Rotor Replacement Question - Toyota Nation Forum : Toyota Car and Truck Forums
Avalon 3rd Generation (2005-2012) Specific discussion of the third generation Toyota Avalon
 2Likes
  • 2 Post By ukrkoz
post #1 of 11 Old 04-18-2019, 10:43 PM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
The 2006 Avalon front rotor replacement procedure calls for checking the runout of the new rotor and selecting the installation position where the front disc has the minimum runout. I do not own a dial indicator yet. I am I just asking for trouble if I install the new rotor without checking the runout?
kc27 is offline
post #2 of 11 Old 04-19-2019, 12:05 AM
Senior TN Member
Quoted: 620 Post(s)
As long as you clean the hubs, most name brand rotors are good enough quality where you won't have to worry about it. Since you didn't mention the rotor brand, buy the dial indicator and hub resurfacing tools.
https://www.harborfreight.com/clampi...tor-63656.html
Amazon Amazon
Amazon Amazon
https://www.autozone.com/test-scan-a...kit/900812_0_0
So many trolls so little time
Greasymechtech is offline
post #3 of 11 Old 04-19-2019, 05:47 AM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
I usually use Centric rotors or rotors from NAPA. This is the first time I have done brakes on this car. What brand rotor do you recommend?
kc27 is offline
post #4 of 11 Old 04-19-2019, 08:05 AM
Quoted: 55 Post(s)
When I did my 05 Avalon a couple years ago, called Centric to see what they recommended. Tech support asked if I raced or tracked the car. Since we agreed racing an Avalon would be madness, they said their standard rotor would be fine.
I bought my Centrics from Amazon, but Rock Auto also very good prices, either one beat NAPA/AutoZone/Advance, at least at the time.
As far as runout - I've never checked new rotors for runout, nor have I ever seen any shop check new rotors. Shrug
Riick is offline
post #5 of 11 Old 04-19-2019, 08:51 AM
Moderator
ukrkoz's Avatar
Quoted: 803 Post(s)
Lots of crazies out there, lots of crazies...
Greasymechtech and threevok like this.
ukrkoz is offline
post #6 of 11 Old 04-19-2019, 12:44 PM
Quoted: 55 Post(s)
SIR !!! .. I salute you.
Riick is offline
post #7 of 11 Old 04-20-2019, 06:48 PM
Cosmofennema's Avatar
Quoted: 9 Post(s)
Yup, I've never seen this either, and was 3 years at a Nissan/Subaru dealership.
Cosmo
Cosmofennema is offline
post #8 of 11 Old 04-21-2019, 11:15 AM
Senior TN Member
Quoted: 620 Post(s)
I recommend Bosch, Fremax, Raybestos, EBC, and Wagner rotors. I recommend solid blanks and nothing drilled or slotted. I recommend that the rotors have some type of rust preventing coating. And, if a brand has good/better/best selections, I only recommend best. OE rotors aren't too shabby. I don't recommend OE pads.
Some pads and rotors that I've used or installed are here:
https://www.toyotanation.com/forum/3...l#post14014220
post #9 of 11 Old 04-22-2019, 11:19 AM
Quoted: 55 Post(s)
OK.. My 07 Lexus uses the very same brake setup as the 08-13 Avalon. I managed to (slightly) warp the front rotors a month or so ago. Will put on new rotors, since milling them down, just makes them easier to warp in the future.
Guess I already know the answer, but, still:
Current pads are only 12,000 miles old, minimal wear - New pads & rotors, or, new rotors only?
Penny wise, Pound foolish ?
Riick is offline
post #10 of 11 Old 04-27-2019, 02:24 PM
Senior TN Member
Quoted: 620 Post(s)
New pads and rotors and use better pads
post #11 of 11 Old 04-27-2019, 11:56 PM
Quoted: 55 Post(s)
Better pads.... But you don't know what's on there now. Right now trying to decide on whether to use Raybestos ceramic/metallics or Akebono ACT.
Which pads do you favor?
Riick is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > Avalon 3rd Generation (2005-2012)
User Tag List
Linear Mode Linear Mode
