If you haven't seen the code come back though, ignore it until it does.
Warped likes this.
1985 Celica GT-S Convertible 2.4L 22RE
1999 Corolla LE Rebuilt 1.8L 1ZZFE - Gave to my cousin
2005 Celica GT Tsunami Edition 1.8L 1ZZFE
core2kid is offline
post #2 of 6 Old 10-19-2016, 01:03 PM
cj1
Senior TN Member
Quoted: 358 Post(s)
Unless plugs were really bad, changing them may not be the fix for the error code.
At 205 k cat losing its efficiency is probably correct.
Rockauto.com has CARB cat for $300.00.
For a cheap fix may try a O2 spacer adapter extender that could hold off the error code if/ when it returns.
Are engine parameters such as fuel trims, O2 sensors within spec. No other error codes?
Oil consumption, exhaust leaks ?
cj1 is offline
post #3 of 6 Old 10-19-2016, 01:53 PM Thread Starter
Quoted: 191 Post(s)
(Thread Starter)
I wouldn't jump on the cat. Look at the 8th Gen Corolla/Matrix forums. A lot of us have over 250k on our original cats, our engines also burned oil.
core2kid is offline
post #4 of 6 Old 10-23-2016, 12:16 AM
Quoted: 33 Post(s)
Rock Auto has a California-legal CARB cat for just under $300, and they always have a promo code for 5% off.
bgmbgmbgm is offline
post #5 of 6 Old 10-27-2016, 12:01 PM
Senior TN Member
Quoted: 205 Post(s)
I had 0420 several times on Corolla. Still on the same cat, same sensor, same canister. Just a matter of cleaning... Its been 2 years since last cleaning and no code yet.
Edit: Make that more than 3. Last renewal, we did not have it though I did the seafoam cleaning. We have a renewal next week so I am doing another seafoam cleaning treatment. I normally do one annually.
Also on our honda, after a 0420 that came back couple times, I had installed a spacer. It has been 5+ yrs now since and no code. I had posted that several times on subforums also.
2002 Avalon XL 3.0L mcx20L 1MZFE
2004 Camry LE 2.4L ATM 2AZFE ACV30L-CEPNKA 4FC
2000 Corolla CE1 4 Cyl 1.8L EFI ATM 1ZZFE ZZE110L-DEPDKA SED 4FC
surgeon0 is offline
post #6 of 6 Old 05-28-2017, 12:23 PM
Camry_owner
Quoted: 20 Post(s)
Gen6
Hi, could you please tell me what kind of chemical I use or how do I clean the O2 sensors/catalytic converter.I am going to physically remove the O2 sensors and catalytic conveter.Want to know if anybody has any idea how to cleam them. Kindly let me know.
inchica2009 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > Corolla 9th Gen/1st Gen Matrix (2003-2008)
User Tag List
Linear Mode Linear Mode
