3.0 water pump or not - Toyota Nation Forum : Toyota Car and Truck Forums
4Runner 1st Generation (1984–1989) Discussion area for the first generation Toyota 4Runner.
post #1 of 4 Old 09-01-2018, 10:01 PM Thread Starter
894runnerr's Avatar
Quoted: 1 Post(s)
(Thread Starter)
Bought a 4runner with the owner telling me it had a blown head got it home took it to my mechanic and he said no blown head gasket(I planned on having the 3.4 swap done but supplying the engine). He said the radiator was leaking and that was causing it to over heat. Tonight I replaced the radiator, once it was installed I turned it on and my water pump was leaking. Now I’m wondering do I put the $350-$500 in it to have the water pump done just to find out the water wasn’t circulating enough to show a head gasket problem. Then I’m out $350-$500 which could’ve been almost 1/2 of a 3.4? Just getting some opinions.
894runnerr is offline
post #2 of 4 Old 09-02-2018, 10:45 PM
T100 Road Warrior...
BamZipPow's Avatar
Quoted: 904 Post(s)
Wink
...or you could do the water pump yerself and save the big bucks!
1998 T-100 SR5 2WD auto, Roadmaster Active suspension, dual oil catch jars, AC mod, aero cap, lower aero package, 67% grill block, aero single wheel trailer
BamZipPow is offline
post #3 of 4 Old 09-02-2018, 11:55 PM Thread Starter
894runnerr's Avatar
Quoted: 1 Post(s)
(Thread Starter)
Just curious have you done one and if so how big of a project is it?
post #4 of 4 Old 09-11-2018, 03:27 AM
BamZipPow's Avatar
Quoted: 904 Post(s)
Wink
Also, swapping in a 3.4 is more involved than yer allocating fer. Maybe 3-4 grand when all done and told? It's not a simple drop and bolt it in. You have the wiring harness and ECU to deal with. Fuel and exhaust mods to be performed. Air bag sensor to deal with. Have you noticed that the fuel tank is on the opposite side fer the 3.0 compared to the 3.4? Unless yer working on yer project daily, expect this project to take at least a couple of weeks if not a good month depending on how much time, energy, and finances you put towards it.
Video of water pump/timing belt replacement...
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 4Runner 1st Generation (1984–1989)
User Tag List
Linear Mode Linear Mode
