Steering Column Rattle Noise - 09 Venza - Toyota Nation Forum : Toyota Car and Truck Forums
Venza Forum Discussion area for the Toyota Venza, a new crossover sedan vehicle. (2009+ model year)
post #1 of 6 Old 02-01-2017, 11:12 AM Thread Starter
nubie
Quoted: 0 Post(s)
(Thread Starter)
Hi
My Venza got the steering column rattle noise as described here :
http://www.myvenza.ru/tsb/T-SB-0005-11.pdf
Old part number was (Mechanical Key)
45250-0T060
New part number is :
45250-0T062
I bought a used steering column from a newer Venza from 2012 which has part number :
45250-0T100
The dealer refuse to replace, I know, they don't want to be responsible of any further damage, if it is not compatible.
Does anybody know here if the new part is compatible ?
Thank You
09 Venza
Erick Mulyadi is offline
post #2 of 6 Old 02-02-2017, 07:03 AM
lpatrick's Avatar
Quoted: 49 Post(s)
Steering column
It must be replaced with a new column.
lpatrick is offline
post #3 of 6 Old 02-14-2017, 12:24 AM
Quoted: 0 Post(s)
The steering column in my 2009 v6 ltd also made noise. It is very annoying. I can hear the noise and feel the knocking whenever I shake the steering wheel.
I injected chain lube inside the steering shaft, greased the steering rack but they both won't help.
I ended up doing this mod last summer and it works great. It is a temporary fix but doesn't cost anything.
http://venzaclub.ru/node/1723
epr188gc8 is offline
post #4 of 6 Old 02-14-2017, 12:04 PM
Quoted: 12 Post(s)
epr188gc8 - I have had my 2009 Venza for about 3 weeks and the noise from this steering gear mess is making me hate my car. I would try anything to cure this, but $1700.00 fix is out of my financial range. Could you please put together a more detailed post of how you did this, what parts needed, etc? I am sure that dozens of Venza owners would be so thankful for some help! If I had know of this problem, I would not be a Venza owner right now, but I am unfortunately stuck. Thanking you in adance, Dan!
dlw1949 is offline
post #5 of 6 Old 02-14-2017, 12:23 PM
Quoted: 12 Post(s)
Erick, I checked Amazon, Ebay, and a Toyota dealer and all three said that 45250-0T100 is NOT compatible with the 2009 Venza. I wasn't able to find exactly what this part fits, but I hope this saves you some time.
Regards, Dan
dlw1949 is offline
post #6 of 6 Old 04-15-2019, 05:54 PM
Quoted: 0 Post(s)
Did you ever get a more detailed instructions or figure this out? The pictures are helpful but the translation of the site are hard to understand. I have the same problem. Any help would be welcomed.
sfeitl is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Venza Forum
User Tag List
Linear Mode Linear Mode
