2009 corolla vibrates at stop light - Toyota Nation Forum : Toyota Car and Truck Forums
Corolla 10th Gen/2nd Gen Matrix (2009-2013) A place to discuss all things 10th Gen Corolla and 2nd Gen Matrix.
 2Likes
  • 1 Post By Kamronp55
  • 1 Post By Cuban Legend
post #1 of 11 Old 07-09-2019, 08:23 AM Thread Starter
Quoted: 2 Post(s)
(Thread Starter)
Hi i have a 2009 corolla le with 220000 miles I have had a vibration issue since November ive taken to multiple mechanics. I have changed a engine mount new spark plugs throttle body clean engine flush mass air flow sensor air filter oil change and a few others recently took to toyota dealership for full diagnosis and they couldn't say what was wrong since no check engine light. They suggested fuel clea... Yesterday i noticed when my headlights are on they car does not vibrate ...any ideas on what could be wrong
Corolla trd likes this.
Kamronp55 is offline
post #2 of 11 Old 07-09-2019, 08:33 AM
Corolla Fan
Cuban Legend's Avatar
Quoted: 231 Post(s)
check your battery, alternator and serpentine belt.. they all work in unison to maintain your idle smooth as your ECU sends the data in from the MAF readings. if any 3 of those things are off, then it will cause a rough idle.
I had a bad idle at a stop but once i replaced my battery i was all good, another time my serpentine belt was bad causing a similar issue and replacing it helped me as well, also- if any 1 of those 3 is bad, it will negatively affect the other 2 as they all work together.
if you haven't run seafoam through the car's throttle body and fuel system together, DO IT! (SS14 Throttle Body Cleaner + SF16 Fuel Injector Cleaner Additive) it'll help clean your carbon buildup, and the seafoam fuel cleaner will help with cleaning fuel injectors. also, ensure your fuel injectors are clean, there's vidoes on youtube on how to clean them, they may be gunked up and need a cleaning, or you may need to replace them.
Cuban Legend is offline
post #3 of 11 Old 07-09-2019, 08:39 AM
stvotw's Avatar
Quoted: 715 Post(s)
Mine has a slight low idle vibration as well. I think it's normal. Idle speed is around 620 rpm. Nothing I have done changes it.
When headlights are on it creates a draw on the electrical system which requires higher rpm.
stvotw is online now
post #4 of 11 Old 07-09-2019, 09:01 AM Thread Starter
Quoted: 2 Post(s)
(Thread Starter)
Thank you both when toyota did the diagnostic they stated everything was good except my c.v boots had a slight leak..but I will definitely try the seafoam..and yes it does idle a little low the low idle started after I replaced my engine mount that's when the vibration got worse I guess ill be putting the headlights at stoplights till I figure this out
post #5 of 11 Old 07-09-2019, 07:36 PM
Quoted: 15 Post(s)
Since the headlights have an effect, you may have an electrical issue.
Maybe the alternator is putting out too much voltage (s/b around 14volts)
Measure the battery voltage while :
- not running
- while idling
- with HL's on
My vehicles:
2006 Highlander
2001 Corolla
1999 Tacoma 4x4
FolsomLE is offline
post #6 of 11 Old 07-09-2019, 09:46 PM
Moderator
75aces's Avatar
Quoted: 1028 Post(s)
Have you checked your engine mounts?
In the garage,
9th Gen Corolla XRS
2012 Mazda 5
"If it ain't broke yet, it's probably still working like a Swiss time piece; until you open it up and all hell breaks loose"
75aces is online now
post #7 of 11 Old 07-09-2019, 11:55 PM
Claudio Souza Junior's Avatar
Quoted: 0 Post(s)
Funny enough my car does the same thing, but not all the time. Never found a solution for it so i just let it go 🏻
Claudio Souza Junior is offline
post #8 of 11 Old 07-10-2019, 10:04 AM Thread Starter
Quoted: 2 Post(s)
(Thread Starter)
I had my mounts checked in June and had one replaced and then they double checked them one week ago
post #9 of 11 Old 07-10-2019, 10:06 AM Thread Starter
Quoted: 2 Post(s)
(Thread Starter)
I tried letting it go but the vibration just gets to me ive seen 18 different mechanics and 6 garages and no one can tell me what's wrong they say theres no check engine light and ive had so much work done they couldn't figure it out i even had them test my computer
post #10 of 11 Old 07-12-2019, 09:28 AM
Steven Spock's Avatar
Quoted: 0 Post(s)
I have a 2010 Matrix 2.4 AWD I have had a vibration also. I went to many shops and finally another Matrix owner told me to check the exhaust mounts and have them replaced. I did it solved the issue
Steven Spock is offline
post #11 of 11 Old 07-12-2019, 07:18 PM
Corolla trd's Avatar
Quoted: 293 Post(s)
I have the same issue but never pay attention to it, now that is mentioned, I'm going to hold into DIY oil change and send it to the dealer to hear their input, well I have 180000 miles and counting
Toyotas
Lexus GX 470 2006 Trade
Lexus RX 350 2009 Trade
Lexus RX 350 2012 trade
Lexus RX 350 2015 '
Camry 2002 trade
Corolla 2010 '
Corolla trd is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > Corolla 10th Gen/2nd Gen Matrix (2009-2013)
User Tag List
Linear Mode Linear Mode
