Parts to cover when cleaning the engine bay - Toyota Nation Forum : Toyota Car and Truck Forums
Corolla 9th Gen/1st Gen Matrix (2003-2008) 9th generation Corolla and 1st generation Matrix discussion.
 1Likes
  • 1 Post By mark888
post #1 of 5 Old 06-16-2019, 08:23 PM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
Hey there. I'm planning to clean and detail my engine bay soon so I wanna know which parts to cover so they won't be damaged by water and other chemicals. I know that I should take the battery out and cover the alternator, but are there other parts that I also need to cover? My car is a 2005 Corolla LE. Thank you.
KiesAgent is offline
post #2 of 5 Old 06-16-2019, 08:27 PM
Quoted: 43 Post(s)
Not much else....the alternator is a must do.
watched a guy spray my entire engine bay (with alt covered of course) with hot purple and then just hose it off. Really good cleaner.......good luck
2006 Corolla
2008 Limited Rav4 I4
2017 Camry
Kevin
kevcules46 is offline
The Following User Says Thank You to kevcules46 For This Useful Post:
KiesAgent (06-16-2019)
post #3 of 5 Old 06-16-2019, 09:05 PM
Senior TN Member
cb91710's Avatar
Quoted: 1650 Post(s)
Ever hear of rain?
Seriously, the only thing to be concerned about is getting water down into the spark plug tubes and into electrical connectors.
Do *NOT* use any kind of pressure washer under the hood. It will blast water through seals that are perfectly adequate for rain and splashes, and it will also bend the fins on the radiator.
Cover the alternator and make sure the intake and fuse box cover are secure.
Gentle spray from a garden hose.
-- Rich
cb91710 is online now
The Following User Says Thank You to cb91710 For This Useful Post:
post #4 of 5 Old 06-17-2019, 12:31 AM
Toyota Fanatic
hardtopte72's Avatar
Quoted: 2089 Post(s)
I regularly hose clean and paper towel wipe the engines on all my cars. This includes the following:
2005 Corolla - Cover over valve cover
2005 Sequoia - Cover over throttle body
2008 LS460 - Nearly entire engine bay covered
I dont remove any covers or cover any components on any of them.
With that said, I don't try to wash the alternator, belts, or coil packs directly. I then wipe all the flat plastic areas and large hoses down to dry them off.
My Toyota List:
1982 Corolla SR-5 (Shell Right Now)
2005 Corolla CE 1ZZFE M/T
2005 Sequoia Limited 2UZFE A/T
2008 LS460 SWB RWD 1URFSE A/T
If I helped out in any way please hit the Thanks button under my post.
hardtopte72 is offline
post #5 of 5 Old 06-17-2019, 12:36 AM
Senior TN Member
Quoted: 781 Post(s)
There is a really good YouTube video on this subject.
Here is one (but there are others):
cb91710 likes this.
mark888 is online now
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > Corolla 9th Gen/1st Gen Matrix (2003-2008)
User Tag List
Linear Mode Linear Mode
