03' Echo Clutch cable help - Toyota Nation Forum : Toyota Car and Truck Forums
Yaris/Scion iA, Vitz and Echo Forum Discussion area for all the Toyota Yaris/Scion iA, Echo, and Vitz owners worldwide.
post #1 of 4 Old 01-02-2019, 07:55 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Unhappy 03' Echo Clutch cable help
Hey guys,
Could really use a hand here
I'm trying to do the clutch on my echo, HOWEVER i cant get these clips off the cables for the life of me. any suggestions?
I cant find anyone documenting the process on an echo at all.
EchoBOY03 is offline
post #2 of 4 Old 01-03-2019, 07:34 AM
Safe under my blankie..
HATEnFATE's Avatar
Quoted: 267 Post(s)
They just slide off, like e-clips.
It's hard to explain, but basically, you need to pull them straight up, away from the cable. You can get a pair of pliers on the lip of the clip and give it a side-to-side wiggle as you pull, they'll pop right off.
They're only held in place with Friction.
Originally Posted by The ONCE-LER
"Unless someone like you cares a whole awful lot, nothing is going to get better, it's not."
HATEnFATE is offline
post #3 of 4 Old 01-04-2019, 08:51 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
The clips ended up spinning to one end and pulling right out! 😂
I was able to get the trans dropped shorty after, thanks!
post #4 of 4 Old 01-04-2019, 03:53 PM
Quoted: 299 Post(s)
I think they are shifter cables, my clutch is hydraulic.
Old Mechanic is online now
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Yaris/Scion iA, Vitz and Echo Forum
Tags
cabel , clutch , echo , shifter , transmission
User Tag List
Linear Mode Linear Mode
