What did you do to your Avalon lately? - Page 37 - Toyota Nation Forum : Toyota Car and Truck Forums
Avalon 1st Generation (1995-1999) Specific discussion of the first generation Toyota Avalon
 33Likes
post #541 of 547 Old 10-26-2018, 10:06 AM
BMR
Sheriff of Mayberry
BMR's Avatar
Quoted: 1822 Post(s)
Hey there SimiSu, and welcome to TN! Nice to hear you've been getting a lot from the TN forums.
SimiSu likes this.
2015 RAV4 Limited, AWD, tech pkg, Barcelona red metallic, 62k miles
1996 Avalon XLS, ABS brakes, super white II, acquired w/ 139k, now at 397k
1992 Camry LE, V6 (3VZ-FE), ABS brakes, dark emerald pearl, owned since new. Replaced HGs @332k, totaled at 384k miles
BMR is offline
post #542 of 547 Old 12-17-2018, 04:19 PM
Quoted: 3 Post(s)
Installed Michelin Ultra Stealth 21" & 19" windshield wipers.
Fabricated & installed insulation on firewall...repaired some damaged hood insulation.
Put leds in front side lights and door lights.
Cleaned and detailed engine compartment (no water or chemicals - just tons of rags and Spray Nine Cleaner)
Porter Cable - Meguiars 105 > Pinnacle Advanced Finishing Polish > Meguiars Cleaner Wax
Really perked up the Diamond White Pearl
Picked up a Denso 234-9007 02 Sensor - from Rock Auto. I hope to install it later this week. Read all the diy's but will probably have questions before the install.
Chas78 is offline
post #543 of 547 Old 02-11-2019, 02:57 AM
Quoted: 0 Post(s)
Got the water pump, timing belt, knock sensors and harness, spark plugs and coolant bypass hose all changed and all the related gasket and seals. 236k and running strong. Trying out the "adding an extra washer under the valve cover bolts" thing to see if it fixes my valve cover leak issue. Though it was probably only leaking due to my not originally putting on the proper amount of RTV sealant. Just a heads up for you folks out there, the mechanic I had do the work was hesitant to add extra washers with the valve cover bolts because he thought it might cause the covers to crack. It worked of course and is good but, he went and tried the same thing with the final iteration 1MZ-FE w/VVTi and dual throttle bodies. An entire chunck busted off the corner of the valve cover! I looked at and realized the valve covers were slightly different from the 94-99 covers. They were also a bit skimpier than the older ones. Had a valve check done and all my valves were within tolerance, some exhaust valves were on the top end of the tolerance. Have a loud tick when the engine is running so, the mechanic and shop I took it too concluded that the valve springs are worn.
BlueJ222 is offline
post #544 of 547 Old 02-19-2019, 11:52 AM
BMR
Sheriff of Mayberry
BMR's Avatar
Got the windshield replaced last week for $223. The company I went with told me they'd install an "XYG" brand, which is a not too well rated Chinese made windshield. What they actually installed was a "TriVal", which I found out is a subsidiary of Pilkington.
azcorolla and BlueJ222 like this.
BMR is offline
post #545 of 547 Old 02-25-2019, 08:10 PM
You asked for it...
Quoted: 10 Post(s)
Computer threw a P0340 code - camshaft sensor bad. No performance symptoms at all, just the light. I changed it out, along with the crankshaft sensor just because the guy threw it in and because the one in the car was original. This got rid of the P0340 and didn't cause any new issues. I tested the old camshaft sensor and it showed infinite resistance. A good one should show somewhere around 2000 ohms, plus or minus about 400 ohms. So definitely bad.
Now I need an AC clutch bearing (really noisy). It looks like I'll need to remove the compressor to get the clutch off, so maybe I should just get a rebuilt comressor/clutch unit while I'm at it. Haven't decided on that yet, this is not something I can do myself, because of the refrigerant. The durn alternator is a bit noisy, too.
azcorolla is offline
post #546 of 547 Old 03-31-2019, 03:42 PM
Quoted: 0 Post(s)
TRD Goodies
Recently found this guy off IG and I purchased the TRD goodies for this platform. It'll be a good while before I install the supercharger as my valve springs are worn right now and I generally dont trust throwing any boost on my old and worn daily right now thats at 236k currently. Before and after pics of the stock solara bar vs TRD bar. I have a 96 and there is a relay box directly beneath/next to the driver side strut tower. The bracket does block the trd strut bar from full seating down just by a little bit so I cut a little corner piece off of it so the strut bar could fully seat down. Relay box is currently still zip tied for now but I'll modify it cleanly eventually to not have it ziptied anymore. Before you ask, yes... BIG difference from the stock solara bar, very nicely stiff and solid in the front end of the car now.
File Type: jpg Stock Solara strut bar top down view.jpg (762.4 KB, 5 views)
File Type: jpg Stock Solara strut bar strut tower view.jpg (643.2 KB, 5 views)
BlueJ222 is offline
post #547 of 547 Old 04-30-2019, 08:21 PM
Quoted: 0 Post(s)
Tinted the windows to 20% and added some Black 20" Wheels.
Alan Garcia is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > Avalon 1st Generation (1995-1999)
User Tag List
Linear Mode Linear Mode
