2013 Toyota Venza Auto Rear hatch not working correctly - Toyota Nation Forum : Toyota Car and Truck Forums
Venza Forum Discussion area for the Toyota Venza, a new crossover sedan vehicle. (2009+ model year)
 1Likes
  • 1 Post By dustydis2014
post #1 of 8 Old 06-15-2019, 01:48 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
The automatic rear hatch on my 2013 venza is not working correctly. Firstly, it DOES operate manually. The button to disable the door is NOT depressed to disable the system. If you depress the button to open it automatically (via inside the front cabin, the remote, or the rear door), it beeps, sounds like it is trying to open but does not unlatch, and secures itself closed.
Kkdm is offline
post #2 of 8 Old 06-28-2019, 10:10 PM
Quoted: 1 Post(s)
Mine (2010 Venza LE 4cyl, 180,000 miles) wasn't working right, either. I went looking for something in the lock mechanism (mechanical or electrical) but nothing stood out. Finally realized the weatherstripping (thick black rubber all around the opening) wasn't seated correctly. Re-installed the stripping all around and the door worked good as new. That was about a year or two ago. Recently, same problem re-occurred. Think I will apply some dabs of adhesive to the rubber to make sure it stays in place.
Helodrvr is offline
post #3 of 8 Old 07-07-2019, 01:06 PM
dustydis2014's Avatar
Quoted: 0 Post(s)
The problem with mine is that when I press the key fob it beeps open a little then closes. I have to do this a few more times for it to open completely.
Slvr 14 Venza V6 auto gate, racks, carpet, K&N filter, drilled slotted rotor. Mod 12+ Camry J2 exhaust, 265/35/22" wheels, H&R springs.
dustydis2014 is offline
post #4 of 8 Old 07-08-2019, 05:56 AM
Green Eyed Monster
lburton's Avatar
Quoted: 440 Post(s)
When it beeps and opens a little, can you grab it and open it up? Sounds like it might be that the gas springs that assist in opening the door are failing.
My Customized Venza
35% Tints/K&N Intake/Tint Head-Tails/Billet Grille/MagnaFlow CatBack/22" Asantis/265-40R22/Megan Coilovers
lburton is offline
post #5 of 8 Old 07-08-2019, 09:26 AM
Quoted: 0 Post(s)
Hey lburton, thanks for the heads up. Yes I can grab the bottom to pull it open, but after pressing the fob couple times it opens all the way, it only does it with fob. The latch release inside the car works perfect, I noticed it few days ago after work, I would let the windows down and open the hatch while walking to my car to kinda cool it off before it get to my car, that is when I notice it didn't opening all the way beeps unlatches opens a little then closes.
lburton likes this.
post #6 of 8 Old 07-08-2019, 04:51 PM
Quoted: 0 Post(s)
dustydis2014 - How do you open the windows before you get to the car?
VA_Venza is online now
post #7 of 8 Old 07-08-2019, 06:55 PM
Quoted: 0 Post(s)
It's a box you put in the OBD port, lets you roll up and roll down the windows with the key fob. Got it years ago still works, don't remember what it's called but I now it took a long time to be delivered lol.
post #8 of 8 Old 07-12-2019, 11:09 AM
Green Eyed Monster
lburton's Avatar
Quoted: 440 Post(s)
I remember, they took like 6-8 weeks, unfortunately, they are not available from Aliexpress any more, at least not the original listing. However, if you Google "Toyota Venza OBD window closer", you'll find them.Here is the post with functional and purchasing info:
https://www.toyotanation.com/forum/1...ml#post8795906
My Customized Venza
lburton is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Venza Forum
User Tag List
Linear Mode Linear Mode
