2009 Corolla - Excessive Oil Consumption? - Toyota Nation Forum : Toyota Car and Truck Forums
Corolla 10th Gen/2nd Gen Matrix (2009-2013) A place to discuss all things 10th Gen Corolla and 2nd Gen Matrix.
post #1 of 10 Old 04-15-2019, 07:54 AM Thread Starter
Quoted: 2 Post(s)
(Thread Starter)
I am looking for a 3rd family vehicle for the kids to drive. The Corolla is on the list. Budget dictates it will be somewhere around a 2008, 2009, or 2010. Over the weekend, I saw an article that the 2009 Corolla (among other Toyotas) was part of a class action lawsuit based upon excessive oil consumption. Two questions:
1) Have there been problems with 2009 Corollas (i.e., should I not look at / buy a used one)?
2) Why do the 2010 Corollas not have a problem too since it's the same engine?
paulmlac is offline
post #2 of 10 Old 04-15-2019, 10:00 AM
THEWISEONE's Avatar
Quoted: 213 Post(s)
The 2010 and up Corollas are fine.Avoid the 2009 because of defective pistons and rings.
THEWISEONE is offline
post #3 of 10 Old 04-15-2019, 11:16 PM
Corolla Freak
SupremeCorolla451's Avatar
Quoted: 859 Post(s)
The excessive oil consumption is actually on the 10th gen Corolla XRS's with the 2.4L 2AZ engine. The 1.8L engines did not have the oil consumption problems. What caused the oil consumption problem on the 2.4L engine were defective piston rings and if you had a XRS with oil burning issues, you could bring it to a Toyota dealer and they will replace the engine.
The XRS was available in the U.S. in 2009 and 2010 so buying either a 2009 XRS or 2010 XRS, you might run into the oil consumption issue. Since you want to get a family car, I'd recommend getting either a 2009 or 2010 LE or S as those have the the 1.8L engine and they are better on gas compared to the 2.4L. 2009 Corolla's had minor first year problems such as bad water pumps (an updated one was made and most 2009's by now should have them installed), startup rattle, etc. but nothing too concerning. Again, for your needs, I'd recommend looking at a 2009 or 2010 Corolla LE or S. You could also look at a L (base trim) if you want to save some money.
2011 Corolla CE (5 Speed Manual)
SupremeCorolla451 is offline
post #4 of 10 Old 04-15-2019, 11:19 PM
Senior TN Member
Vangm25's Avatar
Quoted: 557 Post(s)
The 2006/2007 - 2009 2.4L 2AZ-FE oil burning engines are a known issue and may be repaired if under warranty.
Help those who accept it, troll those who shun it
Vangm25 is offline
post #5 of 10 Old 04-15-2019, 11:38 PM
Quoted: 33 Post(s)
2.4 was the motor that drank oil, my 1.8 in my 2011 hardly uses any, even after 7500 miles of highway driving, I barely used a pint of oil, which Iím totally fine with that (full synthetic also btw) a little oil usage is fine in my books
Skidoorevxp is online now
post #6 of 10 Old 04-16-2019, 07:46 AM
stvotw's Avatar
Quoted: 513 Post(s)
My 1.8 uses about a quart of oil every 2k mikes.
stvotw is offline
post #7 of 10 Old 04-16-2019, 08:37 AM Thread Starter
Quoted: 2 Post(s)
(Thread Starter)
OP Here -
Thanks very much for the great info!!! We keep cars for awhile so a little extra effort to find a "good" one is time well spent. We are also looking for a car with stability control. So, all that said, here's my hit list.
2008: 1.8 L engine - stability control optional on S & LE with automatic & ABS
2009: 1.8 L engine (i.e., no XRS) - stability control optional across line (standard on XRS but that's off the table given the oil consumption issue)
2010: 1.8 L engine (i.e., no XRS) - stability control standard
Perhaps a bit of a needle in a haystack but do-able.
Thanks again!
paulmlac is offline
post #8 of 10 Old 04-16-2019, 08:59 AM
Quoted: 33 Post(s)
The 10th gen is a bit slower, but better in my opinion, the 1zz in the 9th had its oil burning issues that was supposedly fixed in 03/04, but the 10th only had a very new model issues that were fixed under tsbís from what I remember. Either motor is good for well over 300k with basic scheduled maintenance
post #9 of 10 Old 04-16-2019, 04:08 PM
THEWISEONE's Avatar
Quoted: 213 Post(s)
Thats good to know! Luckily, I bought a 2012 with the 1.8L engine.
post #10 of 10 Old 04-18-2019, 05:02 PM
Quoted: 1 Post(s)
2009 owner here
i bought a 09 around 1.5 years ago. You are right about the oil burning issue but it is nowhere as bad as the 07-09 camry. I experienced this issue with 0w-20 synthetic oil. Once i moved to 5w-20 conventional this issue is hard to notice. Maybe it does burn a little but i can't tell the difference on a dipstick.
I assume you are aware of other issues.
1)rattle at start problem (was frequent when i bought it but now i rarely hear it) maybe a thicker oil keeps the vvt gear lubricated.
2)water pump going out (haven't experienced since bought ie last 25k miles)
3)Electronic power steering requires constant adjustment and wanders often. Mine is becoming incresingly stiff as well.
Other than that what a great reliable car. Other than maintenance have only changed two light bulbs in the last 25k miles.
murtaza is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > Corolla 10th Gen/2nd Gen Matrix (2009-2013)
User Tag List
Linear Mode Linear Mode
