My HID and interior LED lights installation (lots of pics) - Toyota Nation Forum : Toyota Car and Truck Forums
Venza Forum Discussion area for the Toyota Venza, a new crossover sedan vehicle. (2009+ model year)
post #1 of 22 Old 11-04-2010, 11:38 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
For my 2010 Toyota Venza, I ordered Philips HID kit from Ebay, which costs me less than 200 usd shipped to my door. I have 4300k and 6000K HID bulbs and lets see what the differences are comparing to the original one.
A picture worth a thousand words. Picture with story...
The original plug and light bulb detached. Noticed that there are yellow wire and black/whit wires on the driver's side. On the passenger side, it is red and black/whit wires on my Venza Later on it is going to be connected with the HID kit
The blue and black wires are from the HID kit. They are going to be pluge into the green socket.
Notice that the blue wire should align with the color wire of the green socket. In this case on the passenger side, it is a red wire. The black one goes with the black/white wire. I use black wire to secure this from detach apart. For other wires, they all have specific shapes, just plug and play, you can't go wrong.
After all the connections, lets fire it up and see how it look.
It is the 4300K here in the picture.
This is the original bulb, yellowish and not bright.
Here is the Philips 4300K. I have set the camera in manual mode, so the shutter speed and aperture are all the same.
See it is white on left side and yellow on the right side.
Right side original
Now right side 4300K
Left side 4300k
Left side 6000k
Left side 6000k, Right side 4300k
Another angle, left side 6000k, right side 4300k
I use industrial grade velcro to secure the ballasts
Here is one of the places to put the ballast for right side.
I cut the velcro so it shap nicer
Here is the place I put(hang) the ballast on the driver side. Clean the plastic a bit and put the sticky velcro on.
Trunk Light
Pop it off with a (-)screw driver on the right side
With original bulb. Planty of space. I should get the LED board type instead of the small one.
The one with 4 LED is the one I use.
Original bulb
LED (color is a bit purpleish, sorry, I took the picture using my cellphone.)
Center Lights
Again, pop one side of the center piece open first.
You will see the center bulb
Here is the T10 LED I use. it has 6 white squares and each square contains 3 led, so there are total of 18 light emitting source from this tiny LED.
Size comparison (unit is cm)
Put it in
Lights from 3 directions
Just pull gentally and it should come off.
[IMG][/IMG]
Watch out not to break it when you put it back in
You can see the hinge here. There are 2 hings for the right and left light covers. The center piece has 4.
The LED is so small that there is still lots of room if you consider a longer LED. Just remember to take away the center light cover first when you are doing this area, and put it back the last when you are done.
The LED still have the gradual dimming effect when you open and close doors.
Thats it for now. I will post more pics for the rear reading lights and HID test on the road when I have free time.
Door Lights
After detached from door
The size of the cover limits the size of the LED you can use, unless you plan not to put the cover back.
Detach the cover
Without the cover
There are 4 metal bar that holds the original bulb, which also limits the LED selection, unless you bent it straight.
Thats it for now.
thanks for reading
ccd79 is offline
The Following 5 Users Say Thank You to ccd79 For This Useful Post:
chippedvw (11-24-2010), digitalxdude (06-14-2013), jflarin (11-06-2010), Slvregl (11-25-2010), TrailDust (11-05-2010)
post #2 of 22 Old 11-05-2010, 11:59 AM
Quoted: 4 Post(s)
USA
I love your install. Very Clean. Can you post the link for the site where you got the LED bulbs from? I wanna order those for mine NOW!!! Also, if you can specify which bulb for which side that would be helpful
Where did you get your HID's from? Noticed you had the Philips ballast...curious
nit407 is offline
post #3 of 22 Old 11-05-2010, 02:27 PM
AIH
Quoted: 0 Post(s)
Thanks for the great write-up! Are the LEDs in the cargo area brighter than the old light bulb? Or do they look that way because the camera adjusted to the lighting?
Is the color of the light that blueish?
