$70 chinese android installed in my 97 avalon - Toyota Nation Forum : Toyota Car and Truck Forums
Avalon 1st Generation (1995-1999) Specific discussion of the first generation Toyota Avalon
 1Likes
  • 1 Post By Shinviroz
post #1 of 8 Old 04-16-2019, 08:46 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
i have a 1997 toyota avalon, similar to 1995, 1996, 1998, 1999.
my tape deck was making mechanical noise, so i decided to upgrade the stereo to aftermarket stereo, but then i saw these cheap $70 android that nearly matched the size of my stereo.
i'm getting a small white noise when there's no music playing, and the radio is not as good as before, but now i have gps navigation, bluetooth, and even youtube and gmail etc.
i've made a video showing what i did.
sorry it's not very detailed because i ran into a lot of problems and it's my first time doing this.
BlueJ222 likes this.
Shinviroz is offline
post #2 of 8 Old 04-17-2019, 03:39 AM
Quoted: 25 Post(s)
Not many people have done a video on Double Din installs on 1st gen Avalons. Should help some new folks out. Only thing I would correct is the electrical tape, it's bound to come unstuck, cause an electrical short, and then fry your equipment. Put on some crimp connectors instead. BMR, he's got some useful captions on it. Maybe worth getting it stickied?
Jagalag is online now
post #3 of 8 Old 04-17-2019, 10:34 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Thanks, I'll change them to proper connectors soon.
Do you think it's ok that I connected the red wire to power both android and the amp?
Any tips on getting rid of white noise? It's not too bad, and there's no white noise when there isn't any song/sounds playing.
post #4 of 8 Old 04-17-2019, 05:50 PM
BMR
Sheriff of Mayberry
BMR's Avatar
Quoted: 1824 Post(s)
Stickied.
Connecting two things to the red wire is probably OK. It didnít blow a fuse, right? They donít pull too much power. If one was a high powered amp, then maybe.
The white noise is probably due to the head unit. You could try putting a filter on the power wire, but that may or may not help.
2015 RAV4 Limited, AWD, tech pkg, Barcelona red metallic, 62k miles
1996 Avalon XLS, ABS brakes, super white II, acquired w/ 139k, now at 397k
1992 Camry LE, V6 (3VZ-FE), ABS brakes, dark emerald pearl, owned since new. Replaced HGs @332k, totaled at 384k miles
BMR is offline
post #5 of 8 Old 04-22-2019, 01:11 PM
Quoted: 1 Post(s)
Great video!! Do we need to install that scoshe thing? I have a cheap wish.com one that I went to install, and I ordered a connector. It didn’t fit 😕 I may have put the wrong part#. I ordered another should be here in a couple of days.
The other question I have is the 2 (radio) connectors in the factory deck. I’ve never seen 2?? Just usually the one bigger one. What are these.
Dave Coupland is offline
post #6 of 8 Old 04-22-2019, 08:55 PM
dieselissyjr's Avatar
Quoted: 0 Post(s)
Nice going dude, been meaning to switch out mine too! lol
dieselissyjr is offline
post #7 of 8 Old 04-23-2019, 12:49 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Originally Posted by Dave Coupland View Post
Great video!! Do we need to install that scoshe thing? I have a cheap wish.com one that I went to install, and I ordered a connector. It didnít fit 😕 I may have put the wrong part#. I ordered another should be here in a couple of days.
The other question I have is the 2 (radio) connectors in the factory deck. Iíve never seen 2?? Just usually the one bigger one. What are these.
I think the only harness that fits my old Toyota is the Metra 70-8112, so I had to buy it.
Then I noticed the harness had 4 RCA output cables for FR,FL,RR,RL speakers, which needed someplace to be plugged into: the scosche line output converter(LOC).
I was able to strip the wires from the aftermarket android and feed them into the LOC.
So yeah, I think you do need some sort of LOC if you are gonna use a harness that has 4 RCA cables.
If your aftermarket radio has 4 RCA inputs already, then you wouldn't need it.
post #8 of 8 Old 04-27-2019, 04:37 PM
Just found TN and love it
Quoted: 9 Post(s)
Or solder and heat shrink. Nice video!
Leila
1994 pickup 2wd 22re 5 spd 244 k mi. bought new
1995 Avy XL 235k mi. bought @ 56k mi.,
1994 Honda Civic LX 290mi. bought @ 68k
lifelongtoyotagirl is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > Avalon 1st Generation (1995-1999)
User Tag List
Linear Mode Linear Mode
