2000 4Runner Brakes - Toyota Nation Forum : Toyota Car and Truck Forums
4Runner 3rd Generation (1996-2002) Discussion area for the third generation Toyota 4Runner.
 1Likes
  • 1 Post By steve108
post #1 of 8 Old 04-08-2019, 03:47 PM Thread Starter
GTJ's Avy
Quoted: 4 Post(s)
(Thread Starter)
2000 4Runner Brakes
Are there any upgrades for front brakes? About every six months the pedal start to pulsate and sink further down. Not many miles involved. It feels like the rotors are warping. Thanks for any advice!
71GTJ is offline
post #2 of 8 Old 04-09-2019, 05:25 PM
T100 Road Warrior...
BamZipPow's Avatar
Quoted: 904 Post(s)
Wink
How many miles do you have on the vehicle? What condition is the brake fluid? I would guess that the internal seals to yer master cylinder may be going bad. Probably could use a rebuild.
1998 T-100 SR5 2WD auto, Roadmaster Active suspension, dual oil catch jars, AC mod, aero cap, lower aero package, 67% grill block, aero single wheel trailer
BamZipPow is offline
post #3 of 8 Old 04-10-2019, 12:41 PM Thread Starter
GTJ's Avy
Quoted: 4 Post(s)
(Thread Starter)
Yeah BamZipPow, Just went over 251,000 miles. About 6 mos. ago had new front pads installed, rotors cut, rear shoes adjusted and brake fluid flush.
71GTJ is offline
post #4 of 8 Old 04-10-2019, 03:38 PM
イリジウム
Quoted: 1033 Post(s)
Every 6 months! Something isn’t right.
You might have 2 different problems at the same time, an old master cylinder and maybe seizing caliper piston or anchor pins causing pulsation.
What brands of rotors and pads are you using? Ever applied petroleum based brake lube like Permatex green or purple to rubber parts?
I’d check out parts on rockauto. Centric rotors and Akebono ProAct pads.
JohnGD is offline
post #5 of 8 Old 04-10-2019, 05:23 PM Thread Starter
GTJ's Avy
Quoted: 4 Post(s)
(Thread Starter)
I believe its still the original untouched master cylinder and calipers, not sure what brand rotors, they were replaced by a shop. So when approaching to a complete stop you can feel the unevenness of the rotor, if in fact are the rotors.
71GTJ is offline
post #6 of 8 Old 04-30-2019, 09:46 PM
steve108's Avatar
Quoted: 19 Post(s)
Tundra calipers and rotors are bolt on and bigger and much less prone to warping.
steve108 is offline
post #7 of 8 Old 04-30-2019, 10:09 PM
short-throw dipstick
Quoted: 1816 Post(s)
IIRC, all gen3 4Runners suffer from this due to a design defect that results in the pads being held too close, heating everything up and warping rotors.
That's the fix, replace calipers+bracket and backing plates (?) with ones from a gen1 Sequoia or Tundra.
00 Camry 5S-FE 184k smoooth
01 ES300 147k NEEDS TRANS WORK
01 Insight 137k BROKEN CAMSHAFT
02 Insight 178k DC-DC BELLY-UP
08 STS-V 67k 570 RWHP!
01 Viggen 112k 400 FWHP
insightbrewery is offline
post #8 of 8 Old 05-01-2019, 07:22 AM
steve108's Avatar
Quoted: 19 Post(s)
No need for bracket or backing plate.
The Tundra calipers come in two sizes, both will fit but the larger ones require trimming the backing plate. The smaller ones are purely bolt on (and still bigger than the 4runner). They are 4.7", come from a 2000-2003 Tundra or Sequoia, and have casting number s13we. You also need the corresponding pads and rotors. I believe you need a 16" or larger wheel, but I can't remember for sure.
96931R Rotors
RC11039/RC11040 Loaded calipers
FRC11039/FRC11040 Calipers & pick your own pads
insightbrewery likes this.
steve108 is offline
The Following User Says Thank You to steve108 For This Useful Post:
insightbrewery (05-01-2019)
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 4Runner 3rd Generation (1996-2002)
User Tag List
Linear Mode Linear Mode