AIH is offline
post #4 of 22 Old 11-05-2010, 02:29 PM
Do you feel lucky?
TrailDust's Avatar
Quoted: 7351 Post(s)
Great write-up!
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is online now
post #5 of 22 Old 11-06-2010, 12:06 PM
Quoted: 0 Post(s)
Are you planning on upgrading foglight to HID too?
Great photos and instructions. Are you planning on upgrading foglight to HID too?
dcpc08161992 is offline
post #6 of 22 Old 11-06-2010, 12:44 PM
heatjay's Avatar
Quoted: 0 Post(s)
heatjay is offline
post #7 of 22 Old 11-06-2010, 02:05 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Nit407, I got these LED light from yahoo auction site of Taiwan. Bad thing is that they don't ship out of Taiwan, so the only way to get it is to have someone living there and get it for you. You can check Ebay for similar items, I think there are a lot there to choose from.
The main type of bulbs for interior light are T10.
The 2 Door lights
3 center roof lights
2 mirror lights
1 rear reading light
They are all T10 type of LED. Jus get the longest bulb that can be fitted in its own case.
For me, I got the LED before I got the car, so I played safe and find the brightest/ smallest one to make sure they fit.
For the rear reading light, maybe this is a good idea. Only one side has LED
The only different one is the trunk light, which uses a 3022 bulb.
From the photos, you can see that there are planty of room. If I do it again, I would take out the trunk light (should take only 5 secs) and measure the space, and then order the largest board type LED that fit. I found that the LED I use for the trunk is just a little brighter than the original one.
ccd79 is offline
post #8 of 22 Old 11-06-2010, 02:31 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
It looks bright if you starr at it. But if you look at the cargo area where it shines, I think only a little brighter. You will notice it has just a tiny blue hue if you satrr at it a long time and compare/imaging the flourecent desk lamp at home.
I think something like this is better. it will be brighter for sure.
ccd79 is offline
post #9 of 22 Old 11-06-2010, 05:16 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I have added some pictures for the door light.
ccd79 is offline
post #10 of 22 Old 11-24-2010, 05:17 PM
Quoted: 0 Post(s)
Do you know how to remove the panel to change the bulbs in the rear map lights. I do not have the sunroof in my Venza.
Thanks
chippedvw is offline
post #11 of 22 Old 11-28-2010, 08:13 AM
2010 Sunset Bronze Mica
Quoted: 0 Post(s)
Thanks
Here is a link to the Camry forums. The rear map lights are the same. I replaced my interior lights with LEDs except for the rear map lights. I hope to finish this soon.
https://www.toyotanation.com/forum/sh...d.php?t=271120
nevadavenza is offline
post #12 of 22 Old 11-30-2010, 07:08 PM
Quoted: 0 Post(s)
Anyone HID their foglight?
I found this HID kits (supposedly a good quality HID kits... according to their disclaimer)... but I never see anyone upgrade their stock fog light to HID. I am afraid it would melt the plastic housing of the fog light to to high heat built up.
I have tried the so called bright 'led' bulbs but the result is totally disappointed to say the least.
This is the kit I am talking about:
http://cgi.ebay.com/ebaymotors/ws/eB...ht_5702wt_2447
post #13 of 22 Old 11-30-2010, 07:26 PM
Quoted: 0 Post(s)
i have a kit that i instaled last year in march and have had no problem and my fog light are always on when the light is on i have the 5000k and the color is not exacly the same i think the color of the venza is actualy 4000k
2009 venza v6 awd magnetic grey premium pkg
VENZPHIL is offline
post #14 of 22 Old 11-30-2010, 08:06 PM
Quoted: 0 Post(s)
Thanks for the info. I think the stock HID is 4300k.
post #15 of 22 Old 12-01-2010, 10:09 AM
CrazyBiker's Avatar
Quoted: 38 Post(s)
I went with the 6000k 55w kit from *** Tuning for ~$50.
CrazyBiker is online now
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Venza Forum
User Tag List
Linear Mode Linear Mode
