91 Wagon Condenser fan plug is shorted - Toyota Nation Forum : Toyota Car and Truck Forums
Corolla 6th Generation (1988-1992) Specific discussion of the AE92
post #1 of 8 Old 05-15-2019, 09:19 AM Thread Starter
Quoted: 5 Post(s)
(Thread Starter)
Hello!
I recently fixed my fan speed selector switch thanks to Toyotanation! I was able to pick out the burnt plastic and pull up the metal part that needed to make contact with the selector and it works now!
My next problem is that the condenser fan is shorted, and the wiring harness plug that goes into the condenser fan ALSO has continuity! I'm no tech, but I think that means I have a short somewhere down the wiring harness. Any tips on how to locate the short? I also measured for continuity at the Condenser fan relay plug, and I think I was getting continuity from more places than it should have.
I'm starting to think that the burnt out fan speed selector, and the shorted condenser fan and fan plug might be related. If anyone has any advice on the matter, please let me know! this is my work vehicle and I can't afford to take it to a shop, so I have to do it all myself.
Thanks!
1991 Corolla Wagon DX 5 speed
126,000 miles
from Puerto Rico
Juan91wagon is offline
post #2 of 8 Old 05-15-2019, 10:04 AM
Senior TN Member
Quoted: 209 Post(s)
Hot side of condenser fan comes from 30 Amp fusibke link underhood fuse block. Ground side comes from condenser fan relay number 2. Pull relay and see if problem goes away.
chuckoff is offline
post #3 of 8 Old 05-16-2019, 10:10 AM
DrZ
Senior TN Member
Quoted: 653 Post(s)
Interior blower fan and condenser fan are completely different circuits.
You're going to have to say where you placed the 2 probes to measure continuity for us to say whether it's normal or not.
1990 Corolla DX sedan, 4A-FE, 3-speed auto A131L
233,000 miles and counting...
1997 Corolla DX sedan, 7A-FE, 4-speed auto A245E
213,000+ miles
DrZ is online now
post #4 of 8 Old 05-16-2019, 05:20 PM Thread Starter
Quoted: 5 Post(s)
(Thread Starter)
HEY! Thanks a lot! I just tested after removing the relay you mentioned and there was no continuity between the prongs on the harness plug. I could put the relay back and immediately get continuity.
Do I need to replace that relay?
Thanks again!
126,000 miles
from Puerto Rico
post #5 of 8 Old 05-16-2019, 05:52 PM
DrZ
Senior TN Member
Quoted: 653 Post(s)
If you have a short then which fuse is blow?
213,000+ miles
DrZ is online now
post #6 of 8 Old 05-16-2019, 06:12 PM Thread Starter
Quoted: 5 Post(s)
(Thread Starter)
THE 30 amp fuse in the under hood fuse box looks funky but had continuity. BUT, the plug where that 30 amp fuse plugs into ALSO had continuity among the prongs. tHat canít be OK.
File Type: jpg FE4827D7-CD76-42F8-81DF-5F860C544228.jpg (709.3 KB, 6 views)
126,000 miles
from Puerto Rico
post #7 of 8 Old 05-16-2019, 06:30 PM
DrZ
Senior TN Member
Quoted: 653 Post(s)
Did you disconnect the negative battery terminal before doing these continuity tests? You can't use an ohmmeter or continuity setting on a circuit with voltage.
The radiator and condenser fans are controlled by 3 relays and the circuit is a bit complex. Without looking at a wiring diagram while you're doing these tests it's hard to say where there should or shouldn't be continuity or voltage.
213,000+ miles
DrZ is online now
post #8 of 8 Old 05-19-2019, 06:59 AM
Senior TN Member
Quoted: 209 Post(s)
Correct. Need to check wiring for a short to ground on the hot side. High resistance could also be the reason the plug melted
chuckoff is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > Corolla 6th Generation (1988-1992)
User Tag List
Linear Mode Linear Mode
