2014 Corolla items - Toyota Nation Forum : Toyota Car and Truck Forums
Corolla 11th Gen (Sedan 2014-2019)/Scion iM (2016-2018) Forums dedicated to the 11th generation Toyota Corolla, as well as the directly related Scion iM
 1Likes
  • 1 Post By Di3S3L
post #1 of 9 Old 02-27-2019, 06:32 PM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
2014 Corolla items
Wife has a 2014 Corolla LE Plus. Well looked after since 4 and half years. 31k miles. Out of warranty and we purchased no service plan.
What all services would you recommend for the car at this stage - just had an oil change done and an alignment done. Not sure if the alignment toe angle was super out of spec or not? Did the shop just rip us off ?
https://ibb.co/VHrJJDj
adi1031 is offline
post #2 of 9 Old 02-27-2019, 06:56 PM
redlinebluecrush's Avatar
Quoted: 19 Post(s)
What was the before on the toe?
Sent from my LM-V405 using Tapatalk
redlinebluecrush is offline
post #3 of 9 Old 02-28-2019, 04:00 PM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
My bad. This is the before picture. They reset it to 0.00 and 0.01 on the front left and front right.
They were not supposed to charge me if everything was within spec. I'm not sure if these measurements are to be considered bad or manageable
adi1031 is offline
post #4 of 9 Old 05-25-2019, 01:34 PM
Quoted: 19 Post(s)
Certainly within toyota spec. At least according to the print out. Cant find my sheet but my toe was out on my 14 enough to be in the red but they were able to bring it back in.
The Following User Says Thank You to redlinebluecrush For This Useful Post:
adi1031 (05-27-2019)
post #5 of 9 Old 05-25-2019, 04:24 PM
Di3S3L's Avatar
Quoted: 156 Post(s)
Make sure the TSB for the CVT is done. Every 5K, change the oil and oil filter. Every year, clean out or replace your in cabin air filter. Every 60K, get a CVT drain and fill service done. @90K change the spark plugs, and replace the air filter. @180 K do a coolant flush, replace the water pump, and engine thermostat.
Di3S3L is offline
The Following User Says Thank You to Di3S3L For This Useful Post:
post #6 of 9 Old 05-27-2019, 10:03 PM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
Thanks for the response. Will try to find recommended services for the CVT.
Got this sheet from the dealership. Not sure how effective a fuel system cleaner is and if it's really needed.
adi1031 is offline
post #7 of 9 Old 05-29-2019, 02:01 PM
Di3S3L's Avatar
Quoted: 156 Post(s)
You don't need that.
Joseph Juguilon likes this.
Di3S3L is offline
post #8 of 9 Old 05-29-2019, 02:26 PM
Quoted: 69 Post(s)
Everything Diesel said, but I'd suggest changing the coolant once at 90K rather than waiting until 180K. Also, I would suggest that you change your engine air filter every ~30-50K.
2001 Camry LE 2.2L, Black, 146K as of 7/19
Bought 10/16 with 131K
2001 Camry LE 2.2L, Lunar Mist Metallic, 97K as of 7/19
Bought 6/01 brand new
jiantao is offline
post #9 of 9 Old 06-01-2019, 11:30 PM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
Thanks guys. Just changed the engine air filter when it hit 30K. Definitely needed a change. Cabin air filter also changed just now. This is the third filter. Other than that I keep the oil interval at 6K with full synthetic. Allegedly it can go up to 10K on full synthetic, but I'm skeptical on that.
adi1031 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > Corolla 11th Gen (Sedan 2014-2019)/Scion iM (2016-2018)
User Tag List
Linear Mode Linear Mode
