Crazy issue with central locks- 2003 Matrix - Toyota Nation Forum : Toyota Car and Truck Forums
Corolla 9th Gen/1st Gen Matrix (2003-2008) 9th generation Corolla and 1st generation Matrix discussion.
post #1 of 4 Old 06-11-2019, 10:58 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Hello all,
I have a crazy problem with central locks that started happening after I changed my drivers door (because of rust). Since then, I have replaced the new doors harness with my original door harness and now most of the issues have gone away- but still some remain.
1. Power lock/unlock toggle button does not work. Hatch button inside car does not work.
2. Remote button only unlocks driver door. Does not lock any doors.
3. If any door (including hatch) is open, the rear window hatch keeps making a clicking noise- as if trying to open.
4. These issues prevail, even if I completely disconnect all door harnesses from the car.
5. Door fuse is good. All other fuses are also good.
Here are the things I tried:
1. Tried resetting the BCM by disconnecting both battery terminals for more than 30 mins
2. Changed the driver door lock and actuator back to the original
3. Tried to isolate the central locking toggle switch
I'm running out of ideas. Any help would be appreciated.
Ajit Pharne is offline
post #2 of 4 Old 06-11-2019, 01:28 PM
Moderator
75aces's Avatar
Quoted: 987 Post(s)
Was this the case before you replaced the door?
In the garage,
9th Gen Corolla XRS
2012 Mazda 5
"If it ain't broke yet, it's probably still working like a Swiss time piece; until you open it up and all hell breaks loose"
75aces is online now
post #3 of 4 Old 06-12-2019, 02:19 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Everything worked perfect before the door was replaced.
Can anyone tell me the location of the Body module on the car and what it takes to replace it?
post #4 of 4 Old 06-12-2019, 11:11 PM
Moderator
75aces's Avatar
Quoted: 987 Post(s)
Double check the connectors and wiring for damage. Not likely, but it's a start.
May have missed something.
In the garage,
9th Gen Corolla XRS
2012 Mazda 5
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > Corolla 9th Gen/1st Gen Matrix (2003-2008)
User Tag List
Linear Mode Linear Mode
