14 Highlander XLE Smart Key touch to lock function not working after actuator change - Toyota Nation Forum : Toyota Car and Truck Forums
Highlander 3rd Generation (2014-2019) Forum dedicated to the discussion of 3rd generation Toyota Highlanders.
 2Likes
  • 1 Post By DerekD2014Highlander
  • 1 Post By rseward
post #1 of 8 Old 06-18-2019, 10:15 PM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
Hi All,
Today I changed the driver door actuator in my 14 Highlander XLE. After the install the function to lock the doors by touching the 2 lines on the outside of the door handle no longer works. The lock/unlock functions on the keyfob and inside door controls all work perfectly but the feature to lock the doors by touching the outside handle is failing(no response from vehicle). Any suggestions on what to try to trouble shoot this or what the issue could be?
Appreciate the help!
DD
2014 Highlander XLE
DerekD2014Highlander is offline
post #2 of 8 Old 06-19-2019, 09:47 AM
Quoted: 59 Post(s)
Can you unlock from the door handle, by placing your hand behind it?
If both lock and unlock from the door handle are not working, Iíd suggest you open it up again, and check the harness that connects to the door handle. Maybe it was disconnected and wasnít reconnected properly.
Actually... Iíd suggest you check that even if you can unlock from the door handle. Could be a pin in the harness not making contact, or got bent or something.
rseward is offline
post #3 of 8 Old 06-19-2019, 10:26 AM
Senior TN Member
Quoted: 509 Post(s)
DD..as mentioned, possibly connection issue, IDK? Some info..search this forum..enter..door lock actuator. Recall member toddsta did actuator install with pics with no issues. Hopefully easy fix.
2014 HL Blizzard Pearl XLE AWD V6 Ash Int. M. Latitude Tour 245/60R18. OEM Tow hitch/4 pin. B/D 04/14
BUFFO is offline
post #4 of 8 Old 06-19-2019, 10:30 AM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
Thanks for the replies guys, yes the door unlocks with touching the inside of the door handle. I’ll tear it apart again today and see if the harness is properly seated checking for bent pins etc. swap was a easy enough task. I’ll give an update later today
PS neither the passenger nor driver door will lock by touching the handle, perhaps it needs to complete a circuit for both or either to work
2014 Highlander XLE
post #5 of 8 Old 06-19-2019, 11:59 AM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
Well no dice after tearing it apart again, all the harness's were seated properly no pins bent. There are 2 small guage wires coming off the main line that go into the part of the door handle that’s behind the 2 lines on the handle and I assume this is the part that operates the touch to lock feature, see pix. I unseated the harness and looked it over, 2 pins look fine to I reseated and still nothing....I didn’t have a volt meter to check for power. This has me baffled and wifey not liking she has to fetch her fob out of her purse now.....so what to check now?
Click image for larger version
ID:	243094   Click image for larger version
2014 Highlander XLE
post #6 of 8 Old 06-19-2019, 05:08 PM
Quoted: 59 Post(s)
Iíd try disconnecting and reconnecting the battery, just to see if it resets something.
You might also want to check fuses, but I doubt thereís a fuse dedicated to just the door handles.
Also make sure itís the correct actuator for your model/yr/trim.
rseward is offline
post #7 of 8 Old 06-19-2019, 09:15 PM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
ok we now have some joy! Disconnected battery and cleaned the terminal and connectors and reattached and now the touch to lock function is back and all other functions of the door locks and actuator are working as normal. I really appreciate the help guys!
For what its worth I got the actuator from a guy on eBay that refurbishes them and resells them. I paid 109 for an OEM refurbished unit and if I send in my old core he provides a lifetime warranty on the actuator. Not too bad considering toyota wanted almost 300 for the actuator. Here's a link to his listing on eBay:
https://www.ebay.com/itm/Toyota-High...72.m2749.l2649
BUFFO likes this.
2014 Highlander XLE
post #8 of 8 Old 06-19-2019, 10:25 PM
Quoted: 59 Post(s)
Glad to hear itís resolved...
Itís recommended to disconnect the battery anytime youíre working on electronic components (I donít always do it either). Doing so surly would have avoided the issue all together.
BUFFO likes this.
rseward is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Highlander Forum > Highlander 3rd Generation (2014-2019)
User Tag List
Linear Mode Linear Mode
