Windshield Wiper Linkage, How... - Toyota Nation Forum : Toyota Car and Truck Forums
Avalon 1st Generation (1995-1999) Specific discussion of the first generation Toyota Avalon
post #1 of 7 Old 06-13-2019, 09:51 AM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
97 avalon. the wiper arms and plastic are off. Now how do I disconnect the linkage so I can remove it all. Note I had removed the 4 motor bolts and 6 linkage bolts to no net result. Does the linkage just pop off? Should i pop the linkage off BEFORE unbolting things? Not obvious and alldatadiy.com has no info on this.
BobFixit is offline
post #2 of 7 Old 06-13-2019, 10:46 AM
Quoted: 120 Post(s)
The Gen1 design must be totally different from Gen2. According to my Gen2 manual, you remove the arms, remove the cowl, then take out 4 bolts, unplug the electrical connector, and lift the motor and linkage straight out. The 4 bolts in question go into the firewall/body on four little legs formed into the housing for the linkage. Two of these standoffs are close to the motor, and the other two are close to the the outward driver (left) end of the linkage housing.
Three bolts or screws then come out of the linkage housing at the motor end, and the motor is free.
01 Avalon XL
03 Avalon XL
OleAvalon is offline
post #3 of 7 Old 06-14-2019, 09:21 AM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
Thanks but I had removed the 4 bolts on the motor and it flops around but is still connected to the linkage arm. How do I disconnect from the arm? I expect it snaps off but am asking before breaking. Your thoughts?
BobFixit is offline
post #4 of 7 Old 06-14-2019, 09:39 AM
Quoted: 120 Post(s)
The 02 manual says simply to use a screwdriver to remove the linkage from the motor, no details, no drawing.
It is maybe a snap-over connector, popped onto a ball stud, like those at the ends of the gas lift cylinders that hold up the hood?
01 Avalon XL
03 Avalon XL
post #5 of 7 Old 06-14-2019, 10:46 AM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
yes, gen 1 and 2 very different. motor of gen 1 is on the engine side of firewall and the linkage is on the back side of the firewall. thanks.
BobFixit is offline
post #6 of 7 Old 06-14-2019, 10:51 AM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
The offset arm (2 inch long) attaches to the motor with a hex-head bolt so I presume a screwdriver can be used to pop the linkage off the far end. tbd. Ill let you know and a photo. My arm has a squeak.
BobFixit is offline
post #7 of 7 Old 06-15-2019, 08:34 PM
Just found TN and love it
Quoted: 9 Post(s)
You remove the dix linkage bokts then you remove the linkage from the motor through the service hole. Then you take out linkage through the hole and if you need to remove the motor you do that last.
Leila
1994 pickup 2wd 22re 5 spd 244 k mi. bought new
1995 Avy XL 235k mi. bought @ 56k mi.,
1994 Honda Civic LX 290mi. bought @ 68k
lifelongtoyotagirl is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > Avalon 1st Generation (1995-1999)
User Tag List
Linear Mode Linear Mode
