2013 Toyota corolla ce headlight retrofit - Toyota Nation Forum : Toyota Car and Truck Forums
Corolla 10th Gen/2nd Gen Matrix (2009-2013) A place to discuss all things 10th Gen Corolla and 2nd Gen Matrix.
post #1 of 7 Old 01-04-2014, 05:45 PM Thread Starter
dynamite647's Avatar
Quoted: 22 Post(s)
(Thread Starter)
Canada 2013 Toyota corolla ce headlight retrofit
Hey Guys,
I recently completed headlight retrofit. This is my first ever retrofit. Some pics here of final product. A tutorial is coming very soon. Converted headlights to Morimoto Mini h1 6.0 projectors, Apollo shroud and 5000k! Painted the housing black to reduce glare.
Regards
Btw is there any simple way of uploading images to this site besides providing http links everytime?
https://imageshack.com/i/g1z2qvj
dynamite647 is offline
post #2 of 7 Old 01-04-2014, 10:25 PM
Diehard Rams Fan
SuperchargedMR2's Avatar
Quoted: 1998 Post(s)
iTrader Score: 8 reviews
You asked....here it is.
https://www.toyotanation.com/forum/20...-pictures.html
89 Supercharged White MR2 5MT/09 Corolla S TURBO CSM 5MT
17 Corolla iM CSM 6MT/ 17 RAV4 XLE MGM
95 Previa S/C White AT/06 Scion xB MT/10 Prius III Blizzard Pearl
SuperchargedMR2 is online now
The Following 2 Users Say Thank You to SuperchargedMR2 For This Useful Post:
dynamite647 (01-04-2014), SupremeCorolla451 (01-05-2014)
post #3 of 7 Old 01-05-2014, 02:51 PM Thread Starter
Quoted: 22 Post(s)
(Thread Starter)
passenger side hid issue
Hey SuperchargedMR2,
I was wondering if you can kindly help me out with something. Today I tried to test the headlights on my car. So after installing all the wires, headlights including relay harness all grounded.
On the first turn on the passenger side flickered and turned off while drive side turned on as normal. Then when i turned off low beam and turned on headlights again both fired up. I tried on/off 5 times after that and all worked fine. All car systems work ok no issues. So after a few mins I retried the whole thing.
headlights on (passenger side doesn't work, headlight off and on again both work.
What could be the issue? I checked my wiring and it all looks good. I tested the passenger side separatlety on a battery and it fires up normal.
Thanks in advance!
post #4 of 7 Old 01-06-2014, 02:58 PM
littleboi64's Avatar
Quoted: 3 Post(s)
Thanks in advance!
is it an ebay kit? sounds like your hid kit needs additional power. you might need to install a harness for it
littleboi64 is offline
post #5 of 7 Old 01-06-2014, 05:58 PM Thread Starter
Quoted: 22 Post(s)
(Thread Starter)
Hi littleboi64
I have the morimoto H1 kit.
http://www.theretrofitsource.com/pro...oducts_id=3959
It is "supposed" to be high end but I think otherwise. I already installed there fancy relay harness.
I think the cheap ebay one or genuine Philips/denso might be better lol
post #6 of 7 Old 01-06-2014, 10:45 PM
Diehard Rams Fan
I have the same kit & it has been regarded as the best quality you can find. I'm no expert but I would check all your connections. If everything looks okay then I would call TRS as they are very helpful & willing to help & they are the experts. Odds are it was something not done quite right when installed but if it is a faulty part they will quickly get it fixed for you. Don't think the worst right away as it's usually the easiest solution that is the answer.
post #7 of 7 Old 01-06-2014, 11:44 PM Thread Starter
Quoted: 22 Post(s)
(Thread Starter)
That is true. Shouldn't draw conclusions yet. Btw what is the coldest temp your car to face or if your car was parked outside? I bought the kit from another seller (http://www.prolightz.com/) really nice guy and he told me test it again if still fails he will send me new ballast!
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > Corolla 10th Gen/2nd Gen Matrix (2009-2013)
Tags
apollo shroud , canada , corolla , morimoto mini h1 6.0 , ontario
User Tag List
Linear Mode Linear Mode
