Requesting AC Tech Specs for 2010 Corolla S 1.8L - Toyota Nation Forum : Toyota Car and Truck Forums
Corolla 10th Gen/2nd Gen Matrix (2009-2013) A place to discuss all things 10th Gen Corolla and 2nd Gen Matrix.
post #1 of 3 Old 05-21-2019, 06:00 PM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
I just need the Refrigerant capacity of the AC system on the 2010 Corolla S 1.8L.
I also need help locating the expansion valve as I intend on replacing it too (10-11yo)
Does anyone have a link or know where I can find the info. I am no where near the car so specs before I get to the car would be greatly appreciated.
eidairman1 is offline
post #2 of 3 Old 05-21-2019, 06:42 PM
Senior TN Member
sdspeed's Avatar
Quoted: 335 Post(s)
17.28 oz. of 134a. The expansion valve is usually next to the evaporator in the cabin. Can't tell from this diagram since some cars did have it in the engine bay and the sensing tube would then run thru the firewall into the evaporator. Is there any symptoms that indicate it would be bad? Like the system is pulling a vacuum while running. Normally not a routine maintenance item.
sdspeed is offline
post #3 of 3 Old 05-21-2019, 08:33 PM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
Thank you, the car is 10-11 years old and I am considering doing this as an preventive maintenance measure. It recently stopped cooling.
That Pictorial PDF file, i ptesume it is item #4?
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > Corolla 10th Gen/2nd Gen Matrix (2009-2013)
User Tag List
Linear Mode Linear Mode
