2012 new brakes squeak - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 7th Generation (2012-2017) Toyota Camry Discussion for years: 2012-2017
 4Likes
  • 1 Post By tpence2177
  • 1 Post By Greasymechtech
  • 1 Post By bionictony
  • 1 Post By Jake Kilton
post #1 of 14 Old 05-26-2019, 11:00 AM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
2012 Camry LE
I initially replaced my brakes several months ago because they were pulsating, kinda shakey, when stopping, like the rotors were warped. I replaced all 4 sets of pads, and all 4 rotors with parts from Advance auto. I chose advance auto because you can get 20% off literally everything by placing the order online with a special promo code, then picking them up in store. After that job, the brakes began to squeak when pressed. I thought it was cheap parts from advance, so i slowly switched EVERYTHING over to parts from O'riellys. (did the fronts one week, the rears a different week, as money allowed) The squeak did not go away, it just moved around. I then read its possibly the cheap organic pads i was using, so i switched to ceramic pads. Again, still squeaking, just moved from one tire to another...
So after replacing my brakes 3 times within a couple months, theyre still squeaking when used. They dont squeak when you press on them very lightly, or very hard. But the average "slow down to the red light" press causes a nice looong high pitched squeak. And its getting worse as time goes on.
Can anyone offer some advice on this?
Jake Kilton is offline
post #2 of 14 Old 05-26-2019, 12:02 PM
Quoted: 225 Post(s)
Did you use anti squeak grease on the back of the pads? Or break them in properly?
Sent from my iPhone using Tapatalk Pro
tpence2177 is offline
post #3 of 14 Old 05-26-2019, 12:18 PM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
since there is no movement between the pad and caliper, i did not grease the backs of the pads. I did grease the tops and bottoms, and the slides they move back and forth in though. I was not aware there was a break in procedure. I cant count how many times ive replaced brakes in my life, and i have never done any kind of break in procedure, and have never had this problem before. But, im here to learn... Tell me more about this procedure..
post #4 of 14 Old 05-26-2019, 01:09 PM
Quoted: 225 Post(s)
Iíve always greased the back of pads with the shims on there and have never had any problems with a squeak. Donít know if you noticed but the factory pads have the grease on the back too. from memory brake break in is where you get up to around 30mph or so and slam on the brakes several times to ďseatĒ them into the rotors. You want to get them pretty warm and then use regularly. Sometimes just regular use can make the pad crystallize and not function properly if they arenít broken in. Have always broken them in as well so not sure which helps the most the grease or the breaking pads in.
Edit: here is an article you may want to read. I donít do this aggressive of a technique. Usually 4-5 hard stops works for me. Biggest thing is donít come to a complete stop and sit while the brakes are very hot or you will have shaking again very soon.
https://brakeperformance.com/bedding-in-rotors.php
sethr likes this.
post #5 of 14 Old 05-26-2019, 02:26 PM
Senior TN Member
Quoted: 679 Post(s)
Measure runout of rotors?
Every contact point needs appropriate grease or what I never use...antiseize
I don't use or recommend generic parts but have never had a problem installing AutoZone/Advance Auto/Napa/O'Reilly parts. So, repeating issue is an installer installation problem.
How many times do you want to do the brake job incorrectly with either bad parts or by taking shortcuts before you get it right?
Live with the squeak as a reminder!
sethr likes this.
So many trolls so little time
Greasymechtech is online now
post #6 of 14 Old 05-26-2019, 03:55 PM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
rotor runout not being good seems like it would cause more of a problem you can feel, than a problem you can hear. Maybe my mind is foggy from the weekend, but im not sure im clear on what youre getting at... Are you suggesting that i grease the back of the pads where it seats against the caliper?
post #7 of 14 Old 05-26-2019, 04:46 PM
Quoted: 5 Post(s)
You need to take the shim off, clean it out and pump out grease bag (included inside brake pads box) between shim and back of brake pad.
syncreation is offline
post #8 of 14 Old 05-26-2019, 05:19 PM
Quoted: 43 Post(s)
I've never had to do "break in" procedure when changing the last 100 sets or so of pads. I do make sure not to brake too hard during the first couple of days if possible though. If you don't , the rotors will heat up and may warp.
The squeak is usually from semi metallic pads or cheap versions of ceramic which have metal in them rubbing against the metal rotor. Cheap organic pads just wear quickly and create lots of brake dust. Ceramic is your best bet though these days.
When you felt your shaky shaky when braking before, you just needed new rotors and could have reused your pads if they were still good.
I would try a different better quality ceramic brake pad and your squeaking should go away. I doubt it's the lack of grease on your pads as your noise is while your pressing the pedal and not just an odd squeak.
Also, you should always give your new pads a week to break in before you decide to change them. They might squeak for a few days , then ok....
2006 Corolla
2008 Limited Rav4 I4
2017 Camry
Kevin
kevcules46 is offline
post #9 of 14 Old 05-28-2019, 05:16 PM
Quoted: 76 Post(s)
did you wash the rotors off before installing? they are coated with machine oil to prevent rust at the factory. i replaced mine on the venza with centric premium rotors and raybestos EHT pads and there is no noise at all. i didn't even use grease on the clips or backing. i just wire brushed the area on the caliper to remove built up dust before attaching the clips in. i have no nose at all. what brand specifically did you use? i would try raybestos EHT. it can be purchased from rock auto for cheap.
sethr likes this.
bionictony is offline
post #10 of 14 Old 05-29-2019, 07:37 AM
Photojournalist
sethr's Avatar
Quoted: 503 Post(s)
I use raybestos ceramics never had a squeak. They are full kits and grease.
Kits give you grease for a reason.
If the factory did it, do it.
Sent from my PH-1 using Tapatalk
12 LE: LED mods-frnt grille paint to match-spkr upgrades-MB wheels-black chrome
sethr is offline
post #11 of 14 Old 06-08-2019, 10:41 AM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
Just wanted to follow up.. I was able to fix the problem, doing it in a manner that seemed very wrong, but it worked. i basically got the car up to speeds that arent even legal on interstates, then slammed on the brakes bringing the car down to 10-20mph. I did this several times in a row. Apparently got the brakes so hot that when i stopped at a red light right after, they smelled so bad i could have swore they were smoking. But they werent. Like i said, probably the wrongest way possible, but idgaf, i was at witts end, this worked, and the actual performance of the brakes was not affected. The brake pedal has the same exact sensitivity as before and the car still stops perfectly on a dime.
to answer the question above, yes, i always clean rotors with contact cleaner before installation
tpence2177 likes this.
post #12 of 14 Old 06-09-2019, 05:43 PM
Quoted: 43 Post(s)
Probably not the right way, but in the end, it worked. Good job.
2006 Corolla
2017 Camry
Kevin
post #13 of 14 Old 06-09-2019, 09:43 PM
Quoted: 225 Post(s)
Glad everything worked out
post #14 of 14 Old 06-15-2019, 09:15 PM
Quoted: 57 Post(s)
Do this, it often fixes squeaks
matt2grfe is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 7th Generation (2012-2017)
User Tag List
Linear Mode Linear Mode
