2017 oil leak - Toyota Nation Forum : Toyota Car and Truck Forums
Highlander 3rd Generation (2014-2019) Forum dedicated to the discussion of 3rd generation Toyota Highlanders.
 2Likes
  • 1 Post By wv_lx450
  • 1 Post By McSpazatron
post #1 of 14 Old 05-11-2019, 10:53 AM Thread Starter
wv_lx450's Avatar
Quoted: 1 Post(s)
(Thread Starter)
2017 oil leak
2017 highlander awd... was changing the oil today and noticed an oil leak on the drivers side just above the cv axle. it doesnt appear to be a bad leak and i cant see in there good enough to tell if its coming from one of the hoses in the pics or from above. it has the look of engine oil but theres not much smell to it so im not really sure. its definitely not gear oil and doesnt look or smell like trans fluid.
are the hoses and such covered under the 60k mi powertrain warranty? if its not under warranty, im not even scheduling a trip to the dealer. ill just fix it myself.
Click image for larger version
ID:	240298   Click image for larger version
ID:	240300   Click image for larger version
wv_lx450 is offline
post #2 of 14 Old 05-11-2019, 03:13 PM
Gort45's Avatar
Quoted: 29 Post(s)
Take it to the dealer and let them diagnose it.
"You can't Fix Stupid"
2018 HL Limited AWD Predawn Gray Mica
Ash Interior
2013 Venza Limited AWD Blizzard Pearl
Almond Interior
Gort45 is offline
post #3 of 14 Old 05-12-2019, 12:49 AM
Quoted: 39 Post(s)
Talk to the dealer and ask if it's still covered under warranty. If not, and you want to handle it yourself, try these steps: clean off the oil with degreaser and water; let dry, blow some corn starch on it to better trace where the oil comes from; make sure it's really engine oil, and not some other fluid.
2017 Highlander Limited Platnum Aluma Jade
2006 Lexus RX400h AWD Mica Grey
gwgang1 is offline
post #4 of 14 Old 05-12-2019, 10:43 AM
Senior TN Member
Quoted: 664 Post(s)
Too many times, especially if no warranty, most leaks are from the 'lube lane'. Hack techs spill oil everywhere.
So, do nothing without a thorough cleaning. Make sure you definitely find the source of the leak.
If its not the hack tech, its the front cover (timing chain area) or one of the valve/rocker/cam covers. This is relatively rare on young vehicles.
So many trolls so little time
Greasymechtech is online now
post #5 of 14 Old 05-12-2019, 11:01 AM Thread Starter
wv_lx450's Avatar
Quoted: 1 Post(s)
(Thread Starter)
i know its not from spilled oil or anyone working on it because i do my own maintenance. the only time it was in the shop was to have the trans replaced at 6k miles and it has 46k on it now. the leak definitely showed up between the last oil change (in march) and this one. im going to investigate further today when i have the wheels off to replace the rotors.
wv_lx450 is offline
post #6 of 14 Old 05-12-2019, 01:36 PM Thread Starter
wv_lx450's Avatar
Quoted: 1 Post(s)
(Thread Starter)
looks like its coming from this breather or whatever it is on the transmission/transaxle. the hose just slides over it and is very loose. when i pulled the hose off, there was a decent amount of air pressure in there so maybe its a differential breather or something. not sure why it would just start leaking after this many miles.
ID:	240346   Click image for larger version
wv_lx450 is offline
post #7 of 14 Old 05-12-2019, 01:57 PM
Senior TN Member
Quoted: 664 Post(s)
Weather is warming up and transmission fluid is running hotter.... I would have the ATF level checked correctly. I would also see if that is the same on another highlander.... might've been broken after transmission change
Was the transmission hot or cold when you broke the seal?
post #8 of 14 Old 05-12-2019, 02:19 PM Thread Starter
wv_lx450's Avatar
Quoted: 1 Post(s)
(Thread Starter)
trans was cold, just moved the car from the house to the garage after it was sitting all night. i was surprised at the air pressure since the trans was cold.
wv_lx450 is offline
post #9 of 14 Old 05-14-2019, 06:54 PM Thread Starter
wv_lx450's Avatar
Quoted: 1 Post(s)
(Thread Starter)
this breather leak was bugging me so i had to look at it again. i kept looking at the pics i had and dont know why i didnt notice it to start with but you can see plastic around the end of the hose. ive never seen a breather hose with a plastic liner so i pulled the hose back off today to find that a dust cap was blocking the hose. apparently the new trans was shipped with a dust cap over the breather tube and the dealer just put the hose on over it. surprised it never leaked til now.
ID:	240590   Click image for larger version
Highlander56 likes this.
wv_lx450 is offline
post #10 of 14 Old 05-14-2019, 09:53 PM
Quoted: 36 Post(s)
Excellent bit of diagnostic work there! That might have avoided a wild goose chase.
stvotw likes this.
McSpazatron is offline
post #11 of 14 Old 05-15-2019, 04:30 PM
Quoted: 10 Post(s)
The tranny had to be replaced at 6k miles? What year is your vehicle?
ericward is offline
post #12 of 14 Old 05-15-2019, 06:43 PM Thread Starter
wv_lx450's Avatar
Quoted: 1 Post(s)
(Thread Starter)
2017. i was changing the oil at around 6k mi and noticed trans fluid leaking from the bell housing area. ended up being the input shaft seal and toyota replaced the whole trans. its got 46k on it now and no trans issues since.
wv_lx450 is offline
post #13 of 14 Old 05-18-2019, 10:45 PM
Quoted: 232 Post(s)
Oil leak TSB... Could be related?
https://www.toyotanation.com/forum/s...php?p=13944840
2017 HL XLE AWD
dchobo is online now
post #14 of 14 Old 05-19-2019, 09:17 AM Thread Starter
wv_lx450's Avatar
Quoted: 1 Post(s)
(Thread Starter)
this leak was definitely coming from the breather hose. i think the cap was causing the pressure to build up in the trans until the pressure could overcome the seal of the cap and then blow out oil vapor and air.
wv_lx450 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Highlander Forum > Highlander 3rd Generation (2014-2019)
User Tag List
Linear Mode Linear Mode
