Dodge Caravan Rim on 2013 Camry?? - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 7th Generation (2012-2017) Toyota Camry Discussion for years: 2012-2017
post #1 of 3 Old 06-26-2019, 09:08 AM Thread Starter
Quoted: 3 Post(s)
(Thread Starter)
I have a 2013 Camry LE (16" steel wheels). My friend is junking his 2003 Dodge Caravan with 16" steel wheels.
I was thinking of taking one of his wheels as a full size spare for my Camry. Can I do this?
The rim size and bolt patterns appear to be the same, but the positive offset and center bore are different (the Caravan's is bigger).
Camry positive offset is ET40 and center bore is 60.1mm
Caravan positive offset is ET45 and center bore is 71.6mm
Camry wheel info is at https://www.wheel-size.com/size/toyota/camry/2013/
Caravan wheel info is at https://www.wheel-size.com/size/dodge/caravan/2003/
This will be a spare so its use on the car will be very limited, but I could need to drive a long distance on it if I'm unfortunate enough to need it far from home.
Would this be safe to use? Would it even fit?
ftres is offline
post #2 of 3 Old 06-26-2019, 09:22 AM
Senior TN Member
Vangm25's Avatar
Quoted: 744 Post(s)
If the center bore is bigger than what you got, then you CANNOT use it.
Vangm25 is offline
post #3 of 3 Old 06-26-2019, 09:40 AM Thread Starter
Quoted: 3 Post(s)
(Thread Starter)
OK. Thanks for the reply.
ftres is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 7th Generation (2012-2017)
User Tag List
Linear Mode Linear Mode
