What did you do to your Avalon lately? - Page 4 - Toyota Nation Forum : Toyota Car and Truck Forums
Avalon 1st Generation (1995-1999) Specific discussion of the first generation Toyota Avalon
 34Likes
post #46 of 549 Old 08-27-2012, 05:33 PM
Senior TN Member
Quoted: 405 Post(s)
Has anyone thought of converting the fuel door release to electrical? I've thinking of moving the trunk release button and installing an fuel door actuator in the two empty spaces on the left of the steering wheel and installing my sub control knob where the fuel door lever is.
pmesfun is online now
post #47 of 549 Old 08-27-2012, 05:36 PM
Avarollin?
Jigg007's Avatar
Quoted: 3 Post(s)
Why not put the sub knob in that void to the left of the wheel? Im about to remove my power mirror switches, to make room for MORE SWITCHES
Jigg007's 1996 Toyota Avalon
250A Alternator
2500W AC Inverter
3200W Sound system
Windows 7 Carputer
Onboard Air System
D2 Street Coilovers
Jigg007 is offline
post #48 of 549 Old 09-02-2012, 01:36 AM
Avarollin?
Jigg007's Avatar
Quoted: 3 Post(s)
Double post WINNING
http://i.imgur.com/VAIe0.jpg
[s]The real question is what sort of sick bastard would take a picture with his camera phone when he has several dslrs at his disposal?[/s]
Edit:
Man, really wish I didnt crack that panel WAAAAY back. Still looking for a black avalon for as parts car. (seats, that dash trim, rear driver door etc)
250A Alternator
2500W AC Inverter
3200W Sound system
Windows 7 Carputer
Onboard Air System
D2 Street Coilovers
Jigg007 is offline
post #49 of 549 Old 09-06-2012, 06:44 AM
Chunkywolf's Avatar
Quoted: 2 Post(s)
Dang Jigg, there was a black 95 avi in the hammond pick-n-pull all last year(got some dash trim from it myself). Very nicely done panel though. I still have plans for my center console if I could have a long enough chunk of time in the same location.
After bein parked for the last 2 months in a shed, she fired right up, and made me regret leaving her empty(Chicago gas... ulgh). Also, long overdue pic of her on the freshly finished rims.
(It's nice that I don't need to censor the plate ever, lol)
Black 95 Avalon XLS 245k
2015 Cascadia DD15 225k
Chunkywolf is offline
post #50 of 549 Old 09-15-2012, 12:09 AM
Senior TN Member
Quoted: 405 Post(s)
I bought a new steering wheel off e-bay.
Old:
New:
post #51 of 549 Old 09-15-2012, 08:37 PM
Avarollin?
Jigg007's Avatar
Quoted: 3 Post(s)
Stumbled across a 98 Avalon at a bone yard that was blasted in the front, but the interior was MINT.
So I pulled the steering wheel, dashboard, every seat, the driver rear door (mines pretty rusty, cant go wrong for $75)
A lot of today's fun stemmed from fixing up a bunch of wires that I have added in. Right now, I'd like to call myself a professional (i do similar stuff at work; motor coaches), starting with zero knowledge on the Avalon over five years ago.
The wire loom with purple tape (radio-pass) is 1" in diameter and eventually I got it crammed full with said wiring.
Changed the harness out from the 98 to put the 96 in its place. All you need is one misplaced pin!
Then my helper ran off, and I wasnt looking forward to installing the dashboard single-handedly (plus it was getting dark) So now my car is in a million peices for the night. yay.
Oh, I also installed a monitor in my trunk because WHYNOT.
Oh yeah.. and about two or three weeks ago I installed a Mechman 240 amp high output alternator with an external regulator. That was fun...
250A Alternator
2500W AC Inverter
3200W Sound system
Windows 7 Carputer
Onboard Air System
D2 Street Coilovers
Jigg007 is offline
post #52 of 549 Old 09-19-2012, 09:21 PM
Senior TN Member
Quoted: 405 Post(s)
Nice score on the interior. How much added weight is in the avy?
