Changing door unlocking sequence - Toyota Nation Forum : Toyota Car and Truck Forums
Highlander 3rd Generation (2014-2019) Forum dedicated to the discussion of 3rd generation Toyota Highlanders.
post #1 of 6 Old 06-04-2019, 07:41 AM Thread Starter
Quoted: 40 Post(s)
(Thread Starter)
I want all the doors to be unlocked from the drivers door. Is this a dealer computer change or is there a simple fix ? Its probably been solved in prior posts but unable to find with limited computer experience.
Thanks.
bought the ranch is offline
post #2 of 6 Old 06-04-2019, 07:59 AM
Quoted: 23 Post(s)
You can change this yourself
1) touch the apps button
2) touch the setup button
3) touch the arrow at the bottom of the screen to get to the vehicle button
4) touch the vehicle button
5) touch the vehicle customization button
6) touch the door lock settings
7) touch the arrow to select all doors to unlock instead of only the driver's door
Goldstar is offline
post #3 of 6 Old 06-04-2019, 08:03 AM
Senior TN Member
Jdsmitty10's Avatar
Quoted: 315 Post(s)
This setting can be changed from the Nav screen
2018 Highlander Platinum Blizzard Pearl
Morimoto 35w 5500k HIDs
2012 Camry SE V6 Loaded Barcelona Red
Morimoto 35w 5000k HIDs~
Jdsmitty10 is offline
post #4 of 6 Old 06-04-2019, 03:12 PM Thread Starter
Quoted: 40 Post(s)
(Thread Starter)
Thanks, Doesn't even sound complicated.
post #5 of 6 Old 06-15-2019, 11:47 AM Thread Starter
Quoted: 40 Post(s)
(Thread Starter)
Completed to step 7. Selected all doors. Is this the end of the reprogramming or is there another step ? I got back to the app screen and it will not respond to the outside door locks. If I lock from the inside button it beeps and does not lock any door.
How do you finalize the change? Does it have to be running as I am on the accessory mode while programming.
post #6 of 6 Old 06-17-2019, 08:18 AM
Quoted: 23 Post(s)
after step 7, just keep tapping the back button until you get back to the main screen. You can do this without starting the car.
Goldstar is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Highlander Forum > Highlander 3rd Generation (2014-2019)
User Tag List
Linear Mode Linear Mode
