2013 Camry Se radio screen going white need replacement alternatives - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 7th Generation (2012-2017) Toyota Camry Discussion for years: 2012-2017
 1Likes
  • 1 Post By Pvt-Public
post #1 of 7 Old 07-11-2019, 10:19 AM Thread Starter
Sweetnsouthern84's Avatar
Quoted: 0 Post(s)
(Thread Starter)
I want to buy a used upgraded stock radio with Entune to replace my stock radio that's on the fritz but I don't know the correct part ID so I can just plug and play.
Sweetnsouthern84 is offline
post #2 of 7 Old 07-11-2019, 10:54 AM
Senior TN Member
Vangm25's Avatar
Quoted: 765 Post(s)
Have you looked at a Toyota Parts Website?
Vangm25 is online now
post #3 of 7 Old 07-11-2019, 11:20 AM
Captain Camry
CorollaPants's Avatar
Quoted: 73 Post(s)
Also, the part number is on your (current) stereo. But if you're going to go through that hassle, seriously consider an aftermarket. Pioneer is phenomenal. I was so glad to ditch Entune. Better sound quality by a mile and the way it manages MP3 folders is intuitive and easy to use. There's 101 posts about what you'll need to do. Installing an aftermarket requires a bit more work, but the payoff is huge. Add GPS and Android while you're at it too!
Check out this forum for some aftermarket discussion:
https://www.toyotanation.com/forum/3...l#post14034106
And add this for video playback when not in park:
Amazon Amazon
2015 Camry SE
CorollaPants is offline
post #4 of 7 Old 07-11-2019, 10:52 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Is there a way to find my Radio ID#/Part # without taking anything apart first to find out which one I have?
post #5 of 7 Old 07-12-2019, 03:36 PM
Senior TN Member
Pvt-Public's Avatar
Quoted: 234 Post(s)
For the amount of $ you'll spend to get an exact replacement you can probably get a much better unit set up with all the connections from Crutchfield. Give them a call absolutely nothing to lose. And the call is free.
https://www.crutchfield.com/S-SiVSAUX5H5b/
phoenixgreg likes this.
2013 Camry XLE 3.5L A/T
2017 Camry LE 2.5L A/T
Pvt-Public is offline
post #6 of 7 Old 07-12-2019, 04:01 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I don’t want aftermarket radios just stock
post #7 of 7 Old 07-12-2019, 10:35 PM
Senior TN Member
Vangm25's Avatar
Quoted: 765 Post(s)
Look at a Toyota Parts Diagram from almost any vendor and you will get the most up-to-date model of your stereo. I plan on buying at least six used ones before I finally get an aftermarket stereo. In addition, if you want to go from a stock to a "premium" OEM headunit, there is gonna be a lot more to do than just a plug-n-play.
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 7th Generation (2012-2017)
User Tag List
Linear Mode Linear Mode
