2009 Toyota Corolla LE Oil Consumption - Toyota Nation Forum : Toyota Car and Truck Forums
Corolla 10th Gen/2nd Gen Matrix (2009-2013) A place to discuss all things 10th Gen Corolla and 2nd Gen Matrix.
post #1 of 24 Old 08-23-2010, 08:29 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
My 2009 Toyota Corolla has an oil consumption problem that Toyota refused to remedy. Last April, I noticed a grinding noise and had gotten the oil changed 4800 miles earlier. I looked at my dip stick and it was totally dry. Since then I have been getting oil consumption tests every 1000 miles which really doesn't prove anything, especially when Toyota over fills! I contacted the Gulf Coast region District Manager and was told they can't do anything unless the car consumes more then 1.1 quarts in 600 miles. That means everytime I fill up with gas, I would need to put in 1/2 quart ...THEY CONSIDER THIS NORMAL!!! I am taking action through the State DMV but don't know if I have any leverage since it states the above consumption in the owner's manual!
The ECM has been reflashed and I have changed to synthetic oil but still no results. Does anyone know what I can do to either fix the problem or how to get any results from Toyota? I can't believe Toyota will not stand behind their product!
s1arch is offline
post #2 of 24 Old 08-23-2010, 09:08 PM
littleboi64's Avatar
Quoted: 3 Post(s)
i would remain parked for a while and see if any of it is leaking out.
littleboi64 is offline
post #3 of 24 Old 08-23-2010, 10:45 PM
TLeong13's Avatar
Quoted: 0 Post(s)
What weight of oil are you using?....people were saying when they were using 0w-20 that their engine was consuming oil but when they switched to 5w-20, the consumption stopped
2009 Corolla S Magnetic Gray Auto
Limo Tints|K&n Typhoon Intake|Upgraded Premium Horn|Smoked Tails, Reflectors & fogs||HID Kit FOG & Heads 6000k|TRD Lowering Springs|TRD FSB|TRD RSB|Wicked flow muffler|Weathertech Vent Visors|Keyhole Plugs|Calvin vinyl
Future:
JDM front lip|Headers|17in rims
TLeong13 is offline
post #4 of 24 Old 08-23-2010, 11:12 PM
Senior TN Member
flamedrgn's Avatar
Quoted: 0 Post(s)
synthetic would actually consume more if theres a leak because the particles are smaller. try switching to 5w-20.
flamedrgn is offline
post #5 of 24 Old 08-23-2010, 11:37 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I actually started out with 5w20 and switched to synthetic...I am going to try 5w30.
Thank you.
s1arch is offline
post #6 of 24 Old 08-23-2010, 11:39 PM
uh..no, it's not a hybrid
LeanBurn's Avatar
Quoted: 188 Post(s)
Canada
Uhhh... 0w20 and 5w20 are both the same weight...20....the 0w20 has additives that allow it to flow slightly better at a given lower temperature, & I do mean slightly, insomuch that one could barely tell by the specifications on paper....
Synthetic particles are smaller??? That's a new one. Synthetic oil is such that it has better lower and higher temperature flowing/protection capabilities than conventional oil. Other than that the difference is what group it comes from (group I,II and sometimes III are conventional, group III, IV, V are synthetic) and its additive packages which varies in any oil.There are some conventional oils that perform close to a synthetic, The SM class conventional oils of today perform more than adequately for more than 90% of the vehicles out there.
You guys should visit BITOG and get more correct information. If you really wanted a different weight, you would go with a 0w30/5w30
'09 Corolla CE Enhanced Auto
TRD Springs/Sway/Xrs FSB by Yamaha
Lifetime : 6.111L/100km(38.761mpgUS)
Maximum: 5.082L/100km(46.287mpgUS)
(manually calculated)
(original unflashed factory ECM code)
LeanBurn is offline
post #7 of 24 Old 08-23-2010, 11:40 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Tried that...no oil leaks. The dealership also checked for leaks.
Thanks anyways.
s1arch is offline
post #8 of 24 Old 08-24-2010, 10:49 AM
It needsa muffler bearing
Quoted: 0 Post(s)
I thought it was 1.1qts in 1000mi? Could be different for the corolla I guess. That seems like a lot of oil consumption.
