Where is seatbelt chime option in Techstream v12.30.017? - Toyota Nation Forum : Toyota Car and Truck Forums
Highlander 3rd Generation (2014-2019) Forum dedicated to the discussion of 3rd generation Toyota Highlanders.
 5Likes
post #1 of 20 Old 08-20-2018, 09:00 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Greetings:
I just purchase mini VCI on **Removed**. Techstream v12.30.017 64 bit was installed in my Windows 10 home laptop. When I connect the device to my 2017 Highlander V6 LE, AT, the software doesn't detect the VIN, model, year etc. After manually inputting all data, make, model, year, engine, options etc I look everywhere and can't find the seatbelt chime option. Any idea?
Thanks in advance for your time and help.
njchen24 is offline
post #2 of 20 Old 08-20-2018, 10:06 AM
Got Pyro?
funman1's Avatar
Quoted: 829 Post(s)
Is it even connecting? It does not sound like it's communicating with the vehicle, and if it's not communicating with the vehicle you won't be able to see or do anything.
Did you get a version rated for 64bit? Most copies require you to use a 32 bit operating system (Like Windows XP)
I had to put mine on an old Windows XP laptop and it does great there but it won't run on my windows 10 machines because it's 64 bit
Professional Pyro..
No really; I get paid to blow stuff up...
funman1 is offline
post #3 of 20 Old 08-20-2018, 02:49 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
It looks like it is connecting. Otherwise, I won't have the custom setting. I see only a a handful option such as Wireless Door Lock, Option setup, Security which I can set but no seatbelt chime.
By the way, which version techstream do you have?
njchen24 is offline
post #4 of 20 Old 08-20-2018, 03:26 PM
Quoted: 1 Post(s)
OBD fuse.
Check to make sure the OBD fuse is good?
ChrisD324 is offline
post #5 of 20 Old 08-20-2018, 03:43 PM
Limited
2017Highlander's Avatar
Quoted: 635 Post(s)
Gotta love a guy that wants to break the law and not wear his seat belt. Priceless!
Phil Indeblanc likes this.
2017 Highlander Limited AWD, Blizzard Pearl on Black
2017Highlander is offline
post #6 of 20 Old 08-20-2018, 03:46 PM
Quoted: 1 Post(s)
CUSTOMIZE SEAT BELT WARNING SYSTEM
HINT:
The following items can be customized.
NOTICE:
When the customer requests a change in a function, first make sure that the function can be customized.
Be sure to make a note of the current settings before customizing.
When troubleshooting a function, first make sure that the function is set to the default setting.
These buzzers should be on for safe driving. Perform this procedure only if it is necessary to set the buzzer to off (disabled).
(a) Customizing with the Techstream
(1) Connect the Techstream to the DLC3.
(2) Turn the ignition switch to ON.
(3) Turn the Techstream on.
(4) Enter the following menus: Customize Setting / Warning.
(5) Select the setting by referring to the table below.
2017Highlander likes this.
The Following User Says Thank You to ChrisD324 For This Useful Post:
funman1 (08-21-2018)
post #7 of 20 Old 08-21-2018, 01:08 AM
Got Pyro?
funman1's Avatar
Quoted: 829 Post(s)
There are MANY reasons why people want them off and it's NOT illegal to turn them off.
I've turned them off for my family that owns a massive 400 acre ranch and drives on their private dirt roads.
I turned mine off because when I do Pyro shows I'm driving all over barren fields with nothing around for miles.
There are reasons people want things that don;t always fit the box for what the feature was intended for.
OP:
It's in the "Customize" Then "Warnings" Section
Phil Indeblanc and camelk like this.
Professional Pyro..
funman1 is offline
The Following 2 Users Say Thank You to funman1 For This Useful Post:
camelk (08-21-2018), RockyinNM22! (08-21-2018)
post #8 of 20 Old 08-21-2018, 05:01 AM
lgb0250's Avatar
Quoted: 209 Post(s)
quick OT question relating to techstream. Is there a factory reset setting function available on it? As some know, Iíve been having an issue where my liftgate only opens with a press on the fob when the vehicle is unlocked. From everything Iíve read and from what I remember from my previous HLís itís suppose to open with a long press even when locked! Mine doesnít. All I get when it is locked ittwo short beeps and then nothing. When itís unlocked mine opens with even a short press on the fob. Maybe if I can flush it I will be able to start over and get it to work properly without having to rely on a service visit.
2018 Toyota Highlander Limited Platinum Blizzard Pearl w/Almond Leather
2018 Nissan Rogue SV Premium GunMetal w/Black
lgb0250 is offline
post #9 of 20 Old 08-21-2018, 10:17 AM
Got Pyro?
funman1's Avatar
Quoted: 829 Post(s)
Not that I'm aware of.
Use Techstream or Carista to reprogram as needed.
Professional Pyro..
funman1 is offline
post #10 of 20 Old 08-21-2018, 10:23 AM
lgb0250's Avatar
Quoted: 209 Post(s)
Already tried using both with no help. Thanks anyway
lgb0250 is offline
post #11 of 20 Old 07-09-2019, 02:41 AM
Chasen's Avatar
Quoted: 1 Post(s)
i find a step-by-step guide on Toyota Tundra 2016 Seatbelt Chime Disable by Techstream TIS
http://www.car-auto-repair.com/toyot...techstream-tis
Hope it helps
Big mouthfuls ofter choke.
Chasen is offline
post #12 of 20 Old 07-11-2019, 08:06 AM
Quoted: 4 Post(s)
I purchased techstream also for my 16 Camry and get the same behavior. The seat belt chime option is missing. Not sure what is up. I can customize most everything else.
cdtech20059 is offline
post #13 of 20 Old 07-11-2019, 10:09 AM
Scruffy Nerf Herder
K_Watson's Avatar
Quoted: 872 Post(s)
The knockoffs have several versions and some use firmware that cannot do customization and cannot be updated. This is why we only recommend legitimate hardware and licensed software.
'13 Corolla S Premium Complete BSP
'01 Camry XLE V6 Black (Her's 06+)
'12 Corolla S w/ Nav MGM (15-16)
'98 Chevy Prizm base Green (06-15)
'97 Camry LE I4 Gold (Her's 03-06)
'85 Pickup SR5 (Family truck 89-18)
K_Watson is offline
post #14 of 20 Old 07-11-2019, 10:18 AM
Quoted: 187 Post(s)
Disabling the buzzer/chime is not breaking the law just so you know
Lazy Cat likes this.
Brent Hardy is offline
post #15 of 20 Old 07-11-2019, 04:01 PM
Limited
Quoted: 635 Post(s)
Reading comprehension issues, again? Let me help. Just so you know, i stated that not wearing a seat belt is breaking the law. Have a nice day!
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Highlander Forum > Highlander 3rd Generation (2014-2019)
User Tag List
Linear Mode Linear Mode