Got my new steering wheel in. Put in on immediately.
post #53 of 549 Old 10-02-2012, 11:25 AM
Quoted: 1 Post(s)
My car is just shy of 130K miles and I decided to update the steering and suspension components that I haven't replaced yet. I've got ordered new ball joints, inner and outer tie rods to complete the front end. The rest I did about 1.5 years ago/12K miles ago. I also ordered a new hydraulic front engine mount and dog bone to replace the tired leaking front mount that I recently noticed and a slightly worn dog bone. It also seems now that my valve covers are starting to seep just a tad so that'll be a project for another day. Lots to do in the coming week or so....
fltwd56 is offline
post #54 of 549 Old 10-29-2012, 11:22 PM
Quoted: 0 Post(s)
Yesterday I changed the sway bar links & bushings.
The improvement is much more than I expected.
In a couple of days I will change the steering wheel as it's almost torn apart and I have a question about it.
My 1998 Avalon has steering shift, can I use a steering wheel from any other Avalon as the steering shift model is not very common ?
What other Toyota models' steering wheels will fit my Avalon ?
amaksoud is offline
post #55 of 549 Old 11-25-2012, 08:39 PM
BMR
Sheriff of Mayberry
BMR's Avatar
Quoted: 1877 Post(s)
Did a timing belt job on the Avy today. The works; belt, water pump, idler pulley, and tensioner pulley. I've had the Aisin kit sitting on my work bench for about a month. When I opened the hood, I found the radiator's upper cap was weeping coolant in several places, mostly where the mounts are located. So I ran to town and picked up a "Spectra" brand at Autozone (fortunately they had one in stock), and swapped that out too. Flushed and filled 'er with Toyota red coolant. The old rad appeared to be the original; "Harrison" brand. So it lasted a very long time. Typical for Toyota parts!
Getting the new timing belt on had me scratching my head for a while. Couldn't get the marks on the belt to align with the pulleys all in the correct place. Then I figured out I had the belt on backwards! Turns out the mark for the crank pulley is not centered between the marks for the cam pulleys by about 4 teeth. I can be such a dolt sometimes.
2015 RAV4 Limited, AWD, tech pkg, Barcelona red metallic, 65k miles
1996 Avalon XLS, ABS brakes, super white II, acquired w/ 139k, now at 399k
1992 Camry LE, V6 (3VZ-FE), ABS brakes, dark emerald pearl, owned since new. Replaced HGs @332k, totaled at 384k miles
BMR is offline
post #56 of 549 Old 12-14-2012, 11:52 PM
Senior TN Member
Quoted: 405 Post(s)
I lubed the front sway bar bushings, as they were making an awful creaking noise. Checked all fluids.
post #57 of 549 Old 12-23-2012, 02:47 AM
Quoted: 0 Post(s)
Hi all,
Today, I bought a set of rear shock absorbers for my 98 Avalon.
The brand is not popular over here, it's called Tokico, the black series, made in Thailand by Hitachi Automotive Systems.
I found reviews on other series but not on the black one. I bought the set for almost a 107 USD, is the price reasonable ?
I also bought a pair of front lower control arms and a pair of front and pair of rear brake discs.
They're being fitted right now and I'm supposed to collect the car after 7 hours Can't wait to see the difference as my old suspension sucked.
I'm planing to get a set of front shock absorbers next month but need your feedback regarding the brand.
amaksoud is offline
post #58 of 549 Old 12-23-2012, 12:54 PM
Chunkywolf's Avatar
Quoted: 2 Post(s)
A lot of people have put Tokico blue struts on their avalons/camrys and have found them to have a rough ride for the kind of car it is. I have yet to hear a single thing about the black series though.
My only recent changes to the avalon include an oil change, and 4,000 miles, lol
post #59 of 549 Old 12-25-2012, 12:48 AM
Senior TN Member
Quoted: 405 Post(s)
I installed tokico blues on my friend's ES with tanabe springs and the ride is pretty smooth. I'd say you will be satisfied with them.
post #60 of 549 Old 12-29-2012, 03:50 PM
Avarollin?
Jigg007's Avatar
Quoted: 3 Post(s)
Just had the front windshield and seal replaced. Not having water leaking inside the car is cool (plus the wipers actually make contact, ohboy!)
Soon... ill be in the same boat needing to replace the rear struts... take a guess why
250A Alternator
2500W AC Inverter
3200W Sound system
Windows 7 Carputer
Onboard Air System
D2 Street Coilovers
Jigg007 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > Avalon 1st Generation (1995-1999)
User Tag List
Linear Mode Linear Mode