2010 Corolla S Black-Auto-Fujita SRI-Debadged -Mobil 0W-20 Oil-Nokya Yellow Fogs-All led swap-TRD FSB-TRD Lowering Springs-*** 6k HID-Shift boot/CF Shift Knob-20/35 Tints-Tenzo r Cuzco Wheels-SmokeTail Lights
On the way: Borla exhaust-DC Sports Headers
ej063090 is offline
post #9 of 24 Old 08-24-2010, 11:01 AM
Diehard Rams Fan
SuperchargedMR2's Avatar
Quoted: 2007 Post(s)
iTrader Score: 8 reviews
First of all let me you to TN. I haven't heard of any issues once people had the reflash done. I would try 0W-30 or 5W-30 just to check the result. Have you looked at your plugs to see if they look normal? Keep pushing your dealer too, my 09 Corolla S has never used any oil & never had the reflash done either.
89 Supercharged White MR2 5MT/09 Corolla S TURBO CSM 5MT
17 Corolla iM CSM 6MT/ 17 RAV4 XLE MGM
95 Previa S/C White AT/06 Scion xB MT/10 Prius III Blizzard Pearl
SuperchargedMR2 is offline
post #10 of 24 Old 08-20-2011, 10:21 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Trading in the Corolla!
Thanks everyone for your input and I have taken a lot of the advice but the car still burns oil. I can honestly say that Toyota doesn't stand by their products. I have done everything, even taking Toyota to small claims court about the oil consumption problem and no positive results. Right after 36K miles, my auto door locks broke, and the A/C fan broke. I got the A/C fixed and less than a year later it is broken again which makes me believe there is a larger issue. Just problem after problem. My friend just traded in his Scion because the dealership wanted to charge him 3500.00 for an electrical issue that wasn't covered under warrenty. He traded it in for a Kia, and I plan to do the same. GOOD BYE TO TOYOTA FOREVER!
s1arch is offline
post #11 of 24 Old 08-20-2011, 10:30 PM
Diehard Rams Fan
Sorry to hear about all the issues, my 09 S has been great. Most of use have had very good results with our Corollas but there will always be the exception to the rule with every manufacturer. Just remember that if you have a bad experience with any other brand down the line. You can see people saying the same thing as you on any forum when jumping ship.
post #12 of 24 Old 08-20-2011, 10:56 PM
Scion XD
Quoted: 0 Post(s)
I don't know about this guy. There have been issues of consumption, but no problems like that. You should be covered under the lemon law, right?
nateson is offline
post #13 of 24 Old 08-20-2011, 11:23 PM
Quoted: 3 Post(s)
So according to Toyota you would need 4.5 quarts for an oil change then add 7.7 additional quarts of oil for 5000 mile oil change interval.
12.2 quarts an oil change.
Sounds like there is an issue with the engine design.
All engines consume oil every time the cylinder fires,
But that is just a bit excessive.
I run 5W30 and do not have any oil issues.
Try a heavier oil and see what happens.
ZO6_Vette is offline
post #14 of 24 Old 08-21-2011, 12:24 AM
Senior TN Member
Quoted: 405 Post(s)
Good luck with your Kia, my friend traded in his Lexus gs for a forte and I really like the car. These newer toyotas need the 90s quality again. Burning oil is never normal.
pmesfun is online now
post #15 of 24 Old 08-21-2011, 12:52 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I wasn't covered by the lemon law because Toyota has the clause in their owners manual that stipulates 1.1 quarts every 600 miles and I when I bought the car, I signed a paper stating that I accept the terms in the owners manual.
I have tried changing oil weights, believe me I have tried everything.
I am sure that most Toyotas are great cars...I have actually owned two other corollas that were trouble free...just have a major problem with this vehicle and the corporate office, Gulf States Toyota Corporate located in Houston, standing by their product. I didn't ask for replacement of the car, just asked them to fix it. Their lack of professionalism and lack of communication has turned me against Toyota and they have lost a great customer. I am sure some other manufacturers are the same or worse but I do know my parents recently bought a new Honda CRV that had an engine issue...Honda replaced the engine and now the car runs perfect...Honda was there to stand by their product.
s1arch is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > Corolla 10th Gen/2nd Gen Matrix (2009-2013)
User Tag List
Linear Mode Linear Mode
