2017 AWD XLE - New Tires - Bridgestone Ecopia to Hankook Dynapro ATM - Toyota Nation Forum : Toyota Car and Truck Forums
Highlander 3rd Generation (2014-2019) Forum dedicated to the discussion of 3rd generation Toyota Highlanders.
 6Likes
  • 6 Post By cor
post #1 of 14 Old 01-09-2018, 03:35 PM Thread Starter
cor
Quoted: 8 Post(s)
(Thread Starter)
A lot of tire post question come and go so I thought I would add my experience. There probably aren't many highlanders on all terrain tires! My 2017 AWD highlander came with bridgestone ecopia tires which have been really bad on ice and snow. My previous vehicle was a 2009 yukon that had hankook dynapro atm tires that performed great. I didn't want to swap to snow tires so I went with the same tires I loved previously. They are a 255 width as they aren't made in a 245 that the OEM 18"s are. No regrets!
On with the pics:
Click image for larger version
ID:	180082   Click image for larger version
ID:	180090   Click image for larger version
2011 Avalon Limited | 2017 Highlander AWD XLE
cor is offline
post #2 of 14 Old 01-09-2018, 03:38 PM
Soylent Green sales
fourwd1's Avatar
Quoted: 560 Post(s)
They look good !
_No THANKs necessary !
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline
post #3 of 14 Old 01-11-2018, 08:19 AM
Senior TN Member
Quoted: 503 Post(s)
Cor....Recall sometime ago, member here installed HKDP's on their HL. I assume tread design gives better traction in snow, but on ice ? Notice any changes like road noise, handling, stopping etc VS oem tires. Tnx
2014 HL Blizzard Pearl XLE AWD V6 Ash Int. M. Latitude Tour 245/60R18. OEM Tow hitch/4 pin. B/D 04/14
BUFFO is offline
post #4 of 14 Old 01-11-2018, 08:54 AM Thread Starter
cor
Quoted: 8 Post(s)
(Thread Starter)
We just got about 6"s of snow overnight and the snow traction is much better. Stopping on ice is better as well but the highlander has overly aggressive anti lock breaks imo. An example of the better traction would be backing out of a parking spot and having the front end skip while turning, the new tires no longer do this. The road noise is definitely higher and the ride was stiffer until I aired them down into the mid 30s instead of low 40 psi. The driving dynamics feel exactly the same with city driving as well as on the interstate. No regrets at this point!
cor is offline
The Following User Says Thank You to cor For This Useful Post:
BUFFO (01-11-2018)
post #5 of 14 Old 01-11-2018, 11:30 AM
2014 Highlander V6 2WD LE
Phil Indeblanc's Avatar
Quoted: 1703 Post(s)
Not sure about AT tires, but above 40psi is kinda pushing it. There is a tire thread that someone posted in, and it shows the loss of traction with increased air pressure. This is not good for braking and handling. It can be dangerous. I mention just in case its something overlooked.
I have found with little testing, but some deductive reasoning that 37psi to be a pretty good spot (give or take 1psi) for a balance of grip, even wear, noise, mpg and such on the Michelin Latitude OE tires and the Pirelli Verbe Scorpions (I much prefer the Scorpion over the Latitude in noise and grip. *Wear life yet to be seen).
_____________
2014 Highlander LE-V6,FWD, XD-HID&LED, StereoUpgrade, Airfreshner-Cedar
Phil Indeblanc is offline
post #6 of 14 Old 01-12-2018, 05:58 AM
Quoted: 2 Post(s)
On with the pics:
This is great, i posted a thread inquiring about 255 on our HL'S seemed no one knew if the fit without rubbing. Im glad you did it because i pick my HL up today from the dealer (just orderd it) and already have some 255 AT tires on the way to be swapped out. Thanks for the reasurance. This is the look im going for.
TwzteD is offline
post #7 of 14 Old 01-12-2018, 08:30 AM Thread Starter
cor
Quoted: 8 Post(s)
(Thread Starter)
Also to note, if you actually use a tire size calculator comparison the height difference is about 1% . Comparing the speedo to GPS while doing 75mph the speedo would register almost 2 mph slow. With the slightly larger tires its probably .5mph off.
The tire size is very similar.
cor is offline
post #8 of 14 Old 01-13-2018, 08:29 AM
Quoted: 75 Post(s)
I was wondering if anyone has tried fitting a 265/60-18 tire. It comes up as an option on some tire sites, and there are a ton of options in this size. They are about .9" bigger in diameter, and many tires have deeper tread. Michelin Defenders have 10.5/32 deep tread in the standard size and 12/32" tread in this size, and the life rating goes from 720 to 800. Plus I bet it just looks better!
Craig3277 is offline
post #9 of 14 Old 01-16-2018, 09:09 AM
Huskydog's Avatar
Quoted: 35 Post(s)
I'm running 265 40 22, outer diameter of 30.3", with no issues. When I get new tires for my stock rims I'll go with 265 60 18 (30.5").
2015 Highlander XLE Nautical Blue, 22x9 STR 607's
Huskydog is online now
post #10 of 14 Old 02-07-2018, 02:51 PM
Quoted: 7 Post(s)
On with the pics:
They look great. Now that you have had them for while, any rubbing issues?
yo miler is offline
post #11 of 14 Old 02-07-2018, 02:58 PM Thread Starter
cor
Quoted: 8 Post(s)
(Thread Starter)
No problems with rubbing and no regrets at all!
cor is offline
post #12 of 14 Old 02-07-2018, 08:04 PM
Senior TN Member
Quoted: 503 Post(s)
HKDPs 255/60-18
Road noise (sound heard inside) from my oem tires increases/decreases, depending on road surface. Increase in noise is definitely louder on rough surface VS smoother. Just wondering do u notice same or just road noise higher regardless of road surface with HKDPs? Tnx.
BUFFO is offline
post #13 of 14 Old 02-08-2018, 08:32 AM Thread Starter
cor
Quoted: 8 Post(s)
(Thread Starter)
I haven't really noticed a different in road noise on different surfaces. Overall I have gotten pretty used to the different in road noise from the OEM to these tires.
cor is offline
post #14 of 14 Old 04-18-2019, 08:13 PM
Jaspher's Avatar
Quoted: 2 Post(s)
I currently have 265/60/18 Michelin Latitude Tour HP installed with a matching spare that fits underneath.
ID:	238346   Click image for larger version
2018 Highlander Hybrid XLE (Blizzard Pearl)
2012 Rav4 4WD Touring Package with heated leather seats (Barcelona Red)
Jaspher is offline
The Following User Says Thank You to Jaspher For This Useful Post:
theroadsouth (05-02-2019)
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Highlander Forum > Highlander 3rd Generation (2014-2019)
User Tag List
Linear Mode Linear Mode
