UPDATE: completed:Map light bulb-How to remove - Toyota Nation Forum : Toyota Car and Truck Forums
Avalon 4th Generation (2013-2018) Specific discussion of the fourth generation Toyota Avalon
post #1 of 10 Old 06-15-2019, 08:50 AM Thread Starter
Quoted: 24 Post(s)
(Thread Starter)
Trying to remove the overhead map light bulb.
I got the cover off but how the heck do you get the bulb out?
Is there a tool to get in there to pull it out?
Almost impossible to pull out even with my tiny fingers.
UPDATE: Got it done. Had no luck with trying to wrap a wire or zip tie.
No matter what I did to zip tie I could not get it tight enough to not slip off when pulling.
Ultimately I went for the pliers. It was a little risky. But with just a little bit of wiggling it came out with no problem.
Hybridgrl92 is offline
post #2 of 10 Old 06-15-2019, 09:07 AM
Quoted: 9 Post(s)
Toyota Avalon Map Light Bulbs Replacement Guide
2014 Avalon Limited, w/Tech Package
konobi is offline
post #3 of 10 Old 06-15-2019, 10:01 AM Thread Starter
Quoted: 24 Post(s)
(Thread Starter)
hmmm
keeps slipping out of the zip tie.
post #4 of 10 Old 06-15-2019, 10:12 AM
Quoted: 126 Post(s)
Wash zip tie with strong detergent to remove mold release?
Silicone RTV on zip tie, let it sit long enough for the RTV to cure? Fast-drying alternative: shellac.
Deeply scratch the zip tie interior with rough sandpaper?
Small rubber band wrapped near the end of the bulb, zip tie further inboard?
Use big chunky rubber band instead of zip tie?
Length of 3/8" ID plastic tubing, dipped in hot water to make it as pliable as possible, wait a few seconds for it to cool?
01 Avalon XL
03 Avalon XL
OleAvalon is offline
post #5 of 10 Old 06-15-2019, 10:48 AM
Quoted: 36 Post(s)
Get same tape, wrap around the bulb and it'll easily pull out
PAST: 2002 Nissan Sentra GXE 5SPD I 2003 Honda S2000 I 2001 Toyota Highlander V6 AWD
CURRENT: 2014 Porsche Cayenne V6 I 2018 Honda Civic Type R
9009RPM is offline
post #6 of 10 Old 06-16-2019, 11:14 AM Thread Starter
Quoted: 24 Post(s)
(Thread Starter)
I ended it using a pliers..
Was just careful. Instead of pulling I just got a firm grip and wiggled.
I plan to do the vanity mirror bulbs today.
I'm debating if I will keep them in the front map lights.
They are almost to bright.
File Type: jpg 0C9484B9-44F5-4DBC-8EA9-765D6B003DB3.jpg (723.7 KB, 11 views)
File Type: jpg 603D2717-C8BF-4CDE-B36C-F39E2F5D8847.jpg (690.0 KB, 10 views)
File Type: jpg D1216144-8BC7-4248-A9BD-6A802D733D32.jpg (1.01 MB, 10 views)
File Type: jpg EE29B82E-43F2-4821-9977-8F6D38FA5255.jpg (840.5 KB, 8 views)
File Type: jpg F31E7C1D-030C-4B96-AE52-BD5614A8600E.jpg (1.02 MB, 9 views)
post #7 of 10 Old 06-16-2019, 04:29 PM
Quoted: 18 Post(s)
Did you try to used a rubber ended fuse removal tool ?
2013 Toyota Avalon Hybrid XLE Touring
1999 Toyota Avalon XLE Plat. Edition
TheMiz is online now
post #8 of 10 Old 06-16-2019, 09:25 PM
PJSMITH
pjsmithres's Avatar
Quoted: 344 Post(s)
use duct tape. apply end of tape to both sides of the bulb. Came right out
Phil
2014 Avalon Hybrid Limited (TECH) 75K miles
2012 Volvo S60 T5 (Pumpkin)
2005 Triumph Rocket III
Completely Retired
pjsmithres is offline
post #9 of 10 Old 06-19-2019, 03:32 PM
Quoted: 58 Post(s)
I wrapped a pair of small needlenose pliers with electrical tape and pulled the bulb right out when I did mine.
2014 Avalon XLE Premium
Oh La La Rouge Mica (Almond)
Remote Start, Paint Protection, Rear Bumper Applique, Lower Body Moldings, Painted Mudguards
John in FL is offline
post #10 of 10 Old 07-15-2019, 09:20 PM
Quoted: 4 Post(s)
I couldn't get mine out either. So my buddy who is a body and fender man took them out for me in just a few seconds....same as you he wiggled it out with pliers
He says the secret is to wiggle back and forth.
2018 Avalon XLE
Chicago
bluelava22 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > Avalon 4th Generation (2013-2018)
User Tag List
Linear Mode Linear Mode
