Need Source for Rack and Pinion - Toyota Nation Forum : Toyota Car and Truck Forums
 1Likes
  • 1 Post By JohnGD
post #1 of 5 Old 07-12-2019, 03:16 PM Thread Starter
Senior TN Member
sdspeed's Avatar
Quoted: 356 Post(s)
(Thread Starter)
I have a 1993 N/A Mr2 that I need a rack and pinion assemble for. Noticed seal kits are still out there but I'm not finding a complete assembly. The shop that has taken care of it for over a decade plus installed the current one about 5 years ago. He'll warranty it but his original source doesn't have any either. Any ideas. Checked Rock Auto and the usual suspects but nada. Is there a difference between the Turbo equipped cars rack assembly vs. the N.A
TIA
sdspeed is offline
post #2 of 5 Old 07-13-2019, 01:12 AM
TN's Hapa Haole
MR2Jedi's Avatar
Quoted: 682 Post(s)
iTrader Score: 7 reviews
You'll probably have to buy a used one and rebuild it.
MR2Jedi is offline
post #3 of 5 Old 07-17-2019, 12:44 PM
Senior TN Member
Quoted: 1879 Post(s)
DannoXYZ is offline
The Following User Says Thank You to DannoXYZ For This Useful Post:
sdspeed (07-17-2019)
post #4 of 5 Old 07-17-2019, 03:09 PM Thread Starter
Senior TN Member
sdspeed's Avatar
Quoted: 356 Post(s)
(Thread Starter)
Thanks! Had checked with the local parts stores and when push came to shove the units aren't available thru them. Even the link showed it out of stock at O'Reily's. So far Detroit Axle is looking like the route to go even if I have to send my unit back to them and wait for it. It's "weeping" now so no panic just wanted to get ahead of it. I rebuilt a lot of aviation hydraulics over the years, since the seal kits are easy to get I may just do it myself. Only difference is on the aircraft gear I had a test bench
sdspeed is offline
post #5 of 5 Old 07-17-2019, 03:58 PM
イリジウム
Quoted: 1033 Post(s)
As long as the rebuild kit is the correct one.
I believe Cardone offers rebuild service, but turnaround can be a while. So if you have the correct seal kit, the unit is in shape for rebuild, and you can rebuild then that’s probably the best.
MR2Jedi likes this.
JohnGD is offline
User Tag List
Linear Mode Linear Mode
