2007 Yaris Hatchback with no back up lights. - Toyota Nation Forum : Toyota Car and Truck Forums
Yaris/Scion iA, Vitz and Echo Forum Discussion area for all the Toyota Yaris/Scion iA, Echo, and Vitz owners worldwide.
post #1 of 10 Old 08-06-2017, 10:32 AM Thread Starter
I Like Traffic Lights !!!
05_Echo's Avatar
Quoted: 11 Post(s)
(Thread Starter)
Question 2007 Yaris Hatchback with no back up lights.
I have checked the bulbs, replaced the bulbs, checked the fuse and replaced the fuse and I still have no back up lights.
I'm am now doing the only thing left that I can do and thats stand at the back of my car, stare at the lights and scratch my head and wonder why my back up lights are not working.
Has anyone else had this problem (not the itchy head problem, the back up light problem?)
My Toyota's ..2006 YARIS RS .., 2006 Corolla LE
http://img.photobucket.com/albums/v280/Bart68/Sigs/corsig.jpg
05_Echo is offline
post #2 of 10 Old 08-08-2017, 08:35 PM
Quoted: 34 Post(s)
I would just back into any parking spots, that way you can just pull out without needing to reverse out - problem solved.
You replaced the fuse and bulbs, so that takes care of those legs, in this process of elimination. I would check the wiring, as much/far as you can from where it connects. It's affecting both, so find out where both/all back up lights "go to" wiring-wise. Hopefully the fault would be found from that point to the engine compartment.Maybe a relay or something, I'm not sure. From the echo repair manual--I know you have a yaris--but same troubleshooting steps would apply check the following:
1. GAUGE Fuse
2. Ignition Switch
3. Wire Harness
4. Bulb
* Therefore, see if there is another fuse to check that might be the culprit as well as the wiring. And, I guess the ignition switch. Hope that helps.
l33ch is offline
post #3 of 10 Old 08-08-2017, 08:42 PM
Bitter's Avatar
Quoted: 2066 Post(s)
Bitter is online now
The Following User Says Thank You to Bitter For This Useful Post:
l33ch (08-15-2017)
post #4 of 10 Old 08-08-2017, 08:45 PM
Quoted: 34 Post(s)
oh yeah, it could be his reverse switch if it's a stick, good point.
l33ch is offline
post #5 of 10 Old 08-13-2017, 09:58 AM Thread Starter
05_Echo's Avatar
Quoted: 11 Post(s)
(Thread Starter)
It has a 5 speed in it.
05_Echo is offline
post #6 of 10 Old 08-15-2017, 01:28 PM
Quoted: 34 Post(s)
https://www.toyotanation.com/forum/26...ht-switch.html
Might help you resolve if it's your reverse switch. Any updates?
l33ch is offline
The Following User Says Thank You to l33ch For This Useful Post:
05_Echo (05-01-2019)
post #7 of 10 Old 08-24-2017, 09:55 AM Thread Starter
05_Echo's Avatar
Quoted: 11 Post(s)
(Thread Starter)
I haven't had the time to take it in, I've poked and prodded everything to do with
the back up lights and nothing to be found so it has to be at the tranny.
05_Echo is offline
post #8 of 10 Old 08-25-2017, 11:06 AM
Quoted: 34 Post(s)
Don't take it in. They will charge you $$ for a 20 minute job. The reverse switch should be located near the top of the transaxle/tranny kinda right under the battery tray. It might be snugged in with a plate over it, just remove and unfasten the switch, put new one in, done. Save the $$ you saved to go out to dinner with with wife/kids or buy a new bong (I think I would buy a new bong). This is maybe 1-2 degrees harder--difficulty wise--than changing your own oil--if you are retired/disabled,etc, yeah ok--have someone else do it for you--but I still wouldn't take it to a shop, but have someone who is even mildly competent to put in in (neighbor car kid, car relative, etc).
I've been getting more into cars (I'm still in denial as I don't consider myself a car person), ever since around 10 years ago, and I already have made up my mind that I will never bring a car to a shop unless it truly is out of my skill level--and even then before getting to that point, I would have poked and prodded the issue before getting to that point--it's worth it. You get to know your vehicles more, and the pride that goes along with it. Also, scores of beautiful half naked women will randomly cling on your arm asking for money.
l33ch is offline
post #9 of 10 Old 04-05-2019, 08:43 PM
Quoted: 0 Post(s)
Thumbs up
this might be a little late seeing this is now 2019 but your problem lays right in the gear shifter (inside vehicle) underneath it there is a ball bearing there and it's not making contact have a look and slowly place it in reverse and hold it a few different ways and they will work perfect your shifter isn't grabbing it to make them stay on in reverse. and try to also visit the shifter cable running to the front of the tranny and make sure this is all in tact had this myself and the cable had busted off nd replaced it sometimes this is just off a touch and will cause reverse lights to not operate.
hope this helps somebody in 2019
Dave
Dave Ask if needed is offline
The Following User Says Thank You to Dave Ask if needed For This Useful Post:
post #10 of 10 Old 05-01-2019, 09:37 AM Thread Starter
05_Echo's Avatar
Quoted: 11 Post(s)
(Thread Starter)
Originally Posted by l33ch View Post
https://www.toyotanation.com/forum/2...ht-switch.html
Yup i never got the chance to fix the problem, a guy in a stolen truck ran a stop sign and I T-boned him,
good news is I have an Orange RS out the deal for half the money insurance paid me for my black one.
05_Echo is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Yaris/Scion iA, Vitz and Echo Forum
User Tag List
Linear Mode Linear Mode
