what is purpose of this rd lense? Int. rear doors. - Toyota Nation Forum : Toyota Car and Truck Forums
Avalon 4th Generation (2013-2018) Specific discussion of the fourth generation Toyota Avalon
 1Likes
  • 1 Post By pianewman
post #1 of 14 Old 06-10-2019, 08:49 AM Thread Starter
Quoted: 24 Post(s)
(Thread Starter)
The front and passenger door are clear and light up.
But what is the purpose of these?
I pulled one out yesterday and there is nothing behind it. No bulb or wiring.
Hybridgrl92 is offline
post #2 of 14 Old 06-10-2019, 08:55 AM
Quoted: 174 Post(s)
Reflector, when you're on the side of the road, so cars can see the open door.
2014 AvalonHybrid Limited
2015 Nissan Leaf S
2013 Ford CMax SEL
2017 Ford Fusion Energi Titanium
pianewman is offline
post #3 of 14 Old 06-10-2019, 09:24 AM
Senior TN Member
Vangm25's Avatar
Quoted: 761 Post(s)
Reflective lenses for when people can't see your opened door.
Vangm25 is offline
post #4 of 14 Old 06-10-2019, 09:40 AM
BeerSteakTxas
molson.david's Avatar
Quoted: 43 Post(s)
iTrader Score: 8 reviews
I'm not sure about reflective capabilities of this reflector. It's pretty small, positioned very low and based on what I've seen doesn't reflect much. Imo it was destined as a lens for the light, like on EU cars but for some reason engineers scrapped this idea.
2017 Avalon XLE premium
molson.david is offline
post #5 of 14 Old 06-10-2019, 10:16 AM Thread Starter
Quoted: 24 Post(s)
(Thread Starter)
Blah...
Why didn't they just run a wire and bulb to it.
I wonder how difficult it would be to run a wire to this housing and make it functional?
post #6 of 14 Old 06-10-2019, 10:50 AM
Quoted: 174 Post(s)
Originally Posted by Hybridgrl92 View Post
Blah...
$$$...every little bit of cost-cutting helps. Whoever designed the reflector/light into the door design lost out when it came time to FUND the wiring/bulb socket/bulb/install cost. ALL manufacturers do similar things.
I'll bet someone here has installed the wiring and bulb...for me, it's not worth the time/effort/cost.
Vangm25 likes this.
2015 Nissan Leaf S
2013 Ford CMax SEL
post #7 of 14 Old 06-10-2019, 11:50 AM
BeerSteakTxas
Quoted: 43 Post(s)
Blah...
Not difficult at all. Run a wire from a door trigger and find a suitable bulb holder or a small LED plate.
post #8 of 14 Old 06-10-2019, 11:54 AM
BeerSteakTxas
Quoted: 43 Post(s)
+1 I played with my headliner a few days ago and looks like whoever destined the headliner and sunroof lost out as well and lost out big time, when it came to funding.
post #9 of 14 Old 06-10-2019, 12:31 PM
Quoted: 8 Post(s)
I stuck 6 inches of Red DOT reflective on the side of the door. When get round to it I will put some along the bottom too.
2013 TAH Limited 120k mi
Dan Raff is offline
post #10 of 14 Old 06-16-2019, 09:34 AM
ToyoJim's Avatar
Quoted: 154 Post(s)
The diagrams show these modules as being lighted on the gen 4 Avalon Limited hybrid but not on less expensive trims.
Of course there is no wiring for rear door lights on lower trims but the part numbers for the lenses and bulb holders for all the door lights for the Limited hybrid are as follows:
81080N LAMP ASSY, INTERIOR ILLUMINATION, NO.1
81080-07020
81362B LENS, INTERIOR ILLUMINATION LAMP
81362-07040 FRONT RH
81362-07050 FRONT LH
81362-07060 REAR RH
81362-07070 REAR LH
If you want some blazingly bright flashing amber warning/safety lights that come on when you open your front doors check out these from MIT: https://www.ebay.com/itm/MIT-TOYOTA-...0AAOSwB-1Yt8oV
These warning lights come in pairs - one for each front door - but I installed them only on our driver doors since that is where we are exposed when we parallel park on dark streets at night. I didn't see any point in installing them on our front passenger doors although doing that might be useful for those who parallel park on the left side of a one-way street. For some reason, the MIT product for the 2010-2015 Prius is less expensive but it "might" be the same product since the cheaper one for the Prius fit our Sienna Limited.
Original owner of 2012 Prius v Five and 2014 Sienna Limited - both Blizzard Pearl with Advanced Technology Package
ToyoJim is offline
post #11 of 14 Old 06-16-2019, 10:11 AM
PJSMITH
pjsmithres's Avatar
Quoted: 344 Post(s)
Mine are lighted
Phil
2014 Avalon Hybrid Limited (TECH) 75K miles
2012 Volvo S60 T5 (Pumpkin)
2005 Triumph Rocket III
Completely Retired
pjsmithres is offline
post #12 of 14 Old 06-16-2019, 11:27 AM Thread Starter
Quoted: 24 Post(s)
(Thread Starter)
81080-07020
81362-07060 REAR RH
81362-07070 REAR LH
Does these door warning lights have to flash?
When installed do they replace the door light on the bottom of the door?
Or can the be connected with the door lights do both light up on the door?
post #13 of 14 Old 06-16-2019, 12:36 PM
ToyoJim's Avatar
Quoted: 154 Post(s)
The MIT warning lights do not replace or affect the operation of the existing lights at the bottom of the doors.
The MIT warning lights have an in-line module in their wiring harness that causes them to flash at about the same rate as emergency flashers. There is no provision for turning the flashing off. I don't think I would want them if they didn't flash.
These door open warning lights replace the round plastic plug on the rear edges of the front doors. A YouTube video shows the warning lights on a Sienna:
Installation requires removing the door trim panel - easy to do but I've removed a lot of them and have the right tools.
There are at least three versions of this MIT product. The version for Toyotas with existing courtesy lights at the bottom of the front doors is the easiest to install since the MIT wiring harness connects to the existing courtesy light harness. In this version, the MIT amber light flashes only when the door is open - not like in the YouTube video which shows a more expensive and difficult to install product version that is sold for less expensive Toyotas that have reflectors instead of courtesy lights at the bottom of their front doors.
These door open warning light may not be beneficial for others as much as for us, e.g. we parallel park on a limited visibility sharp curve on a narrow street every time we pick up our mail from a community mailbox.
ToyoJim is offline
post #14 of 14 Old 06-16-2019, 09:39 PM
Quoted: 174 Post(s)
Hmm...my 2014 TAH Limited does NOT have lights in the rear door reflectors. Another example of manufacturers de-contenting cars during production...to save costs...
2015 Nissan Leaf S
2013 Ford CMax SEL
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > Avalon 4th Generation (2013-2018)
User Tag List
Linear Mode Linear Mode
