89-93 Celica wheel hub replacement - Toyota Nation Forum : Toyota Car and Truck Forums
post #1 of 8 Old 04-12-2019, 07:47 PM Thread Starter
Quoted: 2 Post(s)
(Thread Starter)
The wheel bearing failed in my car today and I am trying to find a replacement hub. Threw it on the lift to replace the bearing and found that the hub itself is done. The spindle is fine but the hub shaft is done. Pressed it in and found the inner race on the back of the bearing is loose around the center. I reinstalled everything to get it off the lift and is driving ok for now, but I know that there will be premature bearing failure and it just isn't safe.
I searched online OE catalogs but it says NLA/Discontinued. No luck on RockAuto or Advance, EBay, etc. So does anyone know of where to buy or have one for sale?
L337TurboZ is offline
post #2 of 8 Old 04-12-2019, 11:00 PM
Toyota Collector
71Corolla's Avatar
Quoted: 2428 Post(s)
Did you call a dealer? Several online sources say 43502-20100 is available, that's the front you don't say if you need front or rear which I think is discontinued would need to source used on that.
2000 Lexus ES300 Millenium Edition
1990 Camry LE V6 Anniversary Edition 5-Speed
1990 Camry LE V6 WAGON
1987 Camry LE I4 5-Speed
71Corolla is offline
post #3 of 8 Old 04-13-2019, 01:10 AM
Senior TN Member
Quoted: 1830 Post(s)
Front available on ebay: https://www.ebay.com/itm/173816050540
DannoXYZ is offline
post #4 of 8 Old 04-13-2019, 07:46 AM Thread Starter
Quoted: 2 Post(s)
(Thread Starter)
The ebay linked is for a 5 lug mine is a 4 lug. I need a front hub. It is weird that site I went to showed NLA. I will check some local parts stores as most online stores for Advance, AZ all suck. Thanks for the response.
post #5 of 8 Old 04-14-2019, 03:39 PM
Senior TN Member
DannoXYZ is offline
post #6 of 8 Old 04-15-2019, 05:31 PM Thread Starter
Quoted: 2 Post(s)
(Thread Starter)
Got it sorted out. Since the 4 lug wheel hub was NLA I used a 1990 corolla DX hub and Celica bearing. Pressed in just fine. To wrap things up here is a list of whats needed for anyone who faces the same problem. Celica ST Wheel Bearing, Celica front and rear wheel bearing seals for the steering knuckle, 1990 Corolla DX Manual Transmission (not sure of difference between A/T and M/T) wheel hub.
The Following User Says Thank You to L337TurboZ For This Useful Post:
DannoXYZ (04-16-2019)
post #7 of 8 Old 04-15-2019, 05:33 PM Thread Starter
Quoted: 2 Post(s)
(Thread Starter)
The Corolla bearing itself is a little smaller in outer diameter than the Celica bearing which makes it incompatible with the Celica steering knuckle. The Corolla hub however has the same diameter and length as the Celica hub. Spline count matched up. I said eff it and tried it out and it works!
post #8 of 8 Old 04-16-2019, 03:29 PM
Senior TN Member
Awesome work and thanks for mix-n-match info!
DannoXYZ is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Celica Forum
User Tag List
Linear Mode Linear Mode
