7th Gen Camry Highlander Brake Upgrade - Page 5 - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 7th Generation (2012-2017) Toyota Camry Discussion for years: 2012-2017
 15Likes
post #61 of 74 Old 12-16-2017, 05:52 PM
Quoted: 1 Post(s)
I checked on the front Highlander calipers and they are listed under two different part numbers. One is for made in Japan and the other is made in USA. Anyone know what if any is the difference and if they are interchangeable?
And has anyone tried this with the XLE 17" wheels?
masami is offline
post #62 of 74 Old 12-18-2017, 08:03 PM
Quoted: 21 Post(s)
The difference is the shape of the caliper - one sticks out a little more than the other. I can't remember which is which, but I'd get the one that sticks out less (you can tell by the pictures) just to be safe. You should be fine with XLE 17" wheels.
Paul1114 is offline
post #63 of 74 Old 01-07-2018, 06:41 PM
Quoted: 2 Post(s)
So you used 2011 highlander calipers and they worked?
Originally Posted by venza7 View Post
I make conversion to 11 Highlander and put 17" OEM Lexus IS wheels winter tires set . Space between brake caliper and rim 1/2 inch.
LowProCamry07 is offline
post #64 of 74 Old 01-26-2018, 12:23 AM
Quoted: 25 Post(s)
Are the front brakes overpowering? Does the car nose dive at all from just normal braking?
Boris Z is offline
post #65 of 74 Old 05-10-2018, 08:56 PM
venza7's Avatar
Quoted: 113 Post(s)
Sorry for late replay. Yes, they work fine.
venza7 is offline
post #66 of 74 Old 05-20-2018, 04:01 AM
Quoted: 57 Post(s)
I have had highlander (kluger in Australia) front disc / calipers for about 2years now on my 2007 V6. I also have a 2009 v6 with stock brakes. The big brake car does stop faster but it also has lowered springs, stiffer shock absorbers and 234/40/18 quite expensive tyres. It does not behave strangely or do anything surprising.
It was an easy job, everything just bolted on perfectly.
matt2grfe is offline
post #67 of 74 Old 05-20-2018, 10:41 AM
16' Camry SE & 18' Camry XSE
SKORPiO's Avatar
Quoted: 256 Post(s)
I bought used calipers on ebay for $45 each from 2013 highlander with 40k miles and drilled and slotted rotors with pads kit for $160. Still waiting for one caliper to arrive and I will disassemble and paint the calipers before install. I already dry fitted the caliper on passanger side and indeed it bolts on fine and even has same offset as original camry rotor. I will also try to smooth out the outside face of caliper and apply high temp stickers. Need to rice it up a bit
Thanks for this great idea! Every time my wife switches from her car to mine, she complains how she doesn't trust my brakes, that they are too weak comparing with her car.
Sent from my SM-G955U1 using Tapatalk
SKORPiO is offline
post #68 of 74 Old 08-29-2018, 03:11 AM
Quoted: 0 Post(s)
Did this upgrade two weeks and totally happy with it. I had trouble with brakes day one with the car get it at 28K miles. The brakes just were always underpowered and would slide during braking, getting into the car gap to quick. I constantly had to stomp on them late and cause car to dip in the front. I had to either get off the gas early, brake early, or harder. After long road trip driving the inside and outs of Yosemite, I had so much brake judder and vibration I knew I had to replace them and they were inadequate for my aggressive driving. At 52K they came out with old rotors still thick at 28mm, min is 25mm and pads still have 15K left.
It seems the original had too much pad dust buildup and it got caught in the crease of the pads. All the shims and pads lacked lubrication, both probably causing the judder.
Had new centric rotors, two rebuilt cardone calipers, and akebono pads out in the front. Calipers got trashed in shipping, so some of paint got chipped and one bleed nipple got clean broken off. I tapped the bleeder out and got a speed bleeders. Caliper was free for my trouble, so it was worth it. I wouldn't buy them again because the manufacturer packaging was piss poor it lets the caliper roll everywhere like shake and bake.
At first the brakes had more pedal travel but after bed in procedure and week of driving it improved. I didn't get rear brakes done, which might improve pedal feel once I replace them and do a complete bleed. The car
braking behavior has totally improved. I can control it so car doesn't slide into gap, it holds distance effortlessly. Car dips less and anytime I have to emergency brake, happens all the time with LA traffic, the car stops and maintains the gap, even increases distance with the car in front. I also get a happy backseat driver who doesn't comment as much on the tailgating.
ricecrispi28 is offline
post #69 of 74 Old 08-29-2018, 10:10 PM
SKORPiO's Avatar
Quoted: 256 Post(s)
I'm happy with mine also. After about 800 miles they became much more responsive, almost on a touchy side. All in all I love them. Well worth the effort.
SKORPiO is offline
The Following User Says Thank You to SKORPiO For This Useful Post:
Cedric Codrington (09-02-2018)
post #70 of 74 Old 01-23-2019, 01:22 AM
Quoted: 27 Post(s)
Originally Posted by 2quik4u View Post
The calipers from the 08-14 highlander are the exact same as the 2010-14 RX350 and RX450. Even the Sienna mini van uses the same calipers from 2011+. I agree these brakes should be standard at least on the V6 with all the extra weight it carries up front.
So the following two part numbers should work on 2012 Camry xle?
47730-0E031
47750-0E031
Part numbers for Highlander
47750-48110 Left
47730-48150 Right
Sent from my Pixel 3 using Tapatalk
silento is offline
post #71 of 74 Old 01-30-2019, 07:35 PM
Quoted: 27 Post(s)
Finally got it done. Thanks Op!!
2017 Sienna Calipers
EBS USR Rotors
Akebono Pads
Cedric Codrington likes this.
silento is offline
post #72 of 74 Old 01-31-2019, 07:31 AM
SKORPiO's Avatar
Quoted: 256 Post(s)
Enjoy. There is couple of us who did this conversion. I love the feel od brake pedal now.
SKORPiO is offline
post #73 of 74 Old 04-10-2019, 06:14 PM
Quoted: 131 Post(s)
For those looking to do this... I searched (randomly) under 2012 Highlander 3.5 on RockAuto
I'm thinking I'm going to have to pull the trigger on this one, as they sell a PowerStop Kit which includes reman calipers, rotors & pads! What a great idea. Cheap, it was 350$ CAD
I've used powerstop in the past and wouldn't hesitate again... so, this conversion just got easier? lol
01lexpl is offline
The Following User Says Thank You to 01lexpl For This Useful Post:
Cedric Codrington (05-26-2019)
post #74 of 74 Old 06-03-2019, 04:59 AM
Quoted: 4 Post(s)
I just bought and installed this upgrade bought from rockauto. Install was pretty straight forward except for one minor issue that had me banging my head against a wall. The screws in the caliper bracket were installed wrong from the manufacturer and lead to sticking brakes. The longer screw which should have been installed in the top hole was installed in the bottom. I figured this out after about an hour of going through every minute detail of my install of each component. Such a simple error that lead to a headache but other than that, great improvement in braking.
Sent from my iPhone using Tapatalk Pro
Cedric Codrington is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 7th Generation (2012-2017)
User Tag List
Linear Mode Linear Mode
