98 Toyota 4 runner v6 SR5 5 speed Busting back - Toyota Nation Forum : Toyota Car and Truck Forums
4Runner 3rd Generation (1996-2002) Discussion area for the third generation Toyota 4Runner.
View Poll Results: Any suggestions on problem with this vehicle
Clamped return fuel line did nothing 0 0%
put mid grade fuel nothing 0 0%
new timing belt 0 0%
acts like its starving for fuel 0 0%
Voters: 0. You may not vote on this poll
post #1 of 3 Old 06-30-2017, 06:15 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
USA 98 Toyota 4 runner v6 SR5 5 speed Busting back
98 Toyota 4 runner v6, replaced the following: wires, plugs, coil boots, gutted catalytic, new fuel filter, check fuel pressure (46-48 PSI), clean KN filter RESULTS: Accelerated 2,000, start busting back, crank good, idle perfect, no codes reading out. Do anyone have any ideas as to what is wrong with this vehicle? I have done everything to get it in perfect order and is now stumped. Your assistance on this would be greatly appreciated.[/SIZE]
msgoody69 is offline
post #2 of 3 Old 07-01-2017, 01:24 PM
Soylent Green sales
fourwd1's Avatar
Quoted: 560 Post(s)
Welcome to Toyota Nation.
First thing I'm going to do is move your question to the correct section.
The V6 in your truck is different from the V6 here in the 1st Gen section where you posted .
You have the 3.4.
_No THANKs necessary !
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline
post #3 of 3 Old 07-20-2017, 01:30 AM
T100 Road Warrior...
BamZipPow's Avatar
Quoted: 904 Post(s)
Wink
Welcome to the forums!
Best thing to do is to hook up a diagnostic OBDII data capturing reader with freeze frame so you can distinguish what is going on.
I'm not familar with the term yer using about busting back.
Is the ECU running in open loop when it is busting back? What is the timing reading? How about the other sensors like the MAF (is it clean), ECT, TPS, crank and cam sensors, etc reading at the busting back issue?
1998 T-100 SR5 2WD auto, Roadmaster Active suspension, dual oil catch jars, AC mod, aero cap, lower aero package, 67% grill block, aero single wheel trailer
BamZipPow is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 4Runner 3rd Generation (1996-2002)
User Tag List
Linear Mode Linear Mode
