2009 scion xb idle problem - Toyota Nation Forum : Toyota Car and Truck Forums
Scion xB 2nd Generation (2007+) Forum for the second generation xB
post #1 of 2 Old 06-08-2019, 06:04 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Hi
My idle around 500 _ 550 at stop while in drive but if i turn headlights on it goes to 620 650 then idles smooth. When i brake goes down little then comes back up. If i turn the ac on goes 750 800 rpm. I clean the throttle body twice. Changed pcv valve. New ground wires. Nothing help.no check engine light for ever. Any idea?
Byran is offline
post #2 of 2 Old 06-10-2019, 08:11 AM
Safe under my blankie..
HATEnFATE's Avatar
Quoted: 267 Post(s)
That's interesting. Usually it would be the other way around, Dropping RPM with a load because the idle-up isn't working properly.
Are you losing/burning any oil? maybe low compression or blow-by is causing the RPMs to drop while at an unloaded idle, and when you kick on accessories, the computer is making up the difference with the idle-up response?
This is PURE speculation and it's probably not it...but it's a thought with the 2.4L
Originally Posted by The ONCE-LER
"Unless someone like you cares a whole awful lot, nothing is going to get better, it's not."
HATEnFATE is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Division and International Models Forums > Scion Forum > Scion xB Forum > Scion xB 2nd Generation (2007+)
User Tag List
Linear Mode Linear Mode
